Re: Schreiber Units - Replacement Doors
Discussion in 'Misc DIY' started by The Medway Handyman, Apr 16, 2006.
  1. wrote:
    > In my kitchen there are some Schreiber Kitchen Units. I am thinking
    > of replacing door and drawer fronts. Are such units a standard size;
    > are the hinge locations a standard; I am told that you can only get
    > Schreiber replacements from MFI - is this so?
    > Basically will it be straightforward to do the replacements - what are
    > the pitfalls - am not a diy expert as such ;-)
    I've just spent 2 days replacing door/drawer fronts for a customer. I also
    had to replace the worktops which had cutouts for sinks & hob units, so not
    all of that time was door/drawer replacement.
    They ordered the door/drawer fronts from Screwfix. I called Sxrewfix
    technical dept to ask if the hinge holes were to some kind of 'industry
    standard' spacing - and they had no idea whatsoever.
    Drawer fronts were dead simple, Just screws and spacers to get the alignment
    right as the drawers in this case were 4 sided 'boxes'. However, in my
    kitchen at home the drawers are three sided 'boxes' with the fronts held on
    by cam lock fittings. This would have needed either brackets or a
    considerable amount of accurate hole drilling - a huge amount of extra time.
    The Screwfix doors were pre drilled for the hinge holes. They didn't line
    up with the existing hinge spacing. In this case I was lucky, It worked out
    that the carcass part of the hinges just needed to be swivelled up or down.
    In other words, the top euroscrew on the top hinge plate had to be removed,
    allowing the hinge bracket to swing down, and a new hole drilled. The top
    euroscrew on the bottom hinge plate had to be removed, allowing the hinge to
    swing up and a new hole to be drilled. Could have been a lot worse.
    There are suppliers on the web (Google for details) who will supply
    door/drawer fronts pre drilled exactly to match the existing door hinge
    spacing - in future I would definately use them - huge time saver.
    Most kitchen door/drawer fronts are standard sizes, but the internet
    suppliers will make any size you want. In this recent case, a panel under a
    built in oven was the length of a drawer front, but too wide. Not a problem
    if you have a table saw and can rip it to width.
    Take a look at the link on my 'Carpentry' page to Didcot Drawers for more
    info.
    Dave
    The Medway Handyman
    www.medwayhandyman.co.uk
    01634 717930
    07850 597257
  1. Replies:
    10
    581
  2. michaelangelo7
    Replacement doors for kitchen units
    michaelangelo7, Feb 17, 2005, in forum: Misc DIY
    250
    Rob Morley
    Feb 18, 2005
  3. Thomarse
    16
    868
    Ed Sirett
    Jul 20, 2007
  4. Peter Rance
    Schreiber Wardrobe
    Peter Rance, Aug 13, 2003, in forum: UK Home Improvement
    765
  5. jamma-plusser
    946
    jamma-plusser
    Jul 13, 2009
Share This Page
