Replacing toilet syphon?
Discussion in 'UK DIY' started by D.M.Chapman, Sep 21, 2010.
  1. D.M.Chapman
    D.M.Chapman Guest
    Day off work tomorrow so as I'm the only one at home it seems the ideal
    time to sort out the loo while it's still only hard to flush, and before
    it becomes impossible :)
    Close coupled (I think, cistern sits on the back of the pan with no pipe)
    toilet - pretty standard AFAIK.
    toolstation appear to have two options:
    http://www.toolstation.com/shop/Plumbing/Toilet Fittings/Dual Flush Syphon 8/d20/sd2835/p77721
    a) how do I tell which of the two I need? What is the measurement - height of
    the syphon?
    b) is that the correct thing? It looks like it has a large plastic nut on
    the bottom - how does that work with the cistern? Is there a hollow in the
    bottom that this will be hidden up in?
    c) what's an Epson syphon?
    http://www.toolstation.com/shop/Plumbing/Toilet Fittings/Epson Syphon 8/d20/sd2835/p52164
    c) to fit it I'll need to remove the cistern. I assume there is some seal
    on the bottom that I'll need to replace. Should I get one of
    http://www.toolstation.com/shop/Plumbing/Toilet Fittings/Close Coupling Kit Metal/d20/sd2835/p85615
    Pointers and tips before I start? :)
    Ta,
    Darren
  2. HI Darren
    If you can find a 'real' plumbers' supplies place - then yuo may be able
    to buy just the diaphragm (which is the likely cause of the 'unreliable
    flush' problem.
    I've done this on our two toilets here - process is generally like this...
    - turn off the water that supplies the WC
    - flush the toilet
    - empty the remaining water from the cistern (sponge works well)
    - remove the flush handle and associated mechanism
    - unscrew the two screws at the back of the cistern holding the cistern
    to the wall (often easier said than done - a short stubby screwdriver
    can help)
    - undo the two nuts or wingnuts holding the cistern to the pan
    - lift the cistern off the pan and sit it on the floor on some olf towels
    - undo the large plastic nut, which retains bracket that holds the two
    bolts that secure the cistern to the pan
    - remove the syphon mechanism
    At this point - either take the whole lot to your supplier and get a
    matching replacement, or take out the plastic diaphragm, and get a
    replacement for that.
    Then refit the new / repaired siphon mechanism
    and 'reassembly is the reverse of disassembly' as they used to say in
    the Haynes Manuals...
    You might need a new big foam washer that the big plastic nut fits into
    - or you might be able to re-use the original one
    Hope this helps
    Adrian
    > the syphon?
    > Ta,
    > Darren
    Adrian Brentnall, Sep 21, 2010
  3. D.M.Chapman
    D.M.Chapman Guest
    In article <i7b22v$pf7$-september.org>,
    Adrian Brentnall <> wrote:
    >HI Darren
    >flush' problem.
    I suspect it is - but I'd quite like to replace it with a more efficient
    dual flush syphon if possible. We've been moved onto a water meter so if I've
    got to take it all apart I might as well take the opportunity to fit one
    that's a bit less wasteful!
    >- flush the toilet
    >can help)
    Ah, so this is the thing that toolstation list. Sounds like I shouldn't
    need a new one of those then.
    one of
    http://www.toolstation.com/shop/Plumbing/Washers Fixings/Doughnut CC Kit Washer/d20/sd2703/p39353
    For that price I'll pick one up in case :)
    Darren
  4. HI Darren
    On 21/09/2010 21:07, D.M.Chapman wrote:
    > In article<i7b22v$pf7$-september.org>,
    > Adrian Brentnall<> wrote:
    >> HI Darren
    >> flush' problem.
    Ah - fair enough - our cisterns were dual-flush already ,g>
    >> - flush the toilet
    >> can help)
    All depends how easily the old one comes off - it's a big thing, and
    fairly fragile as well (when you have that big Stilson on the end of it)
    - if it's your only toilet then you might want to get a 'spare
    everything' as insurance...?
    > one of
    Yes - that's the one.
    At that price you could even go for a spare as well !
    Good luck
    Adrian
    > Darren
    > ideal
    > before
    > pipe) toilet - pretty standard AFAIK.
    Close coupled is the terminology. If it has a pipe its 'low level'
    > height of the syphon?
    Its the distance between the base of the cistern & the top. Most are 9.5"
    IME, but do check.
    > nut on the bottom - how does that work with the cistern? Is there a
    > hollow in the bottom that this will be hidden up in?
    The photo shows a siphon as supplied - they come with the bits for close
    coupled and low level.
    No idea :)
    > seal
    You will absolutely, definately, certainly, 100% need a new doughnut washer.
    Don't even think about using the old one.
