Painting upvc door and frame
Discussion in 'Misc DIY' started by David Parry, Jan 18, 2004.
  1. David Parry
    David Parry Guest
    Can anyone advise on the best primer to use on the outside faceof a upvc
    door.
  2. David Parry
    rob Guest
    "David Parry" <> wrote in message
    news:qUDOb.81$-net.net...
    > door.
    > Best advice I can give, is not to paint it. You will find that however
    well you do it , the paint will eventually peel off, and will look ten times
    worse .
    With the expansion and contraction of the plastic , even the very best of
    paints will eventually come off.
    Is the door so bad that you cant refurbish it with special cleaners
    available from upvc manufacturers instead.????????
    rob
    rob, Jan 18, 2004
  3. David Parry
    BigWallop Guest
    > door.
    You don't paint them, you wash them down and take any scratches out with
    toothpaste and a damp cloth. Any deep scratches can be sanded out and
    filled with decorators caulk to make them look good again.
    Acrylic paints can dissolve the PVC, so shouldn't be used. Gloss paints
    make the PVC go tacky by melting through the surface coating and damaging
    the bond between the base and polished coatings. Water based paints don't
    really stick to well to polished coatings so eventually wash off in the
    rain.
    http://www.basecuritysystems.no-ip.com
    Version: 6.0.563 / Virus Database: 355 - Release Date: 17/01/04
    BigWallop, Jan 19, 2004
  4. David Parry
    BB10
    Apr 24, 2011
    Painting UPVC Doors
    Hi, First clean off surface area with warm water and detergent (washing up liquid is fine). Once dry apply 'Owatrol' E.S.P solution as advised by the manufacturer (dampen cloth with solution and wipe over surface area). Once dry apply an thinned down undercoat (thin down with white spirit). It may be necessary to apply an additional undercoat (not so thin) before applying the finish coat.......I agree that painting UPVC is not ideal but was recently asked by a customer to do this. I will be keen to find out over time whether my process has been successful. Good luck.
    BB10, Apr 24, 2011
  1. SW
    1,426
    Dave Plowman
    Jan 9, 2004
  2. Mitch
    726
    Colin Wilson
    Jul 16, 2004
  3. Some-Hope!
    1,763
    The Natural Philosopher
    Jun 27, 2006
  4. Gogs
    UPVC Door/Frame Problem
    Gogs, Jun 26, 2007, in forum: Misc DIY
    451
  5. Al Shahadie
    406
    Al Shahadie
    Sep 21, 2012
