Replacing indirect cylinder
Discussion in 'UK DIY' started by Tom, Aug 29, 2004.
  1. Tom
    Tom Guest
    I'm intending to replace old existing cylinder with new quick recovery type
    to reduce boiler cycling and to provide more hot water in peak periods, I
    also need to modify pipe layout behind it to connect a shower.
    The existing cylinder lives in an airing cupboard but is supported some 2ft
    above the suspended floor of the bungalow, I propose to locate the new
    cylinder on the floor giving me more space above it. The cistern is in the
    loft space above, the bottom of which is approx 5' above top of existing
    cylinder.
    I cannot think of a reason why I should not do this as water flows should
    not be affected, however I have a nagging doubt, have I missed something
    here? why would the original plumber have gone to the trouble to build a
    load bearing platform to support it (400lbs?)
    Regards
    Tom
    Tom, Aug 29, 2004
  2. Tom
    Set Square Guest
    > recovery type to reduce boiler cycling and to provide more hot water
    > in peak periods, I also need to modify pipe layout behind it to
    > connect a shower.
    > some 2ft above the suspended floor of the bungalow, I propose to
    > locate the new cylinder on the floor giving me more space above it.
    > The cistern is in the loft space above, the bottom of which is approx
    > 5' above top of existing cylinder.
    > should not be affected, however I have a nagging doubt, have I missed
    > something here? why would the original plumber have gone to the
    > trouble to build a load bearing platform to support it (400lbs?)
    > Regards
    > Tom
    I can't think of any technical reason not to put it at floor level. Perhaps
    the plumber didn't like bending or kneeling when connecting the pipes?!
    Cheers,
    Set Square
    ______
    Please reply to newsgroup. Reply address is invalid.
    Set Square, Aug 29, 2004
  3. Tom
    mike ring Guest
    "Tom" <> wrote in
    news::
    > type to reduce boiler cycling and to provide more hot water in peak
    > periods, I also need to modify pipe layout behind it to connect a
    > shower. The existing cylinder lives in an airing cupboard but is
    > supported some 2ft above the suspended floor of the bungalow, I
    > propose to locate the new cylinder on the floor giving me more space
    > above it. The cistern is in the loft space above, the bottom of which
    > is approx 5' above top of existing cylinder.
    > Regards
    > Tom
    I can't think why, I've just replaced my old cylinder with a Q/recovery
    and made room for another shelf even though it was nearly on the floor,
    in a situation just like yours.
    (As I didn't know if there was a reason for it not to be on the floor,
    Ive put the new one on wood blocks, too).
    The only decider on pressure is the cold water tank, which I raised last
    summer, with no noticeable difference.
    In addition, as my DHW has pathetic pressure, I've installed a boost
    pump, which requires a good flow from the cold tank, so I put in a new,
    fairly straight run with a full bore lever valve to shut it off. This
    was very good, I've had it closed for ages while working below, and not
    a drop came out, but when I opened it the rush was scary, and it easily
    beat my cold water fill!
    The jury's out at the moment - I'm just sorting out the wiring, as I
    changed to zone valves, and the original wiring is a real cat's cradle,
    but I'll let the world know if it's a success.
    Good luck with yours, but I'd have started earlier; well I did, but I'm
    slow and ignorant.
    mike
    mike ring, Aug 29, 2004
  1. Frank+Shirley
    Ariston Contract 210 Indirect Cylinder
    Frank+Shirley, May 3, 2004, in forum: UK DIY
    749
    Andy Hall
    May 3, 2004
  2. Replies:
    633
    Adrian Brentnall
    Dec 10, 2004
  3. Russ
    12
    679
    John Stumbles
    Jan 5, 2006
  4. Edward W. Thompson
    Replacing an Indirect Hot Water Cylinder
    Edward W. Thompson, Jan 15, 2006, in forum: UK DIY
    577
    Edward W. Thompson
    Jan 16, 2006
  5. BraileTrail
    27
    962
    Doctor Drivel
    Jan 8, 2010
