Rust spots in new plaster
Discussion in 'Misc DIY' started by brenda@gogetcreative.com, Sep 9, 2007.
  1. Guest
    We removed a picture rail when we had our lounge plastered. We are
    getting ready to paint but there are rust spots along the wall where
    the old nails were. Do we need to seal the rust spots to keep them
    from bleeding through the paint or will that not be a problem? If we
    do need to seal, any recommendations? Thanks for any help!
    , Sep 9, 2007
  2. Cicero Guest
    On Sun, 09 Sep 2007 03:25:41 -0700, brenda wrote:
    > We removed a picture rail when we had our lounge plastered. We are getting
    > ready to paint but there are rust spots along the wall where the old nails
    > were. Do we need to seal the rust spots to keep them from bleeding through
    > the paint or will that not be a problem? If we do need to seal, any
    The rust spots are probably where the old nails have been left in place.
    If there aren't many the best solution would be to gouge out some of the
    stained plaster, remove the nails if possible but if not then paint
    each nail with a bit of oil-based paint. Finish off with Polyfilla.
    Alternatively you could look for a stain block paint in B & Q etc. and see
    if it's suitable for this purpose - i.e. painting over rust-stained
    plaster. They're usually intended to cover damp stains but might work on
    your rust stains.
    Cic.
    Using Ubuntu Linux
    Windows shown the door
    Cicero, Sep 9, 2007
  3. Stuart Noble Guest
    > your rust stains.
    > Cic.
    Paint the plaster with a white oil based undercoat.
    Stuart Noble, Sep 9, 2007
  4. Pete C Guest
    Should be OK as long as the wall doesn't get damp.
    Also try asking on the 'talk forum' on the Screwfix website.
    cheers,
    Pete.
    Pete C, Sep 9, 2007
  1. Jon
    14
    578
  2. Mark Carver
    Removing rust spots on Kitchen Sink
    Mark Carver, Jun 29, 2005, in forum: Misc DIY
    560
    James Salisbury
    Jun 29, 2005
  3. Chuck B.
    Dishwasher rack rust spots
    Chuck B., Jul 6, 2005, in forum: Home Repair
    672
    Appliance Repair Aid
    Jul 6, 2005
  4. Flank
    rust spots on exterior walls
    Flank, Jul 29, 2006, in forum: Misc DIY
    458
    Hopkins
    Jul 31, 2006
  5. Replies:
    408
