Radiator height from floor
Discussion in 'Misc DIY' started by Grumps, Feb 5, 2006.
  1. Grumps
    Grumps Guest
    Is there a minimum gap between the bottom of a standard central heating
    radiator and the floor? Radiator in question is a Myson (I think)
    2000x300mm, and would like to fit this underneath a large window (blinds, no
    curtains).
    Thanks.
    Grumps, Feb 5, 2006
  2. fred
    fred Guest
    In article <>, Grumps <grumpsnothere@h
    otmail.com> writes
    >curtains).
    Mine are an inch above the skirting, it lets the air circulate up behind the
    rads to reach their full output. That seems to look proportionate too.
    fred
    Plusnet - I hope you like vanilla
    fred, Feb 5, 2006
  3. On Sun, 5 Feb 2006 20:37:38 -0000, "Grumps" <>
    |curtains).
    The limiting factor will be circulation of air behind the radiator, so the
    minimum gap, top or bottom, should be greater than the distance between the
    radiator and the wall. In reality quite a lot greater to look right.
    Dave Fawthrop <dave hyphenologist co uk> Please quote, with quote
    character, previous post sniped to only the bit you are replying to.
    Threads often contain 100s of posts dozens layers deep. Other people
    use different newsreaders, they do not see or do what you see and do.
    Dave Fawthrop, Feb 5, 2006
  4. Grumps
    Grumps Guest
    > otmail.com> writes
    >> heating radiator and the floor? Radiator in question is a Myson (I
    >> think) 2000x300mm, and would like to fit this underneath a large
    >> window (blinds, no curtains).
    > behind the rads to reach their full output. That seems to look
    > proportionate too.
    Thanks.
    What size skirting do you have?
    Grumps, Feb 5, 2006
  5. fred
    fred Guest
    otmail.com> writes
    >> otmail.com> writes
    >> proportionate too.
    >Thanks.
    Various, 6 1/2", 10", 11 1/2" (it's an old property) but the inch rule seems
    to work for them all.
    fred
    fred, Feb 5, 2006
  6. Grumps
    Grumps Guest
    > so the minimum gap, top or bottom, should be greater than the
    > distance between the radiator and the wall. In reality quite a lot
    We have a 2.0x1.6m (wxh) window which leaves a gap of 41cm from the window
    ledge to the floor. A 30cm rad would be just above our short 4" skirting. Of
    course our plumber will also advise, but I just wanted some opinions before
    he shows up.
    Ta.
    Grumps, Feb 6, 2006
    |he shows up.
    Stelrad http://www.stelrad.com/UK/elite_tech_info.html have lots of 300mm
    radiators http://www.stelrad.com/UK/docs/elite.pdf available
    Dave Fawthrop, Feb 6, 2006
  8. Grumps
    Grumps Guest
    >> window ledge to the floor. A 30cm rad would be just above our short
    >> 4" skirting. Of course our plumber will also advise, but I just
    >> wanted some opinions before he shows up.
    > 300mm radiators http://www.stelrad.com/UK/docs/elite.pdf available
    Thanks for the link. It seems that Stelrad specify a min floor to rad gap of
    150mm. Looking at the Myson site, they spec 100mm min.
    Grumps, Feb 6, 2006
  1. Alan Dempster
    1,077
    Lurch
    May 4, 2004
  2. tarquinlinbin
    Re: Bath Height Off Floor .
    tarquinlinbin, Oct 20, 2006, in forum: Misc DIY
    2,011
    tarquinlinbin
    Oct 20, 2006
  3. x071907
    750
    Tom Baker
    Apr 30, 2004
  4. Existential Angst
    Breaker panel, code for height from floor
    Existential Angst, Oct 26, 2009, in forum: Home Repair
    12
    657
    RicodJour
    Oct 28, 2009
  5. Usenet Nutter
    Optimum Height Of Window Radiator
    Usenet Nutter, Dec 11, 2009, in forum: UK DIY
    22
    647
    PeterC
    Dec 12, 2009
