Re: Central Heating Boiler problem
Discussion in 'UK DIY' started by david.cawkwell@tesco.net, Apr 8, 2010.
  1. Guest
    On Apr 1, 1:27 pm, Paul <> wrote:
    > Today I have a problem with my central heating, the boiler is a Baxi
    > Duo-tec Combi 33 HE.
    > I have hot water but no central heating, the boiler starts to work and
    > then switches itself off after about 30 secs. Initially I believed this
    > was a problem with the pressure as when the boiler started the pressure
    > dropped below the green marked area on the gauge and the boiler stopped
    > (although I did not get an error indication E119 for low pressure).
    > I have repressurised the system and it now shows 1.5bar but the boiler
    > still starts for approx 30 secs then stops.
    > I have also bled the radiators to ensure there is no air in the system.
    > Any help greatly appreciated
    > Paul
    Air pressure sensor.
    Common fault on modern boilers.
    , Apr 8, 2010
  2. geoff
    geoff Guest
    In message
    "" <> writes
    >> Paul
    Really?
    How does it sense the demand for hot water
    Actually its less of a problem on modern boilers that don't have mains
    on the APS microswitch
    I don't know the duo-tech combi but, first thing to check is whether the
    boiler keeps sparking after ignition until it times out - this would
    point to a flame sensing problem
    Next "30 second" probability is associated with the heat exchanger -
    heat is getting in but not being carried away by the water (blockage,
    pump failure or something) - how long does it take to recover ?
    if neither of those, then the next most probable culprit is the pcb
    finally (but I would dismiss this as its unlikely to have a 30 second
    timescale) would be the diverter valve
    geoff
    geoff, Apr 9, 2010
  1. Frances
    10
    1,532
  2. Thomas
    1,506
  3. Replies:
    426
  4. wally
    446
    abaker
    Feb 15, 2007
  5. CB
    877
Share This Page
