removing insulating foam from clothing
Discussion in 'Home Repair' started by Aye Smith, Feb 3, 2004.
  1. Aye Smith
    Aye Smith Guest
    Hi crew,
    My daughter was helping me install a window and got some of the insulating
    foam on her fleece shirt. It's the Great Stuff kind, comes in a can. Any
    one know a way of getting that stuff off? I guess a chemical but nothing I
    have seems to work. Thanks for any tips.
    AS
  2. Aye Smith <me@home> wrote in message news:<Xns948469EA3E9E5antique10@216.251.47.206>...
    > Hi crew,
    It should say somewhere on the can, but I believe acetone dissolves it.
    Unfortunately, acetone also harms polyester, so if it's a polyester
    fleece you may be out of luck. (Acetone won't dissolve cured polyester,
    but it can still soften/"melt" it to some degree.) A cotton or wool
    fleece should be relatively safe to treat this way, though.
    You can always try removing it by "mechanical" means (scraping, cutting);
    hopefully it's not so deeply embedded in the fleece that this is ruled out.
    Y.
    Yasashii Arbaito, Feb 3, 2004
  3. Aye Smith
    Joe Guest
    On 3 Feb 2004 11:39:18 -0800, (Yasashii Arbaito)
    >> Hi crew,
    Scraping a pair of jeans with a blade from a utility knife worked for
    me once. The scraping took off a slight bit of the jean material
    though. In your case it might leave a bald spot on the garment but it
    might be the only option.
    Joe
    Joe, Feb 3, 2004
  4. He's right. Just throw it away, next time wear old clothes.
    "montana" <> wrote in message
    > In article <Xns948469EA3E9E5antique10@216.251.47.206>,
    > Aye Smith <me@home> wrote:
    > > Hi crew,
    insulating
    I
    > > AS
    > Sounds all too familiar to me. Acetone is supposed to work, but didn't.
    > Nothing I tried worked and we have a lot of different things to try. I
    > liked that shirt, but it's a rag now.
    > Luckily, the haircut I had to get went better...
    Tim or Marty Shephard, Feb 9, 2004
  1. The Reid
    leather dye on clothing
    The Reid, Aug 19, 2006, in forum: UK DIY
    403
    The Reid
    Aug 20, 2006
  2. T i m
    23
    592
    T i m
    Nov 28, 2008
  3. Jamie Decker
    Clothing dryer repair?
    Jamie Decker, Jul 12, 2003, in forum: Home Repair
    372
  4. Alexander Galkin
    How to remove chewing gum from clothing
    Alexander Galkin, Aug 10, 2004, in forum: Home Repair
    8
    339
    chuck yerkes
    Aug 11, 2004
  5. Nicole
    Directory of plus size clothing
    Nicole, Aug 11, 2006, in forum: Home Repair
    310
    Nicole
    Aug 11, 2006
