power goes off....breaker is on
Discussion in 'Home Repair' started by Phil, Dec 8, 2005.
  1. Phil
    Phil Guest
    I'm having a problem with an electrical circuit in my home. The power goes
    out only in one section and hours to days later it may come on again for
    no apparent reason and then off again. I was able to isolate the breaker
    when
    power resumed. It's a double 30 amp breaker and it doesn't trip off but
    still no power. It only controls doorbell and an outlet in the garage.
    I've checked for loose wires but haven't found anything. I've flipped the
    breaker on and off and still nothing. I think at one time this was for an
    electric water heater but have switched to gas over 20 years ago. Could
    the breaker be bad? I would appreciate any suggestions.
    thanks in advance.
    Phild
    Phil, Dec 8, 2005
  2. Mikepier
    Mikepier Guest
    Could it be there is a subpanel in your house fed by that 30 amp
    breaker?
    Mikepier, Dec 8, 2005
    > when
    > thanks in advance.
    > Phild
    I'm not sure if anyone has mentioned yet how dangerous this situation
    is? Something is randomly interrupting the current. That causes heat.
    fortunately its only a small load. Still, when its interrupted you
    should take the opportunity to check the continuity of the circuit and
    see where the break is. Shouldn't be that hard.
    Thank you,
    CL Gilbert
    "Then said I, Wisdom [is] better than strength: nevertheless the poor
    man's wisdom [is] despised, and his words are not heard." Ecclesiastes 9:16
    CL (dnoyeB) Gilbert, Dec 8, 2005
  4. jeff
    jeff Guest
    I had a similiar problem. Use a voltmeter to check to see if the
    voltage is gone or if it is just low. My power would fluctuate between
    60 and 0 (which made the whole circuit garbage). After checking
    everything I discovered that there was a problem with a neutral wire
    (it was had all of the power).
    I ended up having to find a hidden junction box in the cieling where
    two circuits connected into one and one section of wire needed to be
    replaced. After rewiring the junction box and replacing the one wire,
    everything was fine. My water heater too was connected to everything
    else. Turns out that it had a direct line - someone just wired in the
    new one wrong and crossed some circuits or something.
    jeff, Dec 8, 2005
  5. mm
    mm Guest
    On Thu, 08 Dec 2005 13:56:29 GMT, "David Martel"
    <> wrote:
    >Phil,
    > Do you own a voltmeter? When the power goes off in that section turn
    >off the main breaker and test continuity across the suspect breaker. It
    NEVER test continuity before testing voltage, especially when dealing
    with more than 3 volts.
    If the breaker is bad, or even if it is just off (as is recommeded in
    the first two lines above), you'll be putting 110 volts or more across
    the continuity tester. Only neon bulbs are designed for that. No
    voltmeter/multimeter is. Some of them may be protected against that,
    but many are not, and who knows which are which, and I wouldn't want
    to rely on the protection anyhow.
    Test the * voltage* when the breaker is ON. Test at the screw
    terminal on the left or right. The center is inaccesible and that's
    ok.
    IF the voltage isn't what the voltage is at other circuit breakers
    (240, 220, 120, 117, 110, or maybe lower during a brown-out) the CB is
    bad. Turn off the main CB and only then remove this CB.
    When it is all the way out of the box, then you can check it for
    continuity, but even if it passes, don't forget that this circuit
    works sometimes and doesn't work all the time. That's what you said.
    Buy a new CB. They are cheap. If you are like me you can save the
    old bad one for when the next one fails (which may well never happen.)
    and you can't get to the store. Mark it "BAD". Or you can cut it
    open and see what is inside. (Not too much, but there will be pitted
    contacts most likely.)
    Also there is some difference between passing a continuity test with
    1.5 or 3 or 9 volts DC and minimal current, and actually working with
    110 volts AC. I'm thinking there would not likely be in this case,
    but bear it in mind. Voltage testing of a A) circuit with voltage
    present is sometimes more reliable than resistance testing of B)
    individual parts with voltage off. (This situation is neither A nor
    B, because turning the CB off doesn't disconnect the CB from the power
    at one end or from the ground at its other end.)
    >may be bad. A water heater circuit should not have any other
    >connections on it so I'm surprised that this breaker affects anything in
    >your house. If someone took out the water heater and then spliced into the
    >wire and used it to create new circuits the splices may have been done
    >badly. These splices should be in a junction box near the old heater. With
    >the power off check and redo these splices. If the splices are wire nuts
    >without a junction box put them in a junction box.
    >Dave M.
    Remove NOPSAM to email me. Please let
    me know if you have posted also.
    mm, Dec 8, 2005
  6. Andy
    Andy Guest
    Andy writes:
    When I have had intermittent problems like that, it usually turned
    out to be a bad connection. Sometimes the romex is daisy chained
    and connections are made with wire nuts. The connections get
    flaky and heat builds up, causing the wire to expand. This can either
    open a connection, which will then close again when the wire cools
    off or something jiggles it. I had to locate it by finding the outlet
    that was bad, and tracing the romex in the walls or ceiling back,
    box by box, and checking the connections. It can occur with
    wire nuts or on receptacles, or in a light fixture --- almost anywhere
    along the line.
    Andy
    Andy, Dec 8, 2005
  7. volts500
    volts500 Guest
    Phil wrote:
    >Could the breaker be bad?
    Breakers have been known to go bad like that. You may want to replace
    it, or at least switch the wire(s) to another breaker to see if the
    problem goes away. Don't use a 30 amp replacement breaker though, try
    a 15 amp.
    volts500, Dec 8, 2005
  1. Mike Hibbert
    17
    564
    Bob Eager
    Jan 25, 2004
  2. andy everett
    338
    andy everett
    Jul 10, 2003
  3. Tom
    336
  4. Replies:
    375
  5. Replies:
    236
    Fat-Dumb and Happy
    Jul 10, 2013
Share This Page
