Push fit plumbing - any good?
Discussion in 'Misc DIY' started by Dave, Sep 26, 2004.
  1. Dave
    Dave Guest
    I've always used soldered joints but am being tempted by the Tectite
    push-fit range for a heating re-furb I'm about to embark on - maybe even
    plastic pipe rather than copper! How long have they been around? Any horror
    stories? Are there any other competing ranges I should consider?
    Dave S
    Dave, Sep 26, 2004
  2. IMM
    IMM Guest
    "Dave" <> wrote in message
    horror
    > Dave S
    Pushfit Tectite is good. Keep to copper pipe and only use plastic pipe when
    you need to.
    IMM, Sep 26, 2004
  3. Grunff
    Grunff Guest
    > you need to.
    Your opinion on the subject changes every time you post on it! That
    includes your favourite brand.
    Grunff
    Grunff, Sep 27, 2004
  4. IMM
    IMM Guest
    "Grunff" <> wrote in message
    when
    > > you need to.
    Another mentalist.
    IMM, Sep 27, 2004
  5. Grunff
    Grunff Guest
    Andy Hall wrote:
    > There are numerous brands. I've used
    > - Hep2o
    > - JG Speedfit
    > - Marley Equator
    > - Tectite
    I've also used all of the above, as well as CuproFit, and have had no
    problems with any of them.
    I recently tried the ToolsStation offering, made by QualPlumb. They are
    similar in construction to Hep fittings, but come in white plastic. I
    was quite impressed with them.
    Grunff
  6. In article <>,
    > horror stories? Are there any other competing ranges I should consider?
    Check out the price. If you've got decent 'copper' skills, you'll save
    quite a bit of money. Neater job too.
    Plastic can be easier to route under floors, though.
    *Experience is something you don't get until just after you need it *
    Dave Plowman London SW
    Dave Plowman (News), Sep 27, 2004
  7. IMM
    IMM Guest
    "Andy Hall" <> wrote in message
    > On Mon, 27 Sep 2004 00:04:01 +0100, Grunff <> wrote:
    when
    > >> you need to.
    > Generally these change quarterly, as opposed to the heating solution
    > of the month.
    > Speedfit is out of favour at present, ever since the hacksaw incident.
    What incident was that? Speedfit has always been out of favour.
    IMM, Sep 27, 2004
  8. IMM
    IMM Guest
    > > - Hep2o
    > > - JG Speedfit
    > > - Marley Equator
    > > - Tectite
    Who makes them? The Homebase own brand is made by Speedfit. Is it Hepworth
    just changing the colour?
    IMM, Sep 27, 2004
  9. Dave
    Dave Guest
    .... snipped
    > - Hep2o
    > - JG Speedfit
    > - Marley Equator
    > - Tectite
    Are there any huge price differences between the brands? - presumably the
    pipe and fittings are all made to a standard so are interchangeable(?)
    > and had no problems with any of them on either copper or barrier
    > plastic tube.
    > It is important to follow the instructions for bending and securing
    > and also to cut using a proper pipe cutter.
    What's special about the pipe cutter? I see that Screwfix have got a cheap
    one and an expensive one - any experience with them?
    > .andy
    Thanks,
    Dave S
    Dave, Sep 27, 2004
  10. Grunff
    Grunff Guest
    <http://www.qpl.ie/html/QP.html>
    Grunff
  11. IMM
    IMM Guest
    > news:...
    > ... snipped
    > > - Hep2o
    > > - JG Speedfit
    > > - Marley Equator
    > > - Tectite
    Not really. All are expensive compared to copper pipe and end feed fittings.
    > - presumably the
    In theory, yes, as they all have to conform to a standard. In practice, no.
    Hepworth say do not interchange as makers tolerances are different.
    > > plastic tube.
    It gives a clean straight cut very quickly. You can acheive this with other
    tools, but it will take longer.
    IMM, Sep 27, 2004
    #11
  12. Grunff
    Grunff Guest
    The main difference in price comes from where you buy them and how many
    you buy. The most expensive way of buying them is to buy just one from
    B&Q or a plumbers merchant. The cheapest way is to buy a bag of 10 from
    Screwfix or Toolstation.
    > - presumably the
    They all use standard pipe, so 10mm, 15mm, 22mm, 28mm are the main
    sizes. The only thing to look out for is pipe inserts. When using
    plastic pipe, you need to use plastic/copper/s.steel inserts in the end
    of the pipe. Use the correct insert for the fitting.
    I have one of each. The SpeedFit cutter (blue) is by far the best way of
    cutting. It's very quick, and gives nice clean square cuts. The cheap
    Screwfix cutter (red) is ratchetting, and is good for cutting big MDPE
    pipe. Does a pretty good job on 12/22mm PEX pipe, but not as quick as
    the blue cutter.
    Grunff
    #12
  13. :::Jerry::::
    :::Jerry:::: Guest
    "IMM" <> wrote in message
    > news:...
    pipe
    > when
    > > > you need to.
