Pulsing lawn mower
Discussion in 'Home Repair' started by Calab, Aug 9, 2009.
  1. Calab
    Calab Guest
    Howdy!
    I just received a three year old B&S 3.5 horsepower mower from a friend.
    Currently, it starts easy but starts pulsing once it's been running for a
    few minutes.
    I've been told that the mower ran fine until it was tipped onto it's side to
    be cleaned out.
    What I've done so far...
    - cleaned the sponge air filter
    - drained the gas and filled with new
    - sprayed the carb with carb cleaner
    - checked oil levels
    - ensured that the throttle moves freely
    The only thing that I can think of is that it's internal to the carb, or
    that the springs on the carb are not in their correct location.
    Photo's of the carb and linkage.
    http://members.shaw.ca/linkto/temp/carb1.jpg
    http://members.shaw.ca/linkto/temp/carb2.jpg
    Any ideas on how to fix this?
    Calab, Aug 9, 2009
  2. Calab
    RBM Guest
    "Calab" <> wrote in message
    news:X9Hfm.90048$...
    > Howdy!
    > few minutes.
    > to be cleaned out.
    The condition is called "hunting", and is caused by a governor that needs
    adjustment
    RBM, Aug 9, 2009
  3. Calab
    Oren Guest
    On Sun, 9 Aug 2009 15:26:14 -0600, "Calab" <> wrote:
    >Howdy!
    >few minutes.
    >be cleaned out.
    Loosen the gas cap a tad and see it runs better. If so the cap vent is
    clogged. Use a paper clip to clear the cap vent hole.
    A fouled spark plug might be the culprit.
    Oren, Aug 9, 2009
  4. Calab
    Doug Miller Guest
    >> Howdy!
    >> few minutes.
    >> to be cleaned out.
    >adjustment
    I have a rototiller that suffers from that problem -- any link to a site that
    explains how to adjust an air vane governor? I Googled, and found plenty of
    info about adjusting mechanical governors, but didn't find anything about air
    vane governors.
    Doug Miller, Aug 9, 2009
  5. Calab
    RBM Guest
    "Doug Miller" <> wrote in message
    news:h5nj5f$bkl$-september.org...
    >>> Howdy!
    >>> a
    >>> few minutes.
    >>> side
    >>> to be cleaned out.
    >>adjustment
    > that
    > of
    > air
    > vane governors.
    The governor is just one possibility for hunting, any number of carburetor
    issues can cause it as well. In the op's case, it appeared that the engine
    was fine until they tipped it over, so my guess is that they inadvertently
    mucked up the vane linkage. I have a pdf I can send you with a typical B&S
    vane adjustment, just email me at
    RBM, Aug 10, 2009
  6. Calab
    Art Todesco Guest
    >> Howdy!
    >> few minutes.
    >> to be cleaned out.
    > adjustment
    Or, it just might need cleaning. On my
    old Toro, it started hunting.
    I found the governor lever caked up with
    mud, grease and grass.
    After a cleaning with a degreaser (spray
    carb cleaner) to remove
    old grease, etc., it ran perfectly.
    Art Todesco, Aug 10, 2009
  7. Calab
    RBM Guest
    "Art Todesco" <> wrote in message
    news:h5nlq5$3pt$...
    >>> Howdy!
    >>> a few minutes.
    >>> side to be cleaned out.
    >> adjustment
    > Or, it just might need cleaning. On my old Toro, it started hunting.
    > I found the governor lever caked up with mud, grease and grass.
    > After a cleaning with a degreaser (spray carb cleaner) to remove
    More often than not, that's just the kind of adjustment they need. Damn
    things are very critical, so it doesn't take much to throw them out.
    RBM, Aug 10, 2009
  8. Calab
    dpb Guest
    Calab wrote:
    > Howdy!
    > a few minutes.
    One lesser possibility given it's not terribly old but alternative to
    the governor hunting is a variable air leak--loose intake or worn
    throttle shaft are most common of those.
    dpb, Aug 10, 2009
  9. Calab
    JIMMIE Guest
    > >Howdy!
    > >few minutes.
    > >be cleaned out.
    > A fouled spark plug might be the culprit.- Hide quoted text -
    > - Show quoted text -
    Im just a tinkerer when it comes to small engines but Ive kept mine
    going over the years. Whenever I have seen this I just go over them
    checking everything. First thought usually is that its a governor
    problem but I dont think I have ever seen that be the problem. Clogged
    fuel path seems to be pretty common and a lot of "I dont knows" it
    just starts working after cleaning everything up.
