saw on a rope
Discussion in 'Home Repair' started by okey, Sep 13, 2009.
  1. okey
    okey Guest
    I've seen flexible "wire" saws that can bend a good bit. These wire
    saws have a grit coating. I need to cut down a tree and was wondering
    if anyone has ever used something like this on a rope. You tie ropes
    to either end of a "wire" saw, toss one end over a branch and pull
    back and forth on the ropes to cut the limb.
    I need to take down some high branches and don't have the $$$$ to pay
    anyone. Don't mind climbing up high, but sawing/working up high is
    another thing. I get spooked fast.
    The branches are way beyond the reach of any poll saws I've ever seen.
    okey, Sep 13, 2009
  2. okey
    fftt Guest
    > Thanks
    here's a multi-segment pole saw ~18 feet
    http://www.amazon.com/dp/B000XTMFOC...e=asn&creative=380341&creativeASIN=B000XTMFOC
    here;s a flexible saw that could be used as you propose....
    http://www.unbelievable-saw.com/
    but be careful! A large limb coming down from height is
    dangerous. Large limbs can break before the cut is complete & rip the
    tree's bark badly.
    Proper / safe tree trimming requires care.
    cheers
    Bob
    fftt, Sep 13, 2009
  3. okey
    Tony Hwang Guest
    > Thanks
    Cutting down a tree? How big and high?
    Once I did with a small gas chain saw.
    Tony Hwang, Sep 13, 2009
  4. okey
    Jim Elbrecht Guest
    -snip-
    I've got one in the garage. Might just be me, but it takes a good
    deal of strength and co-ordination to use the darn thing. My son
    and I did manage to finally cut a 6" limb 20 feet up in a tree. We
    had 30 feet or so of rope on each side of the saw- could only cut the
    branch where it was horizontal- and it took the better part of an
    hour.
    Maybe if we did it every day for a year or so we'd discover some sort
    of rhythm- but it was just plain clumsy this time around.
    >tree's bark badly.
    A tree-man would undercut the branch- you can't with those saws.
    Call a tree guy- the one with the smallest ad in the yellow pages.
    Jim
    Jim Elbrecht, Sep 13, 2009
  5. okey
    okey Guest
    On Sep 12, 11:11 pm, "benick" <> wrote:
    > "okey" <> wrote in message
    > news:...
    > > Thanks
    > Ya , good idea...Stand directly under a limb your cutting off with a wire
    > saw on a rope...Is your life insurance paid up to date ?? If not do so for
    > your family....
    sure stupid ass... that's what I'm going to do, stand under the
    thing. Are you retarded?
    okey, Sep 13, 2009
  6. okey
    okey Guest
    > tree's bark badly.
    > cheers
    > Bob
    Looks like what I need. Thanks. Now to go cut it while I sand
    directly under it for benick's entertainment.
    okey, Sep 13, 2009
  7. okey
    okey Guest
    > > tree's bark badly.
    > > cheers
    > > Bob
    And found at that saw's website; Special instructions just for
    me! :)
    Great for cutting high limbs. Simply add your own ropes to both
    handles and throw over a high limb to cut easily from the ground. Be
    careful not to stand under the limb as it falls.
    okey, Sep 13, 2009
  8. okey
    Smitty Two Guest
    In article <>,
    "John Gilmer" <> wrote:
    > I'm in my mid 60s so it had taken me a fair amount of time to cut things
    > using these gadgets and, therefore, I have been tempted to use the ladder
    > and some power equipment.
    I used chain saws on ladders occasionally when I was a tad younger, but
    now the combination makes me nervous. A sharp bow saw will cut through
    any limb smaller than 6" in very short order.
    Smitty Two, Sep 13, 2009
  9. okey
    RicodJour Guest
    On Sep 13, 12:50 pm, willshak <> wrote:
    > With a long enough rope, one can stand as far away from the tree as the
    > rope allows. You don't have to stand directly under a flagpole to raise
    > or lower the flag with a long enough halyard..
    Right. The OP said he didn't mind climbing, so he could possibly
    climb a nearby tree, prop himself against a limb and saw from a
    greater elevation. That would take care of undercutting the limb,
    assuming the flexible blade was long enough and angle sufficient.
    RicodJour, Sep 13, 2009
  10. okey
    Tom Horne Guest
    > news:...
    > >news:....
    > > > The branches are way beyond the reach of any poll saws I've ever seen..
    > > > Thanks
    > > your family....
    > Ahh , more 2nd grade name calling...Your IQ is showing.......
    > I use a Homelite Electric, 15 Ft. Reach, Pole Chain Saw with an extensionor
    > step ladder to get the higher ones if needed....99 bucks at
    > Homedepot....Works
    > GREAT........http://www.homedepot.com/Outdoors-Outdoor-Power-Equipment-Chainsaws-C...
    He wasn't the one that started the insulting drivel. You were!
    Tom Horne
    Tom Horne, Sep 14, 2009
  11. okey
    DerbyDad03 Guest
    > on 9/13/2009 1:08 AM (ET) Ed Pawlowski wrote the following:
    > > "benick" <> wrote in message
    > >news:...
    > >>news:....
    > >>> Thanks
    > >> saw on a rope...Is your life insurance paid up to date ?? If not do sofor
    > >> your family....
    > > Two people standing far apart would work well with a saw of that sort.
    > Bill
    > In Hamptonburgh, NY
    > In the original Orange County. Est. 1683
    > To email, remove the double zeroes after @
    re: "You don't have to stand directly under a flagpole to raise or
    lower the flag with a long enough halyard."
    True...but why wouldn't you?
    DerbyDad03, Sep 14, 2009
    #11
  12. okey
    JIMMIE Guest
    > news:...
    > >news:....
    > > > Thanks
    > > your family....
    > Homedepot....Works
    Duct tape is a crirtal part of the way I handle triming some limbs a
    few years ago. I Duct tapped a fleamarket sawzall to a piece of pipe
    and stood on my dog box in the back of the pickup. I dont really
    reccomend doing this but it worked for me in a moment of insanity.
    Jimmie
    JIMMIE, Sep 14, 2009
    #12
  13. okey
    Tony Hwang Guest
    SteveB wrote:
    > "JIMMIE" <> wrote in message
    > news:...
    >> news:...
    >>> news:...
    >>>> Thanks
    >>> wire
    >>> for
    >>> your family....
    >> or
    >> Homedepot....Works
    > Jimmie
    > What's wrong with that? I duct taped a hedge trimmer to a piece of pvc,
    > then stood on a sheet of plywood on top of my truck rack to poodle cut my
    > olive trees.
    > Steve
    Gorilla tape is even better, LOL!
    Tony Hwang, Sep 14, 2009
    #13
  1. MattP
    chop saw/compound mitre saw
    MattP, Jan 28, 2004, in forum: UK DIY
    576
    Dave Plowman
    Jan 30, 2004
  2. Tom
    2,430
    John Rumm
    Nov 2, 2007
  3. Replies:
  4. Adam Lipscombe
    Reciprocating saw vs Chain saw
    Adam Lipscombe, Jun 30, 2008, in forum: UK DIY
    34
    2,518
    Dan Smithers
    Jul 3, 2008
  5. Sam Kaan
    Cordless Circular saw versus Trim Saw?
    Sam Kaan, Nov 20, 2003, in forum: Home Repair
    576
    CBHvac
    Nov 21, 2003
