Pumping air into combi expansion vessel - how many PSI?
Discussion in 'UK DIY' started by Dave£, Oct 24, 2004.
  1. Dave£
    Dave£ Guest
    I checked the air pressure in my Britony 80 combi boiler's expansion
    vessel the other day; that's after I lowered the water pressure to
    about 0.8 bar. There was no air pressure at all - as I suspected.
    I now need to know how many psi of air to pump into it when the water
    presure is, say, about 0.8 bar. I'm asking for a psi figure because my
    air pressure guage only has psi reading no bar reading.
    The expension vessel was originally pre-charged to 0.7 bar according
    to the manual.
    Thank you
    Dave L
    Dave£, Oct 24, 2004
  2. Dave£
    Set Square Guest
    > to the manual.
    > Thank you
    > Dave L
    1 bar = 14.5 psi - so, for 0.7 bar, you'll need just over 10 psi [10.15 to
    be exact - but I doubt whether your pressure gauge measures fractions of a
    psi]
    Cheers,
    Set Square
    ______
    Please reply to newsgroup. Reply address is invalid.
    Set Square, Oct 24, 2004
  3. Dave£
    Dave£ Guest
    On Sun, 24 Oct 2004 19:54:11 +0100, "Set Square" <>
    >>> to the manual.
    >>> Thank you
    >>> Dave L
    >>psi]
    SS, Thank you for your help again. One thing I'm not clear about: At
    what pressure should the heating system water be when I pump the
    expansion vessel to 10psi? And, should the boiler be tuned on or off
    during this operation?
    Dave L
    Dave£, Oct 25, 2004
  4. Dave£
    Set Square Guest
    >>> [10.15 to be exact - but I doubt whether your pressure gauge
    >>> measures fractions of a psi]
    > Dave L
    You must pump up the pressure vessel with the heating system cold and
    un-pressurised. At this point, the pressure vessel will be completely filled
    with air at 0.7 bar. *Then* use the filling loop to pressurise the system to
    around 1 bar, cold. *Some* water will enter the pressure vessel (on the wet
    side of the diaphragm), and will compress the air a bit more - but still
    leave plenty of expansion potential. When the system is hot, it shouldn't
    get to much more than 2 bar if everything is working correctly.
    Cheers,
    Set Square
    ______
    Set Square, Oct 25, 2004
  5. Dave£
    Ed Sirett Guest
    >>>> to the manual.
    >>>> Thank you
    >>>> Dave L
    >>>psi]
    The FAQ may help (if it's read).
    Ed Sirett, Oct 25, 2004
  1. Dave£
    8
    529
    John Rumm
    Nov 20, 2004
  2. Rich
    786
  3. nrh
    Combi expansion vessel
    nrh, Jan 18, 2006, in forum: UK DIY
    17
    1,012
    Ed Sirett
    Feb 13, 2006
  4. Jake S
    728
    Roger Mills \(aka Set Square\)
    Feb 28, 2006
  5. Steve Stone
    well pressure tank - 19.2 psi = 44 psi ???
    Steve Stone, May 27, 2012, in forum: Home Repair
    12
    446
    Steve Stone
    May 31, 2012
