Radiator heat
Discussion in 'UK DIY' started by Golan, Nov 2, 2006.
  1. Golan
    Golan Guest
    So.
    My living room radiator acting wired.
    It have two valves one on each side (no trv) we use to open and close
    one valve in order to get more or less heat.
    Accidently some one touch the other valve (the one you not spouse to
    touch) and from than the radiator become colder. It is still warm but
    not burning as it uses to be before.
    I try to play with it but I cant get it to work as it was I was
    thinking that if both sides are open all the way it should give you to
    most high heat. What am I doing rung? Do I need to close the out valve
    to create a pressure in the radiator in order to get more heat? or do I
    need to open them both all the way in order to get more heat I want
    that radiator to be on full blast.
    Thanks for the help.
    Golan, Nov 2, 2006
  2. Golan
    Codswallop Guest
    "Golan" wrote:
    > So.
    Assuming that there are no other problems such as air in that radiator, or a
    blockage, and this problem is caused by the lock shield valve (out valve)
    being disturbed, you could try the following. Open the radiator control
    valve (in valve) fully, turn the central heating on, close the lock shield
    valve fully, then open it a quarter of a turn. Leave for 5 minutes then
    check the radiator. If it isn't working, open the lock shield valve another
    quarter of a turn. Keep repeating this until the radiator gets hot. If it
    doesn't get hot then something else is wrong. You can also try this: turn
    all the other radiators off by their control valve (do not touch their lock
    shield valve) and se if that one radiator gets hot. If it doesn't, there may
    be air or a blockage, if it does then the whole system may need balancing or
    there is some other problem. Is it possible that someone has opened the lock
    shield valves on any of the other radiators as that could unbalance the
    system. This is a diy answer, not from a plumber.
    Codswallop, Nov 2, 2006
  3. Golan
    Golan Guest
    Codswallop wrote:
    > "Golan" wrote:
    > > So.
    Hi.
    I did nit touch ant other radiators is the system. We keep most of them
    close. Only the bathroom always on and the living room when we sit
    there. So if I open the LSV all the way will I get the max heat from
    the radiator? Or do I need to close it little bit to "hold" the water
    in?
    Golan, Nov 2, 2006
  4. Golan
    Codswallop Guest
    "Golan" wrote:
    > Hi.
    > in?
    Yes, if you open the LSV you will reduce the resistance to the flow of water
    through that radiator so more water will flow through but that may mean less
    pressure to the other radiator(s). You have not said how many radiators you
    have in total but if you only have two radiators in use on a typical 6 to 8
    radiator system then if the pump and motorised valves are working properly,
    and there are no blockages due to sludge, the two radiators should be hot if
    their control valves and lock shield valves are open. Closing a LSV will
    increase the resistance to water flow in that radiator and mean more water
    available for the other radiators(s). I have assumed a non-pressurised
    system.
  5. Golan
    Golan Guest
    Codswallop wrote:
    > "Golan" wrote:
    > > Hi.
    > > in?
    > system.
    I will give more info.
    Pressurised system worcester24CDi combi
    4 radiators we use only 2. The bath radiator is ok but the living room
    as I sad worm not burning hot.
    Another thing. From yesterday the boiler pump making noise "clink
    clink" noise like it have air in it. When I lower the boiler
    temperature it is quieter.
    Golan, Nov 2, 2006
  6. Golan
    Codswallop Guest
    I have no knowledge of pressurised systems. I don't like the sound of your
    pump. I suggest you re-post with as much info as possible.
  7. Golan
    Golan Guest
    _____________________________________________________________
    I think the problem is some how with the pressure in the system. I did
    top up the system because I have a leek in one of the valves.
    The pressure bar is on 1.6 and only 2 radiators are on (living room and
    bathroom) when I open the hall radiator and turn the boiler off and
    than on again all the radiators become really hot. Than when I close
    the hall radiator the system go cold again and the radiators are worm
    but not burning hot. I have a filing that the pressure is to high and I
    should release some of it out.
    Any thoughts about that?
    And can any one just tell my for my general knowledge, if both side of
    the radiator fully open should the radiator work in full blast? Or do I
    need to close the LSV in order to create a pressure in the radiator the
    squeeze more heat?
    Golan, Nov 2, 2006
  8. Golan
    Codswallop Guest
    > squeeze more heat?
    Yes, if this radiator is the one closest to the pump. But if this radiator
    is somewhere in the middle, or is the one farthest from the pump, the effect
    of opening or closing the lock shield valve might depend on how all the
    radiators are balanced, especially the earlier ones on the circuit, and
    whether their control valves are open or closed. The lock shield valves
    alter the resistance to water flow in each radiator to compensate for the
    fact that the radiators are at varying distances from the pump, so that the
    radiators are balanced. In order for radiators to work properly the pump
    needs to be working, the system needs to be free of air and sludge, and the
    radiators need to be balanced.
    Codswallop, Nov 3, 2006
  1. Lee Wright
    981
  2. Dave
    17
    1,479
    Roger
    Jan 10, 2005
  3. Replies:
    507
    Dave Plowman (News)
    Oct 11, 2005
  4. Replies:
    16
    591
    Roger Mills
    Apr 18, 2006
  5. Replies:
    16
    703
    Road_Hog
    Mar 3, 2012
