Permanently sticking "self-adhesive" floor tiles
Discussion in 'Misc DIY' started by Clive, Sep 23, 2009.
  1. Clive
    Clive Guest
    I have put down some cheap vinyl floor tiles on a cement floor
    surface. It's a temporary job - honest ! However, a few (thankfully
    few) tiles are lifting at the edges. What is the best adhesive to
    really stick them down?
    I'm thinking:
    "No nails" type adhesive
    Bathroon/kitchen mastic
    Contact / impact adhesive (can't remember if this has an "official"
    name) - the type used to stick "non-self-adhesive" vinyl floor tiles
    Any other suggestions?
    Clive
    Clive, Sep 23, 2009
  2. Clive
    NT Guest
    On Sep 23, 2:56 pm, Clive <> wrote:
    > Hi,
    > I'm thinking:
    > Thanks
    > Clive
    I tried everything bar conctact adhesive, and all failed except one.
    What worked was bitumen. Clean the adhesive off the tiles round the
    edges using loo roll and paraffin. Apply roofing bitumen adhesive and
    put weights on the tiles, leaving till set, which takes a couple of
    days iirc.
    NT
    NT, Sep 23, 2009
    >> Hi,
    >> I'm thinking:
    >> Thanks
    >> Clive
    > days iirc.
    > NT
    you should have dried contact. That really DOES work
    The Natural Philosopher, Sep 23, 2009
  4. Clive
    bof Guest
    In message
    Clive <> writes
    >Hi,
    >I'm thinking:
    So long as the cement floor is solid my first choice would be contact
    adhesive
    bof at bof dot me dot uk
    bof, Sep 23, 2009
  5. Clive
    NT Guest
    > days iirc.
    > NT
    > Don't forget the clothes' pegs .......... for your nose!
    > If it's anything like the bitumen paint, that stuff stinks - particularly
    > indoors where smell seems to concentrate.
    > Phil
    I used wickes, no pong
    NT
    NT, Sep 23, 2009
    Contact adhesive will work but will be a PITA when this "temporary"
    floor needs to be lifted. It will stick to the concrete and be a
    right begger to get off, depending on what the permenant floor will
    be this may or may not be a problem of course.
    Cheers
    Dave.
    Dave Liquorice, Sep 24, 2009
  7. Clive
    RobertL Guest
    On Sep 23, 10:18 pm, bof <> wrote:
    > In message
    > Clive <> writes
    > >Hi,
    > >I'm thinking:
    > adhesive
    one day you will want to take them off again.
    Robert
    RobertL, Sep 24, 2009
  8. Clive
    bof Guest
    In message
    RobertL <> writes
    >> In message
    >> Clive <> writes
    >> >Hi,
    >> >I'm thinking:
    >> adhesive
    Well the thread subject is "Permanently sticking", and in this
    particular case it's just a "few" "lifting at the edges".
    bof, Sep 25, 2009
  1. Clive Long,UK
    Purchasing self-adhesive cork floor tiles
    Clive Long,UK, Nov 30, 2003, in forum: Misc DIY
    780
    Clive Long,UK
    Nov 30, 2003
  2. Replies:
    889
  3. Borked Pseudo Mailed
    sticking self-adhesive tiles to acrylic paint?
    Borked Pseudo Mailed, Apr 16, 2008, in forum: Misc DIY
    357
    Apr 16, 2008
  4. cgmsys
    394
    cgmsys
    May 10, 2007
  5. Jim K
    397
