Question on HVAC Abbreviations TLC & PTU
Discussion in 'HVAC' started by A, Mar 2, 2005.
  1. A
    A Guest
    Could someone give me the HVAC definitions for 'TLC and PTU' when used
    for a gas mid-efficient furnace?
    The reason I ask is my daughter's 1993 Lennox G24M2-75A-2
    mid-efficient hot surface ignitor furnace has been (IMHO) rapidly
    cycling lately.
    I came across a service bill at her home from many years ago (before
    they bought the home) and it had the notation 'Recommend TLC or PTU'.
    So I was thinking - maybe TLC means: Temperature Limit Control? But
    PTU?
    They had their ducts cleaned in the summer - but the furnace was not
    cleaned at that time. I'm going to recommend that they have the
    furnace cleaned but was wondering if the TLC or PTU might also require
    attention (provided I can figure out what they are).
    The furnace has the normal pre-ignition exhaust fan run for 1 minute
    then
    normal ignition but the gas runs for only for 4 minutes (which seems a
    short period of time to me at least compared to my furnace)
    The blower fan starts normally after the 1 minute heat exchanger warm
    up period,
    After the gas shuts off, the blower runs for the cool down period for
    3 minutes to fan off
    There is a 2 minute delay - which seems abnormally short - then the
    ignition sequence restarts.
    Total cycle time 10 minutes.
    They have been doing lots of renovations - some involving work around
    the ducts & I suspect they may have kicked up a lot of dust onto the
    heat exchanger.
    We replaced the blower compartment filter. The problem persists.
    Thanks, Cindy
    A, Mar 2, 2005
    Ask in alt.home.repair, not here.
    Paul ( pjm @ pobox . com ) - remove spaces to email me
    'Some days, it's just not worth chewing through the restraints.'
    HVAC/R program for Palm PDA's
    Free demo now available online http://pmilligan.net/palm/
    Free Temperature / Pressure charts for 38 Ref's http://pmilligan.net/pmtherm/
    p j m@see _my _sig _for_address.com, Mar 2, 2005
  3. bill
    bill Guest
    In article <>,
    > cycling lately.
    > PTU?
    I tend to think it means: Recommend Tender Loving Care or Pitch The Unit.
    bill, Mar 2, 2005
  4. stretch
    stretch Guest
    Re: Question on HVAC Abbreviations TLC & PTU
    PTU means Precision Tune Up. TLC means Tender Loving Care.
    stretch, Mar 2, 2005
  5. Tekkie
    Tekkie Guest
    A posted for all of us....
    > cycling lately.
    > PTU?
    > then
    > up period,
    > heat exchanger.
    > Thanks, Cindy
    TLC = Total Loser Caution
    PTU = Parts Too Unmentionable
    Tekkie
    Tekkie, Mar 4, 2005
  6. bill
    bill Guest
    In article <>,
    Typical Lousy Customer
    Piss Towards Unit
    Tiny Little Cockroachs
    Party Till Upchuck
    Tighten Loose Cover
    Press To Unlock
    bill, Mar 4, 2005
  1. David
    8
    473
    David
    Sep 26, 2003
  2. Dave Plowman
    Naughty TLC
    Dave Plowman, Jan 14, 2004, in forum: UK DIY
    379
    The Natural Philosopher
    Jan 15, 2004
  3. John Rumm
    First class service from TLC
    John Rumm, Jul 22, 2005, in forum: UK DIY
    257
    freddyuk
    Jul 22, 2005
  4. a
    HVAC definitions of TLC and PTU
    a, Mar 8, 2005, in forum: Home Repair
    322
    Dr. Hardcrab
    Mar 8, 2005
  5. Mike S.
    Need help with these abbreviations
    Mike S., Oct 10, 2006, in forum: Home Repair
    199
    Joshua Putnam
    Oct 10, 2006
Share This Page
