Poulan Chainsaw Won't Oil Bar And Chain
Discussion in 'Home Repair' started by Ron, Jan 4, 2006.
  1. Ron
    Ron Guest
    I have a Poulan 1950 LE Woodshark that is not oiling the bar and chain.
    I drained out the oil, checked the screen, (which was clean) took off
    the side cover that holds the bar and shot WD-40 thru the hose's that
    run back to the reservoir to make sure they weren't blocked. (WD-40
    flowed freely)
    I also cleaned the oil holes and the grove in the bar.
    Then I reassembled the saw, filled it with oil, ran it, with no signs
    of oil flowing onto the bar/chain.
    Then I ran it with the side cover off and w/o the bar, no oil flowing
    from the port/tube.
    The saw is only a yr old and I've only made about 100 cuts with it,
    what could be the problem?
    It's obvious to me that the oil isn't being pumped, is this a common
    problem with Poulan or did I just get a lemon?
    And, is this an easy fix?
    Ron, Jan 4, 2006
  2. Ron
    Ron Guest
    > flowed freely)
    > from the port/tube.
    Ron, Jan 5, 2006
  3. Ron
    Guest
    It's known as a fairly cheaply made saw. Sounds as if you did all the
    stuff you should have. If you get no help here, try posting at the
    misc.rural usenet forum, or, alternatively on www.gardenweb.com in the
    toolshed forum.
    I'm not much at small engine mechanics....
    If you will be using a saw much, you might try stepping up to an echo,
    Husky or stihl, you might be able to get a used one from a local dealer
    for not too many million....
    , Jan 5, 2006
  4. Ron
    Ron Guest
    > toolshed forum.
    Thanks, I'll try there.
    BTW, no I don't use it much. Like I said, I've only made about 100 cuts
    with it in a little over a yr. Just enough time for the warranty to run
    out. I could take it back to Home Depot but they don't carry that saw
    anymore. I might just try taking it back anyway maybe they'll give me a
    credit.
    Ron, Jan 6, 2006
  5. Ron
    Colbyt Guest
    "Ron" <> wrote in message
    > flowed freely)
    > from the port/tube.
    It is an easy fix. Just buy a new oil pump and install it.
    You can order from your parts diagram or at any parts place.
    Why did it fail? I can't say but a new pump solved my problem after I had
    done all the things you have done.
    Colbyt
    Colbyt, Jan 7, 2006
  6. Ron
    Levon Guest
    put some windex on it
    "Colbyt" <> wrote in message
    news:pFRvf.690265$_o.367634@attbi_s71...
    > news:...
    > > flowed freely)
    > > from the port/tube.
    > Colbyt
    Levon, Jan 7, 2006
  7. Ron
    Ron Guest
    > news:...
    > > flowed freely)
    > > from the port/tube.
    > Colbyt
    Sorry if this post twice, friggen Google.
    I found an oil pump locally, what part of the saw do I need to take
    apart to replace the oil pump?
    Thanks, Ron
    Ron, Jan 8, 2006
  8. Ron
    Ron Guest
    > news:...
    > > flowed freely)
    > > from the port/tube.
    > Colbyt
    Do you have the same saw ?
    Ron, Jan 8, 2006
  9. Ron
    Ron Guest
    > and install it.
    OK, I located a new oil pump (locally) what part of the saw do I need to
    take apart to gain access to the pump?
    Thanks, Ron
    Ron, Jan 9, 2006
  1. Michael Baugh
    Chain and bar oil
    Michael Baugh, Oct 28, 2003, in forum: Home Repair
    12
    625
    Marilyn and Bob
    Oct 30, 2003
  2. Bruce
    475
    Harry K
    Jul 8, 2004
  3. dean
    Do you use bar oil in your chainsaw?
    dean, Jun 22, 2005, in forum: Home Repair
    132
    2,562
  4. yddraig
    Upsizing chainsaw bar and chain
    yddraig, Jul 25, 2007, in forum: Home Repair
    382
  5. Tony
    494
