Sandtex masonry paint
Discussion in 'UK DIY' started by Appelation Controlee, Apr 14, 2011.
  1. Reading the instructions for the above re. preparation, a coat of
    Sandtex Stabilising Solution is recommended to seal the surface before
    application of the masonry paint itself.
    Works OK, but the stabilising solution itself appears, superficially
    at least, to be no more than a thin PVA solution. Does anyone know
    whether this is, in fact, the case, or is it a more complex product
    than that?
    PVA would certainly be cheaper, but I'm not looking for false
    economies.
    > than that?
    > economies.
    I didnt bother. used a thin coat first as sealer.
    Got some spallation where water splash + frost got in: used some sort of
    weathershield to fix that.
    The Natural Philosopher, Apr 14, 2011
  3. Appelation Controlee
    stuart noble Guest
    > than that?
    > economies.
    I'd say the stabiliser is probably an unpigmented version of the paint
    itself, so more likely to be an acrylic. Could also be more penetrative
    than pva
    stuart noble, Apr 15, 2011
    > than pva
    One way to find out what is in things is to look up the COSHH
    datsheet on the product. The manufacturers web site should have them
    available for download.
    I was under the impression that you only needed to use the stabiliser
    if the surface was powdery, ie rub your fingers along it and they get
    covered in fine dust. I didn't use stabilser last year on our walls,
    combination of pressure washed stone or painted render also pressure
    washed to remove the loose paint. Did use a slightly diluted first
    coat then two full strength, it has survived the winter...
    Cheers
    Dave.
    Dave Liquorice, Apr 15, 2011
  5. On Fri, 15 Apr 2011 10:49:02 +0100 (BST), "Dave Liquorice"
    >> than pva
    It is supposed to bind the surface, but my main concern is preventing
    migration of staining from the surface being covered.
    Appelation Controlee, Apr 15, 2011
  6. Appelation Controlee
    stuart noble Guest
    >>> than pva
    Stabiliser always used to be solvent based, partly for that reason. I
    don't know whether pukka paint outlets might still sell it
    >>> than pva
    I think a point needs making here. 'sealers' is a generic term, and in
    this context there are two entirely different classes of product that do
    two entirely different things. The binders, and the waterproof coatings
    As far as the binders go, I find most professional painters simply use a
    coat of thinned paint. Its shade more expensive, but it has got SOME
    pigment in, and if a piss coat plus two coats rather than 3 coats
    overall plus sealer is what it takes to get the color depth, its overall
    cheaper probably.
    Whilst paint or sealer does slow water uptake, it also slows water
    egress, That means a painted sealed render is not that much better tan a
    panted or indeed a bare render at frost attack.
    And it can breathe and dry itself out.
    If you go the weathershield or whatever route which puts an impermeable
    layer in on the render surface, you will indeed completely stop water
    getting in, but you may also stop it getting out if it gets behind the
    sealed render surface.
    My approach is to use the latter sparingly in places that are both cold
    and subject to high water splash, ONLY where spallation has been
    established as happening anyway. In my case that's the tops of lead
    covered drip boards over the windows, on the house North side.
    The Natural Philosopher, Apr 15, 2011
    >>>> than pva
    Many types exist. The weatheshield types are I think solvent based or
    actual cold set resins of some sort.
    They will stop staining, but they will also stop a wet render drying. So
    be careful.
  9. Appelation Controlee
    Tabby Guest
    > than that?
    > economies.
    Its a false economy to use paint that doesn't last well. I found Dulux
    has lasted where the various screwfix ones haven't.
    NT
    Tabby, Apr 16, 2011
  10. On Fri, 15 Apr 2011 17:48:42 +0100, The Natural Philosopher
    -----------------------------8><
    >cheaper probably.
    Thanks - taken under consideration. :)
    Appelation Controlee, Apr 17, 2011
  1. Rick Hughes
    Spraying Sandtex ?
    Rick Hughes, Aug 18, 2003, in forum: UK DIY
    418
    Rick Hughes
    Aug 18, 2003
  2. Rick
    1,265
    Sep 22, 2003
  3. Brian G
    Re: Exterior Painting - Sandtex
    Brian G, May 7, 2007, in forum: Misc DIY
    1,226
    Brian G
    May 7, 2007
  4. Geoff Pearson
    Black Sandtex type finish
    Geoff Pearson, Aug 19, 2012, in forum: UK DIY
    243
    Phil L
    Aug 19, 2012
  5. Replies:
    272
