Recharging a Dead Dehumidifier
Discussion in 'Home Repair' started by frank1492, Jun 13, 2005.
  1. frank1492
    frank1492 Guest
    My three-year old Goldstar no longer works. The coils are cool, but
    never cold enough to permit condensation.
    Is it practical to have the unit recharged, or is this cost
    prohibitive? And, if fixed, will it last?
    I have already purchaed a new Haier and will start using unless
    you guys recommend otherwise.
    Thanks for your help!
    Frank
    > Frank
    Have you checked your warranty? Some will have a 5 year system warranty
    ( gas charge, compressor ) on those items.
    jeff.
    Appliance Repair Aid
    http://www.applianceaid.com/
    Appliance Repair Aid, Jun 13, 2005
  3. HeatMan
    HeatMan Guest
    "Appliance Repair Aid" <> wrote in message
    > > Frank
    > Hi,
    From what I've seen, the 5 year warranty is on the can only....
    > jeff.
    HeatMan, Jun 13, 2005
  4. Guest
    If it's like a lot of other things, it's only economically feasable to
    fix if you can fix it yourself.
    , Jun 13, 2005
  5. Dissemble the unit and clean it, thoroughly.
    Christopher A. Young
    Learn more about Jesus
    www.lds.org
    www.mormons.com
    "frank1492" <> wrote in message
    Frank
    Stormin Mormon, Jun 13, 2005
  6. bubba
    bubba Guest
    > prohibitive?
    this unit cannot be "recharged" in the same sense as recharging your car or
    home A/C
    like a window A/C unit, it does not have ports to screw on a set of charging
    hoses
    generally speaking, low freon is not a problem with a dehumidifier, they are
    not prone to leaking refrigerant
    problem is more likely a dirty or mashed condenser or evaporator coil, or a
    defective thermostatic switch, or other issue, not low refrigerant
    if it did have a leak, and you did weld on a charging port and
    evacuate/recharge, it would only "last" if you also fix the source of the
    leak
    generally speaking, a dehumidifier that is leaking refrigerant is very rare,
    and also not worth the hassle of repairing and recharging, for most people.
    but I believe your problem lies elsewhere, as noted above, which ~would~ be
    worth fixing, and that fix will "last"
    bubba, Jun 13, 2005
  7. G Henslee
    G Henslee Guest
    Hey, just like they have to do Mormons when they wise up and quit the cult.
    Learn the Truth about Mormonism
    http://www.eaec.org/cults/mormons.htm
    G Henslee, Jun 13, 2005
  8. frank1492
    frank1492 Guest
    or a
    defective thermostatic switch, or other issue, not low refrigerant.
    Comments:
    The thermostat works, as the compressor does seem to try to turn on.
    (A short "buzz" is heard when it kicks in.) After the buzz, though, it
    does not seem that the compressor is running, and the coils don't
    get cold..
    If by "mashed" you mean "crushed", no chance. Dirty I doubt also,
    as the filter was very clean. Also, it suddenly stopped working
    (nothing this spring, fine in the fall.)
    Does this help further pinpoint anything??
    Thanks very much!
    On Mon, 13 Jun 2005 13:18:59 -0400, "bubba" <>
    >> prohibitive?
    >home A/C
    >hoses
    >leak
    frank1492, Jun 14, 2005
  9. Re: Recharging an Antimormon's sagging energy level
    Your job is getting harder by the day. We have about 300,000 convert
    baptisms a year, and I can't remember the total church membership, but it's
    about 11 million. Might be 12 by now.
    www.lds.org
    www.mormons.com
    "G Henslee" <> wrote in message
    Stormin Mormon, Jun 14, 2005
  10. Well, that changes everything! All of our previous advice is irrelevant,
    now.
    Now that you've changed the symptoms, the diagnosis will of course change.
    For your latest list of symptoms, you have a starting problem wtih the
    compressor. Can be either not getting enough power, or start components
    problem. On many dehum, it's not dificult for a refrigeration person to wire
    in a hard start kit for the compressor.
    Please remit a second $48.50 for the second diagnosis. First diagnostic fee
    will not be refunded.
    www.lds.org
    www.mormons.com
    Comments:
    get cold..
    Thanks very much!
  11. Doug Miller
    Doug Miller Guest
    You're all the way up to one percent of the membership of the Catholic Church.
    Wow!
    Regards,
    Doug Miller (alphageek at milmac dot com)
    Nobody ever left footprints in the sands of time by sitting on his butt.
    And who wants to leave buttprints in the sands of time?
    Doug Miller, Jun 14, 2005
    #11
  12. G Henslee
    G Henslee Guest
    What job? I don't have to convince people to believe lies. You do...
    Learn The Truth About Mormons
    http://www.carm.org/mormon.htm
    G Henslee, Jun 15, 2005
    #12
  1. Zax
    262
    BillR
    Aug 29, 2003
  2. Hank
    35
    888
    Dave Plowman (News)
    Mar 11, 2007
  3. Andrew
    341
    Guest
    Jul 14, 2007
  4. Jim K
    33
    752
    Jim K
    Nov 15, 2011
  5. Alaa Ramahi
    414
    Alaa Ramahi
    Jun 17, 2012
