Remove/replace garage door bottom roller?
Discussion in 'Misc DIY' started by Dick Yuknavech, Aug 9, 2005.
  1. Hi all.
    I want to remove. for cleaning or replacing, the bottom roller on my
    garage door. There is no problem with removing the brackets on the other
    rollers, but on a torsion-spring door the bracket for the bottom roller
    is hooked to that cable with a grillion pounds of tension in it.
    Does anybody know what the trick is?
    TIA
    Dick Yuknavech, amateur DIY guy.
  2. Dick Yuknavech
    Guest
    On Tue, 09 Aug 2005 15:39:32 GMT, Dick Yuknavech <>
    wrote:
    >Hi all.
    >TIA
    When the door is up the tension should be released. My cables hang
    slack when the door is up
    , Aug 9, 2005
  3. On Tue, 09 Aug 2005 12:22:09 -0400, wrote in
    alt.home.repair:
    >>TIA
    Hmmm. I'll have to meditate on that for a while. My cables are still
    under some tension in the full-up position. They're very short at that
    time, so it's difficult to guesstimate how heavy the tension is.
    I just recalled - a while back I loosened the lock bolts on one of the
    pulleys to even out the door. I bet I can do that (on one side at a
    time!) to replace those rollers. I'll have to ponder that.
    Thanks for the reply.
    Why put fault tolerance in the OS, when it's already built into the
    User?
    Dick Yuknavech
  4. Dick Yuknavech
    Guest
    On Tue, 09 Aug 2005 17:33:08 GMT, Dick Yuknavech
    >alt.home.repair:
    >>>TIA
    Lift the door further than the regular open position. Jam a 2x4 under
    it to keep it up.
    , Aug 10, 2005
  1. Barley Twist
    1,652
    Andy Dingley
    Nov 3, 2003
  2. PoP
    Garage Door - Roller
    PoP, Nov 23, 2003, in forum: Misc DIY
    431
  3. Spike
    Insulated Garage Roller Door..
    Spike, Sep 8, 2006, in forum: Misc DIY
    388
    Andy Hall
    Sep 9, 2006
  4. Replies:
    9
    1,078
    C & E
    Feb 3, 2007
  5. Sprayer versus roller versus power roller
    , Jan 27, 2007, in forum: Building Construction
    377
    C & E
    Feb 3, 2007