    For £2.45 you might as well buy the kit - in case stuff has corroded.
    Dave - The Medway Handyman
    www.medwayhandyman.co.uk
    The Medway Handyman, Sep 22, 2010
  6. Adrian Brentnall wrote:
    > HI Darren
    > able to buy just the diaphragm (which is the likely cause of the
    > 'unreliable flush' problem.
    90% of the time it is the diaphragm - B&Q and Wickes sell them. However, it
    might be a split siphon body. Since the parts are cheap & its the same
    labour to do both, change the complete siphon.
    > this...
    > - flush the toilet
    > cistern to the wall (often easier said than done - a short stubby
    > screwdriver can help)
    > towels - undo the large plastic nut, which retains bracket that holds the
    > two
    > into - or you might be able to re-use the original one
    All agreed 100% - but don't whatever you do try to reuse the doughnut
    washer - almost 100% guaranteed to leak.
    >> HI Darren
    > efficient dual flush syphon if possible. We've been moved onto a
    > water meter so if I've got to take it all apart I might as well take
    > the opportunity to fit one that's a bit less wasteful!
    The ones you are looking at are only dual flush in as much as you can set
    them to flush one of two different volumes. If you want a true dual flush
    where you can choose you need something like a Wirquin Jollyflush
    http://www.pro-builder.tv/archiveproducts/heating/bathrooms/wirquin_jollyflush.html
    B&Q sell these as kits so you can replace the flush handle with a push
    button.
  8. D.M.Chapman
    D.M.Chapman Guest
    In article <V0bmo.49$2>,
    Ahhhhhhhhh..... Will go have a look for one of those then. I take it it's
    designed to replace the old style so the button will just fit through the
    handle hole?
    I seem to remember a friend fitting one yonks ago and needing to open up the
    hole a bit - my dremel is the other side of kent so that might be tricky :)
    >button.
    Will investigate this morning, ta :)
    Darren
    D.M.Chapman, Sep 22, 2010
  9. D.M.Chapman
    D.M.Chapman Guest
    In article <XTamo.46$2>,
    Yep, I did :) The old one was certainly knackered!
    ended up fitting one of:
    http://www.screwfix.com/prods/51173...luidmaster-Push-Button-Cable-Dual-Flush-Valve
    B and Q had quite a selection - and none complete. Looks like someone had
    opened every pack and mixed bits up. Screwfix had that one in stock and
    it seems to have good reviews...
    So far so good, I'm not sure the flush has ever been quite so good :)
    "in case stuff has corroded" is a bit of an understatement. One side it took
    me a while (laying on my back) attempting to work out what had happened
    to the wing nut. Seems it had largely rotted away. Hardly any "wings" left
    just a big mess of rust and strangly swollen rubber. Bosch multitool worth
    it's weight for that - just chopped the bloody thing off.
    Thankfully the other side which has even less access was fine and undid ok
    with a little plusgas to help.
    Sorted. Just got a bad back now from laying reaching around the back of
    the bog!
    Cheers all,
    Darren
  10. John
    John Guest
    "D.M.Chapman" <dmc@puffin.> wrote in message
    news:i7d5fn$jc7$-september.org...
    >>washer.
    > took
    > the bog!
    > Cheers all,
    > Darren
    I hope you greased the threads so that next time they dismantle with ease.
    John, Sep 22, 2010
  11. D.M.Chapman
    D.M.Chapman Guest
    In article <3Fumo.536$2>,
    Yep, little bit of copper grease (was all I had around).
    Darren
    D.M.Chapman, Sep 23, 2010
    #11
  12. John
    John Guest
    news:i7ep6h$l4k$-september.org...
    > Darren
    Even better - well done!
    John, Sep 23, 2010
    #12
  13. ggaylmer
    ggaylmer
    Jan 30, 2011
    Toilet flush
    Thanks everyone for the very helpful info on solving my toilet flush problems and replacing traditional with Screwfix Fluidmaster dual flush cable system.
    Chris.
    ggaylmer, May 20, 2012
    #13
  1. mackem
    Toilet cistern syphon/overflow
    mackem, Oct 12, 2004, in forum: Misc DIY
    9
    936
    Bob Mannix
    Oct 15, 2004
  2. portchey
    Dudley Toilet Syphon
    portchey, Jan 10, 2005, in forum: Misc DIY
    1,290
  3. Homer2911
    Diaphragm for toilet syphon
    Homer2911, Nov 7, 2005, in forum: Misc DIY
    1,639
  4. toilet syphon renewal???
    , Jan 17, 2006, in forum: Misc DIY
    748
  5. Dr Zoidberg
    Replacing two part Syphon?
    Dr Zoidberg, Nov 14, 2010, in forum: UK DIY
    294
    The Medway Handyman
    Nov 14, 2010
Share This Page