    I did find one that wouldnt work with cap on. The cap didnt have a
    vent in it so I figured it had to be vented some place else. I had
    taken everything apart and cleaned and put it back together figuring
    this shouldnt be a problem. Well the problem was it had the wrong cap
    on it. I walked down to my brothers house and checked on the back
    porch. There was his gas can with the lawnmowers cap on it.
    Jimmie
    JIMMIE, Aug 10, 2009
  10. Calab
    JIMMIE Guest
    On Aug 9, 5:26 pm, "Calab" <> wrote:
    > Howdy!
    > few minutes.
    > I've been told that the mower ran fine until it was tipped onto it's sideto
    > be cleaned out.
    I took another look and I think the little silver spring is installed
    wrong. I believe it should be attched loosely in the big loop on the
    throtle linkage.
    Jimmie
  11. Calab
    ransley Guest
    On Aug 9, 4:26 pm, "Calab" <> wrote:
    > Howdy!
    > few minutes.
    > be cleaned out.
    Maybe dirt lodged from tipping in the governor and linkage, easiest is
    try compressed air to blow out everything and see if all moves
    freely.
    ransley, Aug 10, 2009
    #11
  12. When I took a small engine repair course, I was told that
    hunting is caused by a governor spring that's stiffened up.
    Christopher A. Young
    Learn more about Jesus
    www.lds.org
    "RBM" <> wrote in message
    news:4a7f47f5$0$10302$...
    governor that needs
    adjustment
    Stormin Mormon, Aug 10, 2009
    #12
  13. Calab
    Art Todesco Guest
    > news:h5nlq5$3pt$...
    >>>> Howdy!
    >>>> a few minutes.
    >>> adjustment
    Critical is right. The shaft only moves
    a few degrees. It doesn't take
    much to make it work poorly.
    #13
    >>> Howdy!
    >>> few minutes.
    >>> be cleaned out.
    > Jimmie
    It seems that every time I let someone borrow a gas can,
    it is returned sans cap. It's always the same. "Where's
    the cap?" "Eye-O-no". I think that's one reason Tasers
    were invented.
    TDD
    The Daring Dufas, Aug 10, 2009
    #14
  15. On Aug 9, 5:26�pm, "Calab" <> wrote:
    > Howdy!
    > few minutes.
    > be cleaned out.
    > �- cleaned the sponge air filter
    > �- drained the gas and filled with new
    > �- sprayed the carb with carb cleaner
    > �- checked oil levels
    > �- ensured that the throttle moves freely
    It appears that your linkage has been modified. Go to the B&S website
    and download the PDF file that will show the proper parts. Then
    install the proper parts correctly. The linkage that the arrow is
    pointing to is not the correct part. I am not sure about the springs.
    Hank
    Hustlin' Hank, Aug 10, 2009
    #15
  16. Calab
    JP Guest
    On Aug 9, 2:26 pm, "Calab" <> wrote:
    > Howdy!
    > few minutes.
    > be cleaned out.
    Try replacing or cleaning the muffler,I have this to be the problem a
    lot of the time.
    JP, Aug 10, 2009
    #16
  17. Calab
    Calab Guest
    > Howdy!
    > few minutes.
    Lots of good ideas folks! I really appreciate it!
    Calab, Aug 10, 2009
    #17
  18. Calab
    Oren Guest
    >> Howdy!
    >> few minutes.
    Telling us how you fix it will be appreciated.
    Oren, Aug 11, 2009
    #18
  19. Calab
    Ulysses Guest
    "JIMMIE" <> wrote in message
    > Howdy!
    > few minutes.
    to
    > be cleaned out.
    throtle linkage.
    Jimmie
    If it's what I *think* it is it should have only the slightest tension when
    the engine is stopped. Is it a very weak spring about 2 inches long (or
    so)?
    Ulysses, Aug 11, 2009
    #19
  1. chris French
    8
    6,933
    chris French
    Sep 18, 2006
  2. jim
    363
    The Natural Philosopher
    Dec 23, 2006
  3. Doc
    354
    Don Klipstein
    Jul 19, 2007
  4. mrcheerful
    Re: pulsing shower pump
    mrcheerful, Dec 4, 2004, in forum: UK Home Improvement
    823
    mrcheerful
    Dec 4, 2004
  5. nigeee2001
    saniplus pulsing on draining
    nigeee2001, Jun 20, 2010, in forum: Plumbing and Drains
    878
    nigeee2001
    Jun 20, 2010
