"Pressostat" for Miele dishwasher
Discussion in 'UK DIY' started by Jon Fairbairn, Mar 21, 2009.
  1. Dishwasher (Miele G638 plus) on the blink: gets to the
    pump-out part of the cycle and sits running the drain pump
    indefinitely (when I got to it this morning it was flashing
    the "drain/inlet" warning light). It fills and empties out,
    but it doesn't stop pumping when empty. I checked the
    obvious bits (drain hose, non-return valve etc) but nothing
    showed.
    So now I've got the covers off and have extracted a thing
    that I'd expect to be a pressure switch,
    <http://www.cyberpieces.com/devis/pieces-detachees-lavage-sechage-g636-0.htm>
    has an image of something with the same part number.
    My questions are:
    * is it actually just a pressure switch (on/off), or have
    these things got more sophisticated since I last fiddled?
    * would one expect to be able switch it by blowing into it?
    I've tried, and while something clearly moves inside,
    there's no click, and the resistance between pairs of
    terminals remains the same (infinite for most pin
    combinations, short circuit for one). This fits with my
    hypothesis that it's running the pump until the pressure
    switch says it's empty, and that never happens, but I
    can't see how to refute it.
    * given that it appears to have adjusting screws (one is
    visible in the centre of the image at the above link, the
    other is in the tube at the very front of the picture),
    can I simply fit a replacement, or will I have to adjust
    it up to fill to the right level? I don't have a service
    manual, so I don't know the procedure.
    For completeness: the numbers printed in black round the
    plastic part are 276974 E-01/09 T.NR.5380960 1200/700 and
    embossed in the plastic are "Type 790", "83067", "8.8169",
    "μ", "T85", and the terminals are numbered 12, 14, 11 and
    the two gaps where terminals might be are both numbered 16.
    I'm sure that's more info than could possibly be of use!
    On-line spare parts suppliers in the UK don't seem to do
    that exact part, but several offer
    <http://www.partmaster.co.uk/cgi-bin/product.pl?PID=973380&query=Miele G640&model=G640&path=67231,108720:128251>
    which looks very similar, but for a more recent model, so
    I'll probably have to phone Miele on Monday.
    Thanks,
    Jón Fairbairn
    http://www.chaos.org.uk/~jf/Stuff-I-dont-want.html (updated 2009-01-31)
  2. Jon Fairbairn
    John Guest
    "Jon Fairbairn" <> wrote in message
    > showed.
    > My questions are:
    > "?", "T85", and the terminals are numbered 12, 14, 11 and
    > Thanks,
    > Jón Fairbairn
    You will probably get threatened to keep quiet! Some folks on this group
    will be mortified that a Miele has a fault - they always claim they are
    perfect.
    John, Mar 21, 2009
  3. Jon Fairbairn wrote on 21/03/2009 :
    > My questions are:
    That is just a pressure switch.
    All those I have come across click when you suck/blow down the pipe,
    though I suppose they might have conceivably have changed to a
    capacitance type. Check the pipe is clear, they do block up other than
    than it would be safe bet to get a replacement switch.
    Regards,
    Harry (M1BYT) (L)
    http://www.ukradioamateur.co.uk
    Harry Bloomfield, Mar 22, 2009
  4. Harry Bloomfield <> writes:
    >> My questions are:
    > the pipe, though I suppose they might have conceivably have
    > changed to a capacitance type.
    That was what I was wondering.
    > Check the pipe is clear, they do block up other than than
    I did that, and fitted it. (I didn't dare try blowing into
    it). Machine still sat there whirring. Misery. Booked a
    call-out, then suddenly thought that the pipes to the new
    switch would be full of air, so poured in a few mugs of
    water to give it something to chew on and tried again.
    Machine ran. Cancelled call out. Happy again.
    Thanks for the advice.
    Jón Fairbairn
    Jon Fairbairn, Apr 18, 2009
  1. RedOnRed
    Miele G645SC Dishwasher Problem
    RedOnRed, Apr 23, 2006, in forum: UK DIY
    29
    4,671
    John Rumm
    Apr 25, 2006
  2. HK
    Miele dishwasher door removal
    HK, Feb 4, 2006, in forum: Misc DIY
    633
  3. How to reset Miele dishwasher?
    , May 21, 2007, in forum: Home Repair
    2,519
  4. RedOnRed
    14
    1,047
    Mike Lane
    Jul 9, 2009
  5. Steve
    Miele G1022 dishwasher
    Steve, Feb 13, 2011, in forum: UK DIY
    337
    Steve
    Feb 13, 2011
