Re: Internal door handle, deadlatch does not fully retract
Discussion in 'Misc DIY' started by Falco, Aug 20, 2009.
  1. Falco
    Falco Guest
    Devany wrote:
    > On an internal door, the deadlatch does not fully retract into the
    > door when the handle is turned. It protrudes about 5mm and fouls the
    > strikeplate when trying to open the door.
    > There are several of these in my house which are starting to get right
    > on my nerves.
    > What is the problem?
    They are simply worn.
    > I guess I could chisel out the strikeplate, but I know I'm crap at
    > doing that. Shouldn't the deadlatch retract fully? I can't see that
    > wear and tear would affect it that much. Would a new handle fix it?
    Don't bother digging the chisel out of the tool box, just find out whether
    it's the handles or latch that's worn and change the offending item - or
    both handles and latch if you wish.
    Falco
    Falco, Aug 20, 2009
  2. Falco
    Guest
    > > on my nerves.
    I investigated a worn latch like this just a few days ago. The wear
    was where the 'rotating bit' sits in the 'fixed bit' if you see what I
    mean. It doesn't have proper bearings, there's just a round hole in
    the metalwork of the innards where the 'rotating bit' through which
    the square shaft for the handle runs. The round hole was far from
    round after many years of door opening. There's not a lot one can do
    to repair it and I guess they're not very expensive anyway.
    Chris Green
    , Aug 20, 2009
  3. Falco
    John Guest
    <> wrote in message
    news:h6k4vi$pc4$-september.org...
    >> > on my nerves.
    >> whether
    > Chris Green
    Also the square hole in the handle and in the innards becomes a sloppy fit
    causing the handle not to fully retract the catch. Don't touch the striker -
    it is innocent!
    Buy new catch sets and possibly handles - grease well when assembling to
    reduce wear in the future
    John, Aug 20, 2009
  4. On Thu, 20 Aug 2009 19:04:09 +0100, "Falco"
    >> on my nerves.
    It'll be the mortice latch mechanism which has worn. They are made of
    piss poor cast metal and not lubricated during manufacture.
    Screwfix sells them very cheaply and cheaper still in 10 off
    quantities, also the sheds have them.
    Unfortunately at some time in the recent past they went from Imperial
    to Metric, they look the same but by golly they're not the same so
    most probably you'll still need to get it out (your chisel, that is)
    so best do them all whilst you're at it.
    Generally the problem doesn't result in people getting stuck behind a
    locked door, but a similar problem on a bathroom lockset has resulted
    in people getting locked in the loo three times here.
    Derek
    Derek Geldard, Aug 20, 2009
    >>> right on my nerves.
    >> whether it's the handles or latch that's worn and change the
    >> offending item - or both handles and latch if you wish.
    Aha. I wondered why some just don't quite fit - that makes perfect sense.
    Dave - The Medway Handyman
    www.medwayhandyman.co.uk
    The Medway Handyman, Aug 20, 2009
  6. In article <h6k36r$7b7$>,
    "Falco" <falco@diilly-daally....invalid.com> writes:
    >> on my nerves.
    Be careful as you unscrew the handles, and again when you're removing
    the latch. Often, a pile of oily metal filings drops out, and it's
    a real bugger to get them out of a light coloured carpet. Slide a
    piece of newspaper under the door to protect any flooring from this.
    Andrew Gabriel
    [email address is not usable -- followup in the newsgroup]
    Andrew Gabriel, Aug 23, 2009
  1. Replies:
    8
    754
  2. Replies:
    405
  3. Door deadlatch sticks open
    , Dec 3, 2008, in forum: Misc DIY
    680
  4. NT
    690
  5. paulfoel
    10
    631
    The Medway Handyman
    Apr 25, 2013
