Roof Ridge vent length
Discussion in 'Building Construction' started by Guest, Oct 4, 2005.
  1. Guest
    Guest Guest
    I am putting roof ridge vents on my new home construction. I want the
    roofer go all the way to the edge but he wants to go in about four feet as
    he says the wind might catch it. Since he and I have never used the
    product before (Always used the square vents). I thought somebody with
    experience with these vents might give us some advise.
    Any help would be appreciated.
    Jeff
    Guest, Oct 4, 2005
  2. Guest
    DDP Guest
    On Tue, 4 Oct 2005 09:17:27 +0300, <>
    >Thanks
    >Jeff
    I always started my ridge vent about 1 foot from the edge. This is
    mainly for apperance but also it allows you to seal the ends of the
    ridge cap to prevent leakage.
    DDP
    If you always do what you always did
    you always get what you always got.
    DDP, Oct 6, 2005
  3. Guest
    3D Peruna Guest
    "Lil' Dave" <> wrote in message
    news:Rl51f.9554$...
    > "M&S" <> wrote in message
    >> To the OP I would vent the entire attic space at the very least however
    >> as one post has already stated, the manufacturer specifically states the
    >> amount of vent needed and provides charts on the packaging to explain
    >> this to you and your contractor.
    >> Mark
    > Believe you should reconsider the primary source of heat of the attic area
    > when it needs venting the most, summertime. Unless its basically a flat
    > roof, lookouts aren't going to appreciably hinder the hot air from going
    > to
    > the ridge vent.
    I'd spend some time at http://www.buildingscience.com and learn about
    venting of attics...
    3D Peruna, Oct 6, 2005
  4. I have a roof vent the full length of the house and I don't think it moves
    enough air.
    If you go up in the "attic" in the summer, I'll bet it is over 120º.
    JerryD(upstateNY)
    >> Mark
    > to
    > the ridge vent.
    JerryD\(upstateNY\), Oct 7, 2005
  5. JerryD(upstateNY) -
    moves
    > enough air.
    - Nehmo -
    >>>What are your soffit vents like? Do you think they’re big enough? Are
    they clogged with insulation? And you might take a thermometer up there
    next year to get an objective measurement.<<<<
    I have the continuous vented soffit.
    It has 1/8" holes about a 1/2" apart on the whole area of the soffit and it
    runs the whole 40' of the house, front and back.
    The roof vent runs the whole 40' of the house.
    JerryD(upstateNY)
    JerryD\(upstateNY\), Oct 11, 2005
  1. Todd W. Roat
    Roof ridge vent: a DIY project?
    Todd W. Roat, Jun 1, 2004, in forum: Misc DIY
    491
    Todd W. Roat
    Jun 3, 2004
  2. Replies:
    8
    578
  3. Replies:
    8
    690
  4. Mike
    564
  5. usethisone2007
    348
    John Grabowski
    Jun 10, 2008
