Plate question for closet built on concrete slabs
Discussion in 'Misc DIY' started by noname87@hotmail.com, May 12, 2006.
  1. Guest
    I am building a closet in my family room which has a concrete slab
    floor (on ground level) covered with linoleum tiles (think 1960). Do I
    need to use pressure treated 2x4 for the bottom plates? Thanks for any
    ideas.
    , May 12, 2006
  2. Guest
    no
    , May 12, 2006
  3. RicodJour Guest
    > ideas.
    On top of the linoleum tile PT plates are really not necessary. As
    long as there's no history of moisture seeping up through the floor or
    frequent mini-floods from inattention to laundry sink blockage or some
    such. Having said that, would I use PT plates? Probably.
    The major disdvantage nowadays is the ACQ chemicals used in PT lumber.
    It's much more corrosive to standard fasteners and you should use
    either stainless steel, epoxy-coated or galvanized fasteners that
    specifically list their suitability for ACQ contact.
    RicodJour, May 12, 2006
  4. John McGaw Guest
    > ideas.
    Need? No. At least assuming that the slab is dry under all conditions.
    But for the difference in price between untreated and treated it
    certainly shouldn't break the budget if it makes you feel better to use
    treated and down the line somebody may well thank you for your foresight.
    John McGaw
    [Knoxville, TN, USA]
    http://johnmcgaw.com
    John McGaw, May 12, 2006
  5. Guest
    Thanks for the replies.
    , May 13, 2006
  6. Guest
    If it was built in 1960, none of the other bottom plates are PT. I'd
    use regular 2x4's
    , May 13, 2006
  1. Stephen Gower
    Getting rid of concrete slabs
    Stephen Gower, Jan 22, 2004, in forum: Misc DIY
    1,559
    Sneezy
    Jan 22, 2004
  2. Broadback
    Making concrete slabs
    Broadback, Feb 17, 2006, in forum: Misc DIY
    445
    Ian Stirling
    Feb 17, 2006
  3. Mary Fisher
    Weight of concrete slabs
    Mary Fisher, Jun 22, 2006, in forum: Misc DIY
    23
    1,075
    John Cartmell
    Jun 25, 2006
  4. Greystoke
    13
    937
    Mathew Newton
    Aug 24, 2006
  5. benpost
    built in or built under single oven?
    benpost, Jan 25, 2008, in forum: Misc DIY
    875
    Lobster
    Jan 25, 2008
