PEX pipe causes cancer
Discussion in 'Home Repair' started by Oren, Apr 2, 2010.
  1. Oren
    Oren Guest
    On Thu, 01 Apr 2010 22:58:20 -0600, wrote:
    >It's just been announced by the Department of Health that the
    >chemicals used in the manufacture of PEX pipe cause cancer when these
    >pipes are used for drinking water. The chemicals leech into the water
    >and accumulate in the body. This is particularly evident for hot
    >water, since the heat extrudes the carcinogen more than cold water.
    >PEX pipe will likely be banned nationwide by the end of 2010. They
    >warn that if you have PEX pipe in your home, DO NOT drink the water,
    >or use the water for cooking. Boiling the water only concentrates the
    >harmful chemicals, so boiling will not make the water safe. Worse yet
    >are those homes who have chlorinated water. The chlorine in the water
    >is causing these harmful chemicals to leech into the water as much as
    >five times the concentrations above that of standard water.
    >The best solution is to remove all PEX pipes from your homes and
    >businesses and replace them with copper, steel, or other conventional
    >plumbing. If you do replace the PEX pipes, be sure to drain and
    >thoroughly flush your hot water heater, since heavy concentrations of
    >the harmful chemicals will remain in the tank.
    >Peter Sherman
    Bullshit!!
    Oren, Apr 2, 2010
  2. Oren
    Tony Hwang Guest
    >> Peter Sherman
    > Bullshit!!
    Hmmm,
    April fools!
    Tony Hwang, Apr 2, 2010
  3. Oren
    Guest
    Peter Sherman
    , Apr 2, 2010
  4. I'd sure like to see a link to this, on the web. Dept of
    health in which jurisdiction?
    Christopher A. Young
    Learn more about Jesus
    www.lds.org
    <> wrote in message
    the
    when these
    the water
    for hot
    water.
    2010. They
    the water,
    concentrates the
    Worse yet
    the water
    as much as
    and
    conventional
    and
    concentrations of
    Peter Sherman
    Stormin Mormon, Apr 2, 2010
  5. Oren
    Joe Guest
    <> wrote in message
    But only in California.... so no worries...
    Joe, Apr 2, 2010
  1. Lifetime of PEX pipe?
    , Nov 3, 2008, in forum: UK DIY
    380
    Grimly Curmudgeon
    Nov 3, 2008
  2. Replies:
    1,362
  3. pipe heating tape causes fire
    , Mar 4, 2008, in forum: Home Repair
    334
  4. Tim Streater
    393
    Tim Streater
    Feb 29, 2012
  5. Oren
    Chavez Dies After Battle With Cancer
    Oren, Mar 6, 2013, in forum: Home Repair
    10
    338
