Potterton EP2002 Programmer - Intermittent fault
Discussion in 'UK DIY' started by Fresh_Air_Rider@Hotmail.com, Aug 21, 2006.
  1. Guest
    Hi all
    I have a Potterton EP2002 Programmer, for controlling my central
    heating system, which has suddenly started to behave erratically. By
    that, I mean that it sometimes works continuously for perhaps tweleve
    hours and then stop working and the LCD goes blank. Other times, it
    runs for a few minutes and then stops before running again for another
    few minutes.
    I'm buy no means an expert, but could anyone please reassure me that if
    I ordered a replacement programmer and attached it to the existing back
    plate, it would resolve the problem ?
    I'm just guessing that it might be a capacitor or something within the
    programmer that has failed.
    There have been a lot of thunderstorms in my area lately and I just
    wondered if that might be a contributory factor.
    Could it be something else such as the rechargable battery that needs
    replacing or even the backplate itself that is not providing a good
    connection ?
    I'd be very greatful if someone could please give me some advice on
    this one.
    Best regards
    David
    , Aug 21, 2006
  2. raden
    raden Guest
    In message <>,
    writes
    >Hi all
    >this one.
    From your description, it sounds like it's fucked
    the control chain inside is literally controller - transistor - relay
    geoff
    raden, Aug 28, 2006
  3. In article <>,
    > few minutes.
    To try and identify the problem, does the clock still keep time when the
    display goes blank?
    Almost certainly.
    > connection ?
    The device will still work normally if the battery fails - except during a
    power cut.
    It would certainly be worth isolating the circuit, removing the programmer
    and checking the security of the wiring to terminals, and that it's
    getting a constant power supply - although the battery should keep it
    going if this was the fault, and of course it wouldn't operate the
    heating.
    But my guess would be a dry solder joint on the device PCB. It should be
    possible to fix this - if you're into electronics. But not economical to
    pay someone to do it.
    If you do have to replace it you might consider doing so with the 6002
    which has 7 day programming. Think it's the same price.
    *A fool and his money can throw one hell of a party.
    Dave Plowman London SW
    Dave Plowman (News), Aug 28, 2006
  1. Graeme
    Potterton EP2002 Controller
    Graeme, Jan 4, 2005, in forum: UK DIY
    1,262
    Graeme
    Jan 4, 2005
  2. Dopey
    7,318
    Set Square
    Sep 17, 2005
  3. Replies:
    970
    raden
    Jan 14, 2006
  4. raden
    1,676
    Edward W. Thompson
    Nov 29, 2006
  5. Replies:
    3,162
    peterc
    Feb 23, 2011
Share This Page
