Replacing well pump motor
Discussion in 'Home Repair' started by John, Jun 30, 2005.
  1. John
    John Guest
    Howdy all. I'm replacing a bad well pump motor and have run into a little
    snag in disassembling the old one. The spindle of the old one is attached to
    the "flywheel" (sorry... not sure about exact terminology here!) and I am
    stumped on how to proceed in removing it. It looks like it is basically
    screwed on, but the spindle rotates freely and I have no means of locking it
    down. I think there's some sort of thin lock-nut at the tip of the spindle,
    but I see no way of getting that off. Sorry to be vague here... I can
    provide photos if need be to help further clarify what I'm talking about.
    John, Jun 30, 2005
  2. TURTLE
    TURTLE Guest
    "John" <> wrote in message
    This is turtle.
    Now I can't see it from here but here goes at a guess.
    The Treads your looking at is the pull adjustment to the v shape pulley belt
    slot. To Take it a loose there wll be 1 or 2 allen screws holding the pulley
    head on the shaft. Look for allen screw heads to take it loose from the shaft.
    TURTLE.
    TURTLE, Jul 1, 2005
  3. John
    John Guest
    On Thu, 30 Jun 2005 19:30:05 -0400, TURTLE wrote
    (in article <Te%we.7640$>):
    > news:...
    >> to
    > This is turtle.
    shaft.
    Thanks for the tip. Unfortunately there are no screws (allen or otherwise)
    left in the way. I think I'll just find a shop I can take it to tomorrow
    since I wouldn't get an adequate picture of this to give anyone a better
    look. Thanks for the suggestion though.
    John, Jul 1, 2005
  4. Bob
    Bob Guest
    to
    it
    spindle,
    I rebuilt a spa pump recently. I believe I had to partially remove the
    starter switch on the other end of the motor to find a flat spot on the
    shaft for a wrench to hold the shaft.
    Bob
    Bob, Jul 1, 2005
  5. Guest
    It is threaded on in the same direction that the motor runs. If you
    turn the impeller in the normal direction it will unscrew. Take the
    bell cap off the opposite end and there will be a screwdriver slot or
    flats a wrench can grab to hold the shaft. Wear leather palm gloves
    to grab the impeller.
    , Jul 1, 2005
  1. WoodyElf
    354
    WoodyElf
    Mar 16, 2008
  2. DickB
    replacing a deep well jet pump
    DickB, Jun 29, 2004, in forum: Home Repair
    845
  3. Gunn
    905
  4. The Reverend Natural Light
    Replacing deep well with a deeper well
    The Reverend Natural Light, Jul 25, 2007, in forum: Home Repair
    17
    432
  5. Me2
    206
    Mark Monson
    Jul 12, 2004