    > Another mentalist.
    But who was ranting on about how bad push fit couplings were a couple of
    months ago, when a certain someone f*cked up a fiends pluming because he
    couldn't read the instructions ?...
    Surely it wasn't the same 'IMM' as who has just posted the above message ?!
    :::Jerry::::, Sep 27, 2004
    #13
  14. Grunff
    Grunff Guest
    At this point it's worth googling for a little thread we had a while
    back. <http://tinyurl.com/42ke4>
    Grunff
    #14
  15. IMM
    IMM Guest
    other
    It is not worth it. "It gives a clean straight cut very quickly. You can
    acheive this with other tools, but it will take longer." That is all you
    need to know.
    IMM, Sep 27, 2004
    #15
  16. Grunff
    Grunff Guest
    Andy Hall wrote:
    > You do have to read and follow the instructions.
    Well, you say that...
    After that little hacksaw thread I did a fair bit of playing around with
    various pushfit fittings, being of a curious disposition. It's actually
    really, *really* hard to get one to leak.
    The easiest to damage were CuproFit, where the O ring can be pushed out
    if you insert the pipe at a sharpish angle. I failed to make any
    speedfit or hep fitting leak while 'making' them, or subsequently by
    applying sideways pressure to the pipe. In both JG and Hep fittings it
    was the plastic casing that broke first.
    On another matter, 3 years ago I installed a 'temporary' water valve
    outside near the stables. This made use of 3 JG fittings and a Pegler
    1/4 turn ball valve. It has been sitting on a concrete block outside for
    3 years, through quite a few freeze/thaw cycles. No leaks yet from the
    fittings, but I had to replace the valve last year because of frost damage.
    Grunff
    #16
  17. IMM
    IMM Guest
    > >news:...
    pipe
    > >when
    > >> >> you need to.
    > >> of the month.
    > Surely you remember.....
    No incident with an hacksaw. the hacksaw worked perfectly.
    I'm sure you have never seen one of these never mind use one:
    http://www.toolstation.com/images/library/stock/webbig/34311.jpg
    The right hand side is the handle. Then make sure the serrated part is
    facing down. Don't let the kids near it.
    IMM, Sep 27, 2004
    #17
  18. Dave
    Dave Guest
    "Dave Plowman (News)" <> wrote in message
    > In article <>,
    > Dave <> wrote:
    .... snipped
    The "copper skills" are reasonable but I normally use solder ring fittings
    rather than end fed. The only time I had a problem was when I was using some
    old fittings and a previously-tinned end on the pipe; the old fittings had
    leaded solder rings and the tinning used lead-free :-(
    Now I look at the symbol on the fitting!
    What type of fitting do I use to adapt from a poly rising main to copper?
    Currently the main goes straight to 15mm copper using some sort of brass
    fitting but I want to change this to 22mm, unfortunately it's in a corner
    and near the floor so it's going to be a b*gger of a job.
    Dave S
    Dave, Sep 27, 2004
    #18
  19. IMM
    IMM Guest
    A heating engineer I know is working on sites installing Hep2O. O rings
    being dislodged after the pipe is installed is pretty common. The fitting
    failure rate is high averaging one every second house. It takes a hell of
    an effort to push these fitting home which the installers don't particularly
    like, especially in tight corners. In many instances a normal compression
    joint would be better. Many fittings fail after a test (all systems are
    pressure tested) and when the same fitting is taken off and replaced it
    holds. Small amounts of dust/dirt can make a leak.
    None of them are too fussed on plastic pipe and think it is more of a
    hindrance because of the constant failures on the first fix. When they do a
    soldered joint they know it will hold. The odd compression joint weeping
    usually means just a quick tighten up. Installing copper on first fix is
    just as easy to these guys, if not easier than plastic pipe. Plastic
    requires more clips. They say it does not cut installation time.
    Plastic Is only used so the Travellers will not strip out the copper
    overnight.
    damage.
    That is one of plastics advantages. It is resistant to freezing.
    IMM, Sep 27, 2004
    #19
  20. StealthUK
    StealthUK Guest
    "Dave" <> wrote in message news:<>...
    > Dave S
    I've been using JG Speedfit for the last couple of years. They have a
    twist lock feature on them which stops the pipe moving around and
    tightens the seal ring around the pipe after insertion. Never had a
    problem with them.
    For straight runs and where pipes will be visible I still use copper
    pipe. Plastic is great and time saving everywhere else.
    StealthUK, Sep 27, 2004
    #20
  1. Steve
    69
    2,779
    Andy Hall
    Sep 3, 2005
  2. Al
    1,424
  3. Jim K
    682
    Jim K
    Dec 1, 2010
  4. mike
    512
    Man at B&Q
    May 7, 2013
  5. MM
    Push-fit plumbing
    MM, Sep 5, 2013, in forum: UK DIY
    14
    288
    Andrew Gabriel
    Sep 7, 2013
