Re: Hooking Up Doorbell Via Homerun Closet Need Help
Discussion in 'Misc DIY' started by Mike rock, Sep 14, 2009.
  1. Mike rock
    Mike rock Guest
    On Sep 13, 9:08 pm, wrote:
    > I have a bit of an unusual situation. I wired up my house when I did a
    > remodel to install a key system and an intercom at the front door. As
    > such all I did was run a four pair Cat5e from the doorbell to the
    > homerun closet. I have decided not to install a key system but instead,
    > just a doorbell. Unfortunately i did not run a doorbell wire from the
    > location where the doorbell would be to the front door to the chime
    > location and back to the transformer! What I did do is run a four pair
    > Cat5e from the front doorbell to the homerun closet as well as a four
    > pair Cat5e from the area where the chime would be mounted to the homerun
    > closet. Couldn't I just connect the the same color e.g. (brown
    > white/white brown) pair to the front doorbell as well as the same at the
    > chime and do all of the cross connects in the homerun closet to complete
    > the circuit and energize the doorbell. That is, connect the doorbell to
    > the chime with the same half of the pair and the other two conductors
    > (one from the doorbell and one from the chime go to the transformer,
    > that will be mounted in the homerun closet. There is not another way for
    > me to install a hard wired doorbell. Help if you can. If this does not
    > make sense, please let me know. Any suggestions or advice would be
    > appreciated.
    Yeah you can do that. I would suggest doubling up on the pairs to
    increase the wire gauge since CAT 5 is typically 24 guage wire. Ex use
    the white/blue and blue white tied together as 1 conductor, and the
    white/orange and orange white tied together for the other conductor.
  2. Mike rock
    JIMMIE Guest
    > > appreciated.
    > white/orange and orange white tied together for the other conductor.- Hide quoted text -
    > - Show quoted text -
    Ageed I use CAT5 cable for all kinds of low voltagae wiring especially
    since lately I have had access to a lot of scrapped cable.
    Jimmie
    JIMMIE, Sep 14, 2009
  1. Murmansk69
    Need cordless doorbell with longer range
    Murmansk69, Aug 27, 2008, in forum: Misc DIY
    727
    Harry Bloomfield
    Aug 27, 2008
  2. Closet Rod -- Need Support?
    , Feb 7, 2009, in forum: Home Repair
    8
    673
    SteveBell
    Feb 10, 2009
  3. Nail-In-Thumb
    Building a closet...need some help
    Nail-In-Thumb, Jun 9, 2009, in forum: Misc DIY
    1,079
  4. Charles
    Help hooking up thermostat
    Charles, Aug 4, 2007, in forum: HVAC
    649
    Mo Hoaner
    Aug 5, 2007
  5. Helpappreciated
    Need help with house doorbell
    Helpappreciated, Oct 29, 2011, in forum: Electrical
    441
    Helpappreciated
    Oct 29, 2011
