Relative density of topsoil?
Discussion in 'UK DIY' started by al, Aug 18, 2003.
  1. al
    al Guest
    Anyone know? Or more specifically, how much do one of those cubic meter
    bags weigh?
    a
    al, Aug 18, 2003
  2. al
    Rick Hughes Guest
    "al" <{ask_me}@blueyonder.co.uk> wrote in message
    news:Wh%%a.4068$...
    > bags weigh?
    Here is a page to work it out - http://home.iitk.ac.in/~madhav/expt6.html
    if that helps.
    I have figures for sand, hardcore, cement etc. ... but not for soil.
    My guess for damp typical sandy soil you would not be too far out if you
    went at 1 tonne per m3
    Wet or clay would make the biggest difference, the latter as there are then
    no air spaces between grains.
    Rick
    Rick Hughes, Aug 18, 2003
  3. al
    L Reid Guest
    "The Natural Philosopher" <> wrote in message
    > > news:Wh%%a.4068$...
    > >>bags weigh?
    > > if that helps.
    > No, its more than that - between 1.5 and 2.5 at a guess.
    then
    > Indeed.
    > > Rick
    From Perry's Chemical Engineers handbook:
    Substance Sp. gr Aver Weight lb/cu.ft.
    Clay, dry 1.0 63
    damp plastic 1.76 110
    Earth dry loose 1.2 76
    dry, packed 1.5 95
    moist, loose 1.3 78
    moist, packed 1.6 96
    mud, flowing 1.7 108
    mud, packed 1.8 115
    HTH.
    L Reid, Aug 18, 2003
  4. al
    Rick Hughes Guest
    > > news:Wh%%a.4068$...
    > >>bags weigh?
    > > if that helps.
    From the figures by L.Reid -
    so if I follow that :-
    1cu m = 35.3146666 cu ft
    1 cubic foot = 76 Lb
    dry soil therefore = 76 x 35.3146666
    cu m = 2684 Lb
    2684 Lb = 1.2 metric tonne
    which when you take my guestimate of 1 tonne ... that is not bad.
    Rick
  5. al
    al Guest
    "Rick Hughes" <> wrote in message
    news:bhre4k$sqg$...
    > cu m = 2684 Lb
    > Rick
    Thanks for all your answers - some of it was slightly damp at the side from
    contact, so I'll take 1.5 to 1.75 tonnes as being close enough per bag :eek:)
    Just wanted to know how much damn work I did over the weekend - shifted two
    of the bags by hand evenly across a 40m/2 area! At least it was a little
    cooler than the weekend before ....
    a
    al, Aug 19, 2003
  6. al
    Rick Hughes Guest
    > > news:bhre4k$sqg$...
    > >> cu m = 2684 Lb
    > >>Rick
    from
    :eek:)
    two
    little
    > A good Irishman can shovel barrow and rake 30 tons in a day.
    having had several 22 tonne loads of top soil - and had to shovel & barrow
    away one of them - I only managed 22 tonne in a day and a half ....
    30 tonnes in a day would be way past my best effort.
    Had another 22 tonne on Friday (have to take it when I can get it) .. at
    least got this tipped out of the way so I don't have to barrow it now.
    Will have to move & level all of it ( will be 132 tonne in all) but will
    probably hire a skid steer loader for a weekend.
    Rick
    Rick Hughes, Aug 19, 2003
  7. al
    al Guest
    > I've managed about a ton on a good day :)
    > Or 60 tons with a digger :)
    Well, that I am, but not that good ;P
    The roughly 3 tonnes took me two days to spread and rake. But then I was
    painting in between when the going got too hot!
    Out of interest, is there a cheap way of buying loads of topsoil? Quality
    doesn't matter as I'm building up a base to cover over with weed sheets and
    woodchip, but "deliverability" does as it's to the back of my house down a
    laneway that a medium sized truck can fit (crane lifts over my back wall
    thankfully!). I've paid almost £100 for my two cubic meter bags.
    a
    al, Aug 19, 2003
  8. al
    Rick Hughes Guest
    > > news:...
    > >>>news:Wh%%a.4068$...
    meter
    > >>>>bags weigh?
    > >>>if that helps.
    you
    > > cu m = 2684 Lb
    > I can't believe you just did that.
    why ?
    > Try Sp Gr 1.2
    > 1 cu meter of water -= 1 tomnne.
    > Therefore 1 cu meter of material at sp gr 1.2 weighs...GASP...1.2 tonnes
    So the sums are the same.
    > Mmm. I think that my guesstomate of 1.5-2.5 was a bit nearer.
    well with 30 degree temp - all the soil in my area is well dry .... for
    once.
  9. al
    Rick Hughes Guest
    news:l5u0b.287$...
    > news:...
    and
    I pay £100 cash per 22 tonne load ..... found a driver who hauls this for
    big companies, he takes the last load 'home with him'
    I will only take good stuff, so get a phone call at short notice ... "Iv'e
    got a load on do you want it now'
    One he dropped in the drive - hence the barrowing it for a day and a half !
    Simplest way is to look at somebody hauling it and ask them if they sell it
    for cash - most drivers don't own the stuff and always after cash.
    Wherever a new development starts up - they sell off the top soil to
    contractor, who typically gets in sub-contract owner drivers .... these are
    the guys who will sell it on.
    A new development in my area is about to start with the taking off the top
    soil from a playing fields complex of something like 30 acres to build a new
    stadium - hoping to get some soil form that.
    Rick
    > news:...
    I bought some (20 tons) for £13 a ton, and had the local farmer dump a
    trailer full or three for free.
    Trouble is getting the tip lorry to where you want it.
    Mini diggers and dumpers will still set you back £100 a day, which often negates the lower cost of bulk buying.
    > a
    The Natural Philosopher, Aug 20, 2003
  1. John
    High Density Polyethylene
    John, Jun 3, 2004, in forum: UK DIY
    591
    N. Thornton
    Jun 4, 2004
  2. Lobster
    3,544
  3. John Hilton
    Density of MDF, chipboard and WBP ply?
    John Hilton, Nov 14, 2004, in forum: UK Home Improvement
    5,303
    Bob Hill
    Nov 18, 2004
  4. Zen83237
    Density of concrete
    Zen83237, May 1, 2009, in forum: Misc DIY
    671
    May 2, 2009
  5. Roarmeister
    MDF/Medium Density Fibreboard
    Roarmeister, Jan 27, 2005, in forum: Building Construction
    321
    Tecumseh
    Jan 27, 2005
