Problem with Glow-worm boiler
Discussion in 'UK DIY' started by mightyhugh@yahoo.co.uk, Feb 1, 2006.
  1. Guest
    My boiler, a Glow-worm space saver F, has stopped working. Its normal
    sequence of operation when starting up is that the flue extractor fan
    starts running, then a spark electrode lights a pilot light which then
    lights the main burner. However, now all that happens when you switch
    it on is a clunk and a faint whirring sound (I'm not sure if this is
    coming from the boiler itself or just water circulating from the water
    pump). There doesn't seem to be any air blowing out from the flue and
    there is no sparking at the pilot light. Does anyone here have any idea
    what might have gone wrong and how to fix it?
    , Feb 1, 2006
  2. Fentoozler
    Fentoozler Guest
    "Christian McArdle" <> wrote in message
    news:43e0dc4b$0$274$...
    > Well, you say the first element in the sequence is the fan starting. There
    > will be various fail-safe mechanisms that abort the lighting sequence if
    > the
    > fan fails.
    > So perhaps the fan is not starting for a reason. Either it is broken, or
    > the
    > cable to it is, or the PCB is knackered.
    > There may be other failsafe devices, too. Perhaps the first step is really
    > to start the water flow and only to proceed when flow is detected. I don't
    > know enough about the boiler. Hopefully Ed Sirrett or raden will be along
    > soon with the actual sequence or most likely failure mode for this boiler.
    > Christian.
    If the fan doesn't get up to speed, the air pressure switch won't click over
    and nothing else will work. you could try lubricating the fan assembly,
    else replace it. If the fan is getting up to speed, your air pressure
    switch may be faulty.
    Angus
    Fentoozler, Feb 1, 2006
  3. Ed Sirett
    Ed Sirett Guest
    > will be various fail-safe mechanisms that abort the lighting sequence if the
    > fan fails.
    > So perhaps the fan is not starting for a reason. Either it is broken, or the
    I've only met a couple of these boilers. However if the fan is not running
    then the acid test is to see if it's getting any power.
    I have no reason to doubt raden's belief that these boilers have
    troublesome fans.
    The FAQ for uk.diy is at http://www.diyfaq.org.uk
    Choosing a Boiler FAQ http://www.makewrite.demon.co.uk/BoilerChoice.html
    Ed Sirett, Feb 1, 2006
  4. John
    John Guest
    <> wrote in message
    The clunk could te easily be the fan having failed bearings and instead of
    spinning the magnetic field drags the rotor sideways onto the stator.
    If you are competent open up the dasing and watch what happens.
    If the fan is at fault try Geoff at CET
    John, Feb 1, 2006
  5. raden
    raden Guest
    In message <43e0dc4b$0$274$>, Christian
    McArdle <> writes
    >fan fails.
    Well, a bit more info would have been useful. It sounds like all that is
    happening is that the pump is probably running and the fan isn't. Given
    that baseline ...
    Diagnostics would require a DVM and carried out in the following order
    and can all be performed at or near the pcb
    1/ Is there 240V between the live and neutral on the PCB (Blue and brown
    flying leads)
    2/ Is the overheat stat open circuit as measured at the pcb (yellow and
    white flying leads
    3/ Are there volts to the Fan ? (connector which plugs into the pcb
    geoff
    raden, Feb 1, 2006
  6. Cicero
    Cicero Guest
    <> wrote in message
    The 'whirring' sound which you describe might be the fan working normally
    (despite the fact that there is apparently no air blowing out). The tubes
    from the fan to the air switch have a tendency to block up (only about 3mm
    ID). If this happens the light-up procedure fails. If you are confident
    enough open the boiler, disconnect the air tubes and check that they're
    clear of obstruction.
    Cic.
    Cicero, Feb 1, 2006
  7. raden
    raden Guest
    In message <>, Ed
    Sirett <> writes
    >> fan fails.
    >troublesome fans.
    No, that's Fuelsavers, the Spacesaver has a completely different fan
    geoff
    raden, Feb 1, 2006
  8. Ed Sirett
    Ed Sirett Guest
    On Wed, 01 Feb 2006 23:51:49 +0000, raden wrote:
    > In message <>, Ed
    > Sirett <> writes
    >>> fan fails.
    >>troublesome fans.
    .... if any fan at all.
    Ed Sirett, Feb 2, 2006
  9. raden
    raden Guest
    In message <>, Ed
    Sirett <> writes
    >>>troublesome fans.
    Well, yes
    From where I stand, If I know there's a Fuelsaver fan, I don't
    necessarily know that there's a version without a fan
    geoff
    raden, Feb 2, 2006
  10. Guest
    It turned out the fan was jammed. Thanks for your help everyone.
    Hugh
    , Feb 4, 2006
  1. Tim Mitchell
    Is a Glow Worm 18HXI boiler any good?
    Tim Mitchell, Jul 16, 2003, in forum: UK DIY
    882
  2. Peter Kelly
    Glow worm boiler problem
    Peter Kelly, Nov 30, 2003, in forum: UK DIY
    1,791
    Harry Bloomfield
    Dec 16, 2003
  3. Nick Harrison
    replacement boiler glow-worm micron
    Nick Harrison, Jan 6, 2004, in forum: UK DIY
    421
    Nick Harrison
    Jan 6, 2004
  4. Shabs
    20
    1,883
    Ed Sirett
    Feb 19, 2004
  5. Paul S
    Glow Worm Boiler Problem
    Paul S, Jan 3, 2007, in forum: UK DIY
    1,207
    Paul S
    Jan 4, 2007
