Planing a door.
Discussion in 'Misc DIY' started by mark.hannah@totalise.co.uk, Oct 26, 2007.
  1. Guest
    If I am going to plane the bottom and sides of a door to fit a frame,
    can I get away with using my current "smoothing" #4 plane, or should I
    invest in a #5?
    Mark.
    , Oct 26, 2007
  2. NoSpam Guest
    > invest in a #5?
    > Mark.
    A cheap electric plane is much faster, but make sure you back-up the
    "exit edge" when working on the bottom or the grain may split
    (alternatively work towards the centre).
    Dave
    NoSpam, Oct 26, 2007
  3. Guest
    > > invest in a #5?
    > > Mark.
    > Dave
    I've never understood how to plane to the center - surley you are
    going to end up either missing bits, or planing the same bit twice?
    Mark.
    , Oct 26, 2007
  4. NoSpam Guest
    >>> invest in a #5?
    >>> Mark.
    >> Dave
    > Mark.
    Agreed that it's not the best way, but draw a line first and just plane
    down to it.
    .... and don't call me Shirley ;-)
    Dave
  5. Roger Mills Guest
    > invest in a #5?
    > Mark.
    The longer the better. A No.4 is just about ok, but longer is better.
    You'll struggle with a hand plane on the end-grain at the top and bottom - a
    power planer is far better. But a hand plane gives better control on the
    vertical edges.
    Cheers,
    Roger
    ______
    Email address maintained for newsgroup use only, and not regularly
    monitored.. Messages sent to it may not be read for several weeks.
    PLEASE REPLY TO NEWSGROUP!
    Roger Mills, Oct 26, 2007
  6. Roger Mills Guest
    >>> frame, can I get away with using my current "smoothing" #4 plane,
    >>> or should I invest in a #5?
    >>> Mark.
    >> Dave
    > Mark.
    You need to 'feather' it - by lifting the plane slightly as you approach the
    overlap area in the middle. Or, having seen off the end grain with a power
    plane, you're probably better off doing the centre section with a hand
    plane.
    Cheers,
    Roger
    ______
  7. In article <>,
    writes:
    That might not work well with an electric plane as you need to switch
    direction so the timber is planed in both directions roughly an
    equal number of times. This is to prevent microscopic error in
    the parallelism of the rotor axis and sole plate accumulating and
    creating a bevel. Planing into the centre means timber (at any one
    point) is always planed in same direction. You should use scrap
    pieces against the exit edges (both of them).
    Andrew Gabriel
    [email address is not usable -- followup in the newsgroup]
    Andrew Gabriel, Oct 26, 2007
  8. John Rumm Guest
    > invest in a #5?
    For top and bottom of a door, I just use a circular saw and a clamped
    batten. You can take of fractions of a saw kerf this way if you want and
    don't get any of the splintering problems. I then just use a powered
    plane for taking sharp corners off, and shooting in the sides if
    required. (although I often find wedging the frame a better way to fix
    uneven gaps)
    http://wiki.diyfaq.org.uk/index.php?title=Hanging_a_door
    Cheers,
    John.
    | Internode Ltd - http://www.internode.co.uk |
    | John Rumm - john(at)internode(dot)co(dot)uk |
    John Rumm, Oct 27, 2007
  9. Stuart Noble Guest
    > batten.
    Any other method amounts to masochism
    Stuart Noble, Oct 27, 2007
    >> batten.
    Agreed - the only way to go. Sawboard even better, stops the top edge
    splintering.
    Dave - The Medway Handyman
    www.medwayhandyman.co.uk
    01634 717930
    07850 597257
    The Medway Handyman, Oct 27, 2007
  11. Sam Guest
    >invest in a #5?
    >Mark.
    I use an electric plane for this purpose but I've never understood
    what all the different types of hand plane are. What is a #5, #4, etc?
    TIA
    Sam, Nov 6, 2007
    #11
  12. Guest
    On 26 Oct, 14:19, "Rambelt" <> wrote:
    > <> wrote in message
    > news:...> If I am going to plane the bottom and sides of a door to fit a frame,
    > > invest in a #5?
    > > Mark.
    > There must be a technique, when planing the top or bottom of a door, for
    > removing the same amount from the side members (across the grain) as from
    > the top or bottom components (with the grain), but I haven't discovered it.
    > Gave up years ago and now use an electric planer for that job (and most
    > others). When planing the top or bottom start the cut off at each side of
    > the door and finish somewhere in the middle or else you'll spall off the
    > wood on the surface of the side pieces.
    > Sorry about the lack of knowledge of the technical terms for the components
    > of a door, I'm sure you will follow what I mean.
    The top and bottom parts of the door (the horizontal elements) are the
    rails. The side parts (vertical) are called stiles. The central
    vertical dividing parts are called muntins, but you'll not be
    bothering them with your plane.
    Edward
    , Nov 6, 2007
    #12
  13. Guest
    The numbers refer to the old Stanley model numbers. The No.4 is 2.5"
    wide and No.5 is 3" wide (and 9.5" and 10.5" long respectively).
    They're known as smoothing planes. No's 6, 7, 8 are longer versions of
    the No.5 (and known as jack, fore and jointing planes respectively -
    although my memory may be faulty on that).
    The very long planes are really for edge jointing long boards where a
    long and very flat side is required. Most jobs can be done with a No.
    4. It's weight is reasonable, and handle big enough to be comfortable.
    There are also No's 3, 2, 1 going down in size, but they're much less
    common (or useful).
    I'd agree for trimming doors, circular saw and guide batten is the way
    to go - it's not a job that requires fraction of a mm precision. But
    nothing produces a beautiful wood surface like a hand plane - not
    saws, not thicknessers, not power planes. There's also lot's of spots
    where it's easier and produces better results to use a hand plane.
    Hand planes can also do precise fitting (and shooting-in) that only a
    router can equal (though they can also do lots of other stuff) - and
    do it without all the set-up. The downside is of course the skill
    required both to sharpen and set up a hand plane well and to use it
    well. A hand plane will always be slower as well, but you can cross-
    plane can get wood off quickly.
    I'm not saying hand tools are best, and there's a substantial learning
    curve to skilled hand plane usage - but in some jobs it still has no
    equal.
    , Nov 6, 2007
    #13
  1. Mr Fiendish
    planing technique advice please!
    Mr Fiendish, Oct 11, 2003, in forum: UK DIY
    302
    Peter Ashby
    Oct 11, 2003
  2. Tony Wood
    1,455
  3. Tim
    769
    The Natural Philosopher
    Jan 15, 2004
  4. Replies:
    408
  5. Samantha Booth
    Planing a door
    Samantha Booth, Jun 6, 2008, in forum: Misc DIY
    62
    1,543
    Dave Liquorice
    Jun 8, 2008
