Re: Boiler noises
Discussion in 'UK DIY' started by Tim S, May 12, 2009.
  1. Tim S
    Tim S Guest
    mark coughed up some electrons that declared:
    > Combination boiler is making horrible scary noises when I run the hot tap.
    > How can I put this right?
    > mark
    What sort of noises? Screeches, bangs, buzzing?
    Tim
    Tim S, May 12, 2009
  2. Tim S
    YAPH Guest
    >> mark
    Is it OK if you run the central heating?
    What's the system pressure (on the pressure gauge)?
    Does it make the smae noises at all flow rates?
    What make & model is the boiler?
    John Stumbles -- http://yaph.co.uk
    The astronomer married a star
    YAPH, May 12, 2009
  3. Tim S
    YAPH Guest
    On Tue, 12 May 2009 14:43:19 +0100, mark wrote:
    > Biasi
    ah, there's yer problem guv ;-)
    , M90F 28S about 5 years old.
    > No probs with central heating riunning alone.
    > 0.5 bar
    What happens if you put the system pressure back up to 1 bar?
    > Water temp on the boiler dial gets to about 70deg.
    Does it have a water temperature control? How's the problem if you turn
    this down?
    > Noises are loud, screeching, gurgling, banging.
    > Happens at medium flow rates or if washing machine is on.
    It sounds as if possibly the water is boiling in the primary heat
    exchander. Does this model heat the DHW directly in the primary heat
    exchanger, or indirectly via a plate heat exchanger? Are you in a hard
    water area? Is the scale inhibitor correctly topped up with snake oil? :)
    I used to be indecisive but now I'm not so sure
    YAPH, May 12, 2009
  4. Tim S
    RobertL Guest
    On 12 May, 14:43, "mark" <> wrote:
    > "YAPH" <> wrote in message
    > news:...
    > >>> tap.
    > >>> mark
    > Biasi, M90F  28S   about 5 years old.
    > 0.5 bar
    > mark- Hide quoted text -
    > - Show quoted text -
    0.5 Bar? ? should it not be closer to 1.5 Bar?
    RObert
    RobertL, May 12, 2009
  5. "YAPH" <> wrote in message
    >> Biasi
    Fitted properly in a clean system, they are no problem.
    >> 0.5 bar
    > this down?
    Sound lime the plate heat exchanger is blocked. Best replace.
    Doctor Drivel, May 12, 2009
  6. Tim S
    grantly Guest
    > news:...
    >>> Biasi
    >>> 0.5 bar
    >> if you turn this down?
    >> heat exchander. Does this model heat the DHW directly in the
    >> primary heat exchanger, or indirectly via a plate heat
    >> exchanger? Are you in a hard water area? Is the scale
    > I increased the pressure to 1bar and has crept up to 1.5 bar.
    > Since then I have been unable to recreate the noise.
    > So hopefully 'tis cured. Thank you.
    > mark
    Maybe some sediment got moved along the pipework somewhere.
    grantly, May 14, 2009
  1. Steve
    8
    556
    Steve
    Feb 19, 2005
  2. kd
    combi boiler noises
    kd, Oct 16, 2005, in forum: UK DIY
    379
  3. Bart C
    Boiler noises
    Bart C, Dec 23, 2005, in forum: UK DIY
    354
    Nick Booth
    Dec 23, 2005
  4. Replies:
    1,115
  5. Stewart Devereux
    Solid fuel boiler noises?
    Stewart Devereux, Dec 8, 2004, in forum: UK Home Improvement
    298
    Stewart Devereux
    Dec 8, 2004
