Replacing water intake valve for washing machine
Discussion in 'Misc DIY' started by chemqueries, Feb 22, 2005.
  1. chemqueries
    chemqueries Guest
    Hello. My washing machine won't stop filling with water. The previous
    residents of this house left the water faucets open all the time, and I
    believe the valve may be broken (of course, there may be another
    problem, but this is my first thought). I'd like to replace the valve
    and see whether that helps. Before beginning this project, I will turn
    off the water at the main shut off valve for the whole house. Please
    tell me whether I need to turn off the water heater. It is a gas
    powered water heater. I asked several people at the hardware store, and
    they said that I do not need to turn off the water heater, but I'd like
    to hear your thoughts. Also, if you have any other tips on this
    project, please let me know. Thanks.
  2. Leave the valve alone for now. The problem is in the
    washing machine. There's a solenoid assembly that is
    supposed to stay closed till it gets the voltage to open.
    Go to your local library and get a book on appliance
    repair that includes washing machines. The repair is
    easy, the valve solenoid assembly is not very expensive.
    Don't need to turn off the water heater unless you're
    going to be running water out without it being replaced.
    And you probably need to be calling the "water intake
    valve" the "supply valve" instead.
    Not still living in the apartment building, Catherine?
    "chemqueries" <> wrote in message
    Michael Baugh, Feb 22, 2005
  3. "chemqueries" <> wrote in message
    > . Please
    No reason to turn it off. You're not draining it and no water will be
    flowing through it.
    You may want to check out www.repairclinic.com
    Edwin Pawlowski, Feb 22, 2005
  4. chemqueries
    chemqueries Guest
    > Not still living in the apartment building?
    Hi. Thank you for your help. I will look for a book on appliance
    repair. You are right. I moved away from that dreadful apartment, and
    in the process, I've managed to exchange one set of problems for
    another.
    chemqueries, Feb 23, 2005
  5. chemqueries
    chemqueries Guest
    Ed wrote:
    > You have 2 hoses connected to the back of the machine, they are
    connected to
    > the fill valve.
    > Turn off the water for these 2 hoses. Unplug the machine. Replace the
    valve.
    > What brand is it?>
    > If water comes into the machine while it's turned off or unplugged
    then you
    > need the water valve.
    Hi. Thanks for your help. I should have been more specific. Apparently,
    before I moved in, the hot and cold water knobs controlling the two
    hoses at the back of the machine had been left on or open. The previous
    residents turned the water off by pushing the
    pull-to-start/push-to-stop knob on the machine itself rather than
    turning the hot and cold faucets off. When I tried to use the machine,
    I turned the machine on by pulling up on that knob. I assumed that the
    machine would fill to a certain point, and would then stop filling when
    it was ready to go to the next phase of the cycle, but it just kept
    filling. I turned the hot and cold knobs to the hoses off and the
    machine stopped filling. The brand is Kelvinator.
  6. chemqueries
    chemqueries Guest
    be
    > flowing through it.
    Hi. Thanks for your reply. I checked out the repair clinic link. It's
    very helpful.
  7. chemqueries
    chemqueries Guest
    Thanks to all of you for your replies. This is definitely one of the
    better Internet newsgroups!
  8. chemqueries wrote:
    > connected to
    > > the fill valve.
    the
    > valve.
    > > What brand is it?>
    > then you
    Apparently,
    previous
    machine,
    the
    when
    Something that may help to split up the possible trouble makers...
    http://www.applianceaid.com/washer_overfilling.html
    jeff.
    Appliance Repair Aid
    Appliance Repair Aid, Feb 23, 2005
  9. chemqueries
    chemqueries Guest
    Appliance Repair Aid wrote:
    > > Hi,>
    > http://www.applianceaid.com/washer_overfilling.html>
    > jeff.
    Hi Jeff.
    Thank you for those links!
    chemqueries, Feb 24, 2005
  10. chemqueries
    Guest
    the
    when
    > filling.
    You mean it never went to the agitation cycle even though it was full
    to the point of overflowing? That sounds less like the solenoid valves
    and more like the water level switch, or maybe something else like the
    timer/controller. So let's rule out the valves.
    Begin with the washer empty. Now test the "cold" solenoid valve. Turn
    the hot water hose off at the knob/valve that supplies the hose, and
    turn the cold water knob on. Cause the washer to fill, and cycle the
    temperature knob from "hot" to "cold" and back again a few times. If
    the water alternates between start and then stop completely, you know
    the "cold" solenoid is OK.
    Now test the "hot" solenoid valve. Turn the cold water hose off at the
    knob/valve that supplies the hose, and turn the hot water knob on.
    Cause the washer to fill, and cycle the temperature knob from "hot" to
    "cold" and back again a few times. If the water alternates between
    start and then stop completely, you know the "hot" solenoid is OK.
    Once you have proven the solenoids are the problem or not, you can be
    sure if you need to replace the solenoid valve(s) or look elsewhere.
    %mod%
    , Feb 24, 2005
  11. chemqueries
    stevef Guest
    if your concerned about the water heater, just turn the control to 'pilot'.
    this will prevent the gas heater from burning and you will not have to
    relight the pilot light.
    just don't forget to turn it back on when you finish.
    stevef, Feb 24, 2005
    #11
  1. Dominic
    Replacing washing machine pump
    Dominic, Dec 7, 2003, in forum: Misc DIY
    914
    Dominic
    Dec 10, 2003
  2. Nick
    1,139
    Andrew Gabriel
    Nov 7, 2006
  3. Replies:
    892
  4. conishkee
    977
    conishkee
    Mar 2, 2011
  5. AndyHenderson
    935
    AndyHenderson
    Jan 26, 2013
