Pump for pumping air into combi boiler exansion vessel?
Discussion in 'UK DIY' started by Rich, Feb 3, 2005.
  1. Rich
    Rich Guest
    The expansion vessel in my combi has stopped doing its job properly
    after a leaking radiator valve reduced the system pressure to almost
    nothing the other day.
    Last time I found the expansion vessel wasn't doing its job, I managed
    to pump 10psi of air into it, and it then worked perfectly for a few
    months until this latest event.
    This procedure would be easy if I had a suitable (cheap) pump. Any
    suggestions? A car foot pump is out of the question because the
    vessel's valve is about 5 ft above floor level.
    Last time I did it, I had an electric tyre pump which I connected to a
    long wire which I then plugged into my car's fag lighter. But it was
    very tricky because each time I pulled the pump's attachment off the
    valve, the air would escape - and it doesn;t take much air to create
    10psi in the vesel.. And now I don't have a car with a fag lighter!
    I do have a procket pressure guage which can read as low as 10 psi.
    It's just the pump which is the problem.
    Thanks for any suggestions. A battery-operated pump perhaps? Anyone
    know of a cheap one? Someone told me a bicycle pump would work. Is
    that correct?
    Many thanks
    Rich
    Rich, Feb 3, 2005
  2. Rich
    Grunff Guest
    > that correct?
    Bicycle pump.
    Grunff
    Grunff, Feb 3, 2005
  3. Rich
    Set Square Guest
    > that correct?
    > Many thanks
    > Rich
    I would use a car footpump, parked on the platform at the top of a step
    ladder, and operated by hand. You don't need a lot of force for 10 psi - and
    hand-power is quite adequate.
    Cheers,
    Set Square
    ______
    Please reply to newsgroup. Reply address is invalid.
    Set Square, Feb 3, 2005
  4. Rich
    John Guest
    "Rich" <> wrote in message
    > that correct?
    I carry in my van a bicycle pump with suitable connector for just this sort
    of operation.
    Don't forget to depressurise the radiator system before pumping up the
    vessel to its design pressure
    John, Feb 3, 2005
  5. Rich
    John Guest
    "Christian McArdle" <> wrote in message
    news:42023b0e$0$19159$...
    > I would replace the vessel. It should not require regular precharging.
    Well not regularly but you do come across the customer who says I had such
    and such wrong and I thought I'd check for airlocks. I let a lot of air out
    of here but it still won't go <g>
    > Christian.
    John, Feb 3, 2005
  1. Dave£
    3,297
    Ed Sirett
    Oct 25, 2004
  2. Dave£
    8
    550
    John Rumm
    Nov 20, 2004
  3. Bruce
    12
    1,104
    Bruce
    Mar 14, 2005
  4. Replies:
    310
  5. vic
    405
    jamesgangnc
    Mar 8, 2007
