Re: urgent - heating pumping over problem
Discussion in 'UK DIY' started by BB king, Jan 15, 2004.
  1. BB king
    BB king Guest
    > Now customer has hot water & central heating. However I noticed that the
    > vent pipe for the central heating is constantly running - pumping over,
    the
    > water in the header tank roasting. This had been going on all day, and
    > condensation now dripping off roof in attic. What could cause this to
    happen
    > to a previously working system?
    > The vent (22mm) and feed (15mm) pipes connect together within 4" of each
    > other at the inlet to the pump. Although the vent is pumping over, the
    tank
    > is not filling, so the water going in to the tank through the vent must be
    > leaving through the feed pipe. It's as if the connection between the two
    > pipes at the pump inlet is blocked... only thing I can think of, but
    doesn't
    > seem likely.
    > Please help!!
    > Cheers
    > Colin
    There is a good chance that the cold feed pipe is blocked up. Check the f&e
    tank to see if there is sludge on the bottom, if so, there is a good chance
    it will be blocked further down too.
    I remember finding a similar problem to this, we replaced the said pipe and
    hey presto !! bob's me grannie !!!!:eek:)
    mike
  2. "BB king" <robowen(no spam)1@(no spam)v21.me.uk> wrote in message
    > the
    > happen
    > tank
    be
    > doesn't
    > > seem likely.
    > > Please help!!
    > > Cheers
    > > Colin
    f&e
    chance
    That wouldn't cause the reported problem though: there'd be nowhere for the
    water being pumped over to go.
    I encountered this problem on a system which (a) had the pump set at max -
    turning it down stopped it pumping over (b) the opening on the vent pipe was
    just an inch or so above the level of water in the header tank, which meant
    that as soon as pumping over started it would only require a pressure
    difference of 1" WG or so to maintain the flow. This was sorted by
    shortening the downturned part of the vent pipe and lowering the level of
    water in the tank.
    John Stumbles
    John Stumbles, Jan 16, 2004
  1. Ragworm The Abominable
    Pumping Over on HW Only - Modulating Boiler
    Ragworm The Abominable, Jan 19, 2006, in forum: UK DIY
    12
    600
    Jan 22, 2006
  2. Replies:
    351
  3. Pumping over
    , Sep 5, 2006, in forum: UK DIY
    12
    606
    Andy Hall
    Sep 6, 2006
  4. Pumping over-report
    , Sep 7, 2006, in forum: UK DIY
    293
  5. Replies:
    204
