Rid-X For Septic Systems: Any Good ?
Discussion in 'Home Repair' started by Robert11, Feb 3, 2005.
  1. Robert11
    Robert11 Guest
    Hello:
    That product for septic systems, Rid-X, is it any good ?
    or, just "good" advertising ?
    Any thoughts on would be appreciated.
    Bob
  2. Matt
    Matt Guest
    Re: Rid-X For Septic Systems: Any Good ?
    It's pretty good on cornflakes. Don't put it on Lucky Charms tho.
    Matt, Feb 3, 2005
  3. Barkie McDog
    Barkie McDog Guest
    I hear it's great with crabs too. So I've read anyway.
    Barkie McDog, Feb 3, 2005
  4. Matt
    Matt Guest
    Yeah. I think if you eat enough of it, then it absorbs all your shit
    before it needs to exit your body, and therefore, your septic system
    never fills up.
    Or maybe you die if you eat it, and therefore, your septic system never
    fills up.
    I can't remember which it is.
    Maybe Jeff Wisnia will have a bowl and let us know.
    Matt, Feb 3, 2005
  5. Bob S.
    Bob S. Guest
    Robert11 wrote:
    > Hello:
    > Bob
    I guess you'd appreciate an honest opinion instead of a wise-ass remark
    about now.
    Yes, it's a good product as are many other brands. All are concentrated
    bacteria designed to breakdown organic material in your septic tank.
    What is more important, however, is what else is going down the septic
    system. If you flush comdoms, Kotex pads, plastic trash, etc., no
    amount of Rid-x is going to do you any good.
    If you can lift the flush-out lid on your tank, take a look inside. In
    a properly maintained tank there should be little to no material
    floating on the surface of the sewage. That means the tank has
    sufficient bacteria to handle the products going into it.
    I use Rid-x about every 4-6 weeks and am careful about what goes into
    the tank. After 10 years of use there was about 1" of sludge on the
    bottom of the tank. At that rate it may never need pumping out again.
    Bob S.
    Bob S., Feb 4, 2005
  6. toller
    toller Guest
    Septic system manufacturers say additives do not help. They have no reason
    to lie, since they want you to be happy with your system; so I figure
    toller, Feb 4, 2005
  7. Matt
    Matt Guest
    I've never had a septic system. But I always figured Rid-x was full of
    shit for 2 reasons:
    1. Anyone who runs an ad campaign with people who make a living pumping
    shit giving advice that supposedly will reduce the number of times they
    have to come pump shit - is bullshit.
    2. Any ad that actually shows little cartoons in the process of
    breaking down shit - is a shitty ad.
    Hence, rid-x is full of shit.
    But, they have been able to bullshit a lot of people with their crap,
    as somehow they manage to run their shitty ads on national tv in prime
    time.
    Viva la rid-x!
    Matt, Feb 4, 2005
  8. Matt
    Matt Guest
    That brings up an interesting point. What is the politically correct
    method of disposing of condoms these days?
    Flushing? Trash? Composting? Recycling?
    Effi, please let us know.
    Matt, Feb 4, 2005
  9. Bob S.
    Bob S. Guest
    Eric Tonks wrote:
    > If you don't have sludge in the bottom of your tank you must be
    flushing it
    > out into your leaching field. That is what Rid-X is well known for,
    stirring
    > up the sludge into the liquid so that it can flow into the leaching
    field
    > and clog it up.
    No! Sludge is heavier than water and settles at the bottom of the tank.
    It cannot get into the leach field until it builds up to the level of
    the tank output line. Rid-x is concentrated bacteria. It has NO
    properties for stirring up sludge.
    > You should have sludge in the bottom of a tank that has not been
    pumped out.
    > That is all the non-organic materials that go down the drain. One
    major
    > non-organic item is minerals and grit which is from all the dirt that
    is
    > flushed down the drain every time you wash yourself. This is the
    stuff that
    > should be pumped out on a regular basis not stirred up and drained
    into your
    > leach piping.
    Agreed that sand and grit cannot be broken down by bacteria and remains
    at the bottom of the tank as a prime ingredient of sludge. However,
    using a 1000 gal. septic tank would require a LOT of dirt. Personally,
    I'm not that dirty.
    Contrary to the opinions of many others, who's opinions I do NOT agree
    with, here's why Rid-X, or any other similar product, is ocassionally a
    good idea to use:
    (1)It takes bacteria to break down organic material into soft liquids
    that flush out into the leach field. The "primary" source of bacteria
    is feces.
    (2)Chlorine kills bacteria. Chlorine enters the septic system from
    household clensers and clothes wash products.
    (3) The more people in a family, the more feces, but also the more
    table scraps, grease, and clothes wash (chlorine).
    (4) Over a period of time, the bacteria level drops until it cannot
    keep up with the organic input. And your sludge level starts rising
    dramatically.
    Do you NEED to add Rid-x or other type products? NO.
    Will you have to have your tank pumped more often if you don't? YES
    So do you pay the septic tank service company more oftem for a
    cleanout, or pay a merchant for a septic tank additive? Your call. But
    as I stated in an earlier post, I had my tank cleaned after 10 years
    use just because I didn't know how it was building up. I watched the
    whole process. It only had about 1-2 inches of sludge. The service man
    stated it was the "cleanest" tank he'd seen in a long, long time and
    for me to continue doing what I have been doing. And that is adding an
    additive occasionally.
    Others have their opinions, but I have seen the facts.
    Bob S.
    Bob S., Feb 4, 2005
  10. Bob S.
    Bob S. Guest
    flushing it
    stirring
    field
    > and clog it up.
    pumped out.
    major
    is
    stuff that
    into your
    > leach piping.
    I'm not that dirty.
    good idea to use:
    is feces.
    dramatically.
    Bob S.
    Bob S., Feb 4, 2005
  1. Robert11
    335
    Suzie-Q
    Jul 16, 2004
  2. Gel
    Septic tank chemical treatments; any good??
    Gel, Jan 15, 2005, in forum: UK Home Improvement
    429
    Blair Malcolm
    Feb 20, 2005
  3. Jim K
    650
    Jim K
    Dec 1, 2010
  4. Bob
    Rid X For Septic Systems ?
    Bob, Aug 7, 2011, in forum: Home Repair
    359
    chaniarts
    Aug 11, 2011
  5. Bob
    283
    Unquestionably Confused
    Jul 9, 2013
Share This Page
