Re: Integrated Electric Oven Wiring Diagram
Discussion in 'UK DIY' started by Tabby, Mar 23, 2011.
  1. Tabby
    Tabby Guest
    On Mar 23, 6:26 pm, "TMC" <> wrote:
    > Hi
    > I have been asked to look at an integrated double oven where someone has
    > tried to replace the thermostat on the main oven
    > I have not seen the oven yet
    > Having taken off several wires without marking them they have tried to put
    > them back and neither of the ovens now work
    > The oven is a Diplomat APL4426
    > Anyone know where I can get a wiring diagram for this or how I might work
    > out the connections otherwise
    > I have also posted on the free.uk appliance repair site but it does not look
    > very active
    > Regards
    > Tony
    Just map it with a multimeter, they're only simple circuits.
    NT
    Tabby, Mar 23, 2011
  2. Tabby
    robgraham Guest
    > > Hi
    > > I have also posted on the free.uk appliance repair site but it does notlook
    > > very active
    > > Regards
    > > Tony
    > NT
    Well that may be true but I was thrown by the wiring configuration of
    an AEG oven. It started to trip the RCD when switched from OFF to its
    first position OVEN LIGHT. So it's the oven light - or at least the
    wiring or the holder. But no, disconnected both completely and the
    trip still occurred. For some odd reason it was wired in such a
    manner that in this position 1 of the selector switch the neutral was
    fed to the oven fan - it was effective in detecting the fault to
    ground via the RCD before line was applied in Position 4, but it was
    not what one would expect.
    Rob
    robgraham, Mar 24, 2011
  1. spamlet
    560
    spamlet
    Apr 9, 2008
  2. David Nebenzahl
    Need wiring diagram for electric drill
    David Nebenzahl, Dec 1, 2006, in forum: Misc DIY
    18
    2,109
    propman
    Dec 4, 2006
  3. briwy
    Oven wiring diagram
    briwy, Nov 18, 2006, in forum: Misc DIY
    1,686
    briwy
    Nov 30, 2006
  4. Replies:
    985
    ftwhd
    Aug 21, 2007
  5. Ricky
    8
    443
