Re: Shower door lubrication?
Discussion in 'Misc DIY' started by Cash, Nov 23, 2008.
  1. Cash
    Cash Guest
    Muddymike wrote:
    > We have a sliding shower door, only 3 years old which does not slide
    > nicely. It is a simple aluminium runner affair with no rollers. At
    > times it screeches and at best it scroops. If we get hold of the door
    > above half way up it also jams when opened. Gripping the handle below
    > the half way point is the only way to ensure it does not jam.
    > I tried lubricating the runners with silicon grease but this results
    > in greasy black gunge running down the glass. SWMBO want me to change
    > the doors but as they are tiled in with the tiles covering the screws
    > that hold it together this will mean major work.
    > Any suggestions of a lubricant that will make them run more smoothly
    > and not produce the black greasy stains?
    > You can see the offending doors here,
    > http://share.ovi.com/media/Muddymike.Housechanges/Muddymike.10480?sort=5
    > Mike
    Mike,
    Is there any adjusting mechanisms on the door to lift it off the bottom
    guide rail.
    Cash
    Cash, Nov 23, 2008
  2. Cash
    BigWallop Guest
    "Cash" <.............\\@...............//.com> wrote in message
    > > Mike
    > Mike,
    > guide rail.
    > Cash
    That was my thought too, but these doors should have nylon feet that allow
    it to slide in the runner. I wonder if they have slid to one end, or even
    fallen out and are lying about in the guide rail somewhere.
    A metal to metal to runner will never work. Honest.
    BigWallop, Nov 23, 2008
  3. Cash
    Xenon Guest
    Have you tried 'KY' jelly
    Has stopped many things sqeaking ;-}
    Xenon, Nov 23, 2008
  4. Cash
    Xenon Guest
    or even squeaking
    "Xenon" <> wrote in message
    news:49299486$0$1348$...
    Xenon, Nov 23, 2008
  5. Cash
    BigWallop Guest
    "Muddymike" <> wrote in message
    > "BigWallop" <> wrote in message
    > news:8XfWk.91792$...
    > > news:...
    > >> > Mike
    > >> Mike,
    > >> guide rail.
    > >> Cash
    allow
    even
    > The action has been rough right from new, I did wonder if the builder that
    > installed the door forgot to put in some kind of nylon runners. The white
    > coating on the bottom runner has now worn off leaving bare aluminium and
    the
    > action is worse than ever. The annoying thing is I can't even take the dam
    > thing out without destroying the tiles, and probably a lot more as it
    looks
    > like the plaster board under the tiles also went in after the door frame.
    > Mike
    Maybe a piece of plastic, cut to fit inside the bottom runner, would help.
    I'm thinking of the lid from cable trunk or the like. Measure the inside
    length and width and find a find a piece of trunk lid that will fit tight.
    Lift the front edge (open edge) of the door and slide the plastic
    underneath, then tap it down into the runner.
    It might help the sliding action and it will certainly protect the runner
    and door from more damage. And, call the fitter and ask if he left anything
    out of the cubicle. Maybe because he didn't know what it was for.
    Good luck with it.
  6. Cash
    BigWallop Guest
    It doesn't stop her indoors from squeaking. No matter how much we use. :)
  7. Cash
    Abbot Guest
    >> >> > door
    >> >> > below
    Is it possible to use a couple of wheels about 1" dia. (acquired from a
    kiddies toy, tyres removed) as runners on the top rail of the shower
    compartment?
    A cranked bit of aluminium (or even waterproofed wood) to hang the sliding
    door to wheels?
    Regards,
    Abbot, Nov 23, 2008
  8. Cash
    gazz Guest
    > The insert would have to be very thin as the door only lifts about 2mm.
    > Also the bottom rail of the door it "T" shaped with the leg of the "T"
    > guiding the door along a slot in the track. The top is the same but
    > reversed. I guess it was just a crap door.
    it certianly sounds like the wheels the door slides on are either missing
    from when installed, or have worn down/broken, and the door is now trying to
    slide on the runner.
    had a wheel break on a patio door once, and it sounded just like you are
    describing this shower doors action.
    might be time to bite the bullet and take the damn thing out, going to be a
    bit of work, but at least you will know what's wrong and can fix it, that's
    gotta be worth the reduction in ear bashing from the wife every time she
    uses the door :)
    gazz, Nov 25, 2008
  1. Chubb lock lubrication
    , Jan 6, 2004, in forum: UK DIY
    764
  2. John
    529
  3. trinaz
    Genie garage door lubrication ?
    trinaz, Nov 24, 2003, in forum: Misc DIY
    1,121
    jmagerl
    Nov 24, 2003
  4. toller
    lubrication for garage door?
    toller, Nov 15, 2004, in forum: Misc DIY
    585
    Doug Kanter
    Nov 15, 2004
  5. newman
    newman, Sep 21, 2007, in forum: Misc DIY
    686
