pop up waste sheath/cover
Discussion in 'UK DIY' started by sanjaybhandari1@googlemail.com, Aug 13, 2007.
  1. Guest
    i am trying to remove the cover sheath (circular chrome) in order to
    remove pop up waste pleas advise...ps there is not a little screw at
    the bottom
    , Aug 13, 2007
  2. Stuart B Guest
    On Mon, 13 Aug 2007 08:27:36 -0700, ""
    >the bottom
    Why did you start another thread about the same subject . I did tell
    you what to do . Otherwise have a look behind the bath overflow to see
    if there is anyhting there holding it on but more likely it is a push
    fit but with time it will have become stuck so just prise or pull it
    off. Wrap a towel or cloth round the cap and heave and twist .
    Stuart
    Stuart B, Aug 13, 2007
  3. Guest
    > >the bottom
    > Stuart
    will try thanks
    sorry i am new to this thread business thanks stuart
    , Aug 13, 2007
  1. thescullster
    Pop Up Waste Lever Leak
    thescullster, Aug 11, 2004, in forum: UK DIY
    861
    Andrew Gabriel
    Aug 11, 2004
  2. Jon
    Pop Up Waste
    Jon, Dec 31, 2004, in forum: UK DIY
    451
  3. Replies:
    544
    BigWallop
    May 19, 2005
  4. TheScullster
    Pop Up Waste Questions
    TheScullster, May 11, 2007, in forum: UK DIY
    249
    Ed Sirett
    May 11, 2007
  5. Bod
    382
    Lobster
    Dec 9, 2007
