Painting an asphalt tile floor?
Discussion in 'Misc DIY' started by bgrosser@gmail.com, Jan 29, 2006.
  1. Guest
    I have an asphalt tile floor most likely laid in the 50's. It's your
    standard 9x9 tile, brownish in color, with flecks of this and that. I
    also realize it may have asbestos in it.
    I want to paint it it a light gray. The tile is hard and glossy, so I
    started looking into primers that could work with that kind of surface.
    I had some zinsser 1-2-3 around so I painted a small patch. The next
    day I cut an X into the primer with a razor blade, stuck some scotch
    tape down, and yanked it up. Little bits of the primer came up with
    it. So, that didn't seem like it was adhering well enough.
    Looking at paint manufacturers I saw that Sherwin Williams has what
    they call a 'bonding primer' which is intended for hard, glossy, smooth
    surfaces. I went to a sherwin williams store, and asked about it. The
    guy there said it wouldn't work for what I want. He said it works well
    on walls but that it wouldn't stand up to the use a floor would get.
    Anyone have any ideas? I can't sand or etch because of the potential
    asbestos content. I don't want to remove it for the same reasons (and
    I'm not looking for a job that big right now). I really want to paint
    this floor, though. Has anyone tried this and been successful?
    thanks
    , Jan 29, 2006
  2. Guest
    Is it 9x9 or 8x8. I believe 8x8 from that era is asbestos.
    Why do you want to paint it so bad, it doesn't seem like that would
    ever work.
    , Jan 29, 2006
  3. Guest
    They're definitely 9x9. I suppose it's possible they were laid later
    than the early/mid 50's. I know that the first floor, which was also
    asphalt tile, was laid when the house was built in '53.
    I want to paint it because it's ugly and I want it to be a different
    color. Taking it up and re-prepping the floor for something else and
    then laying something else would be a much larger job. I
    The room is used mostly as an art studio so I don't need it to be
    elegant, just bright and durable.
    One other idea I've had is laying a thin layer of 4x8 sheets of plywood
    down as a new floor, although this would cause issues with the
    baseboard heat, as it would reduce clearance underneath where the air
    enters.
    , Jan 29, 2006
  4. philkryder
    philkryder Guest
    so,,, its an art studio - paint it white with an epoxy garage floor
    paint and "spill" drops of brightly colored streaks and drops over it -
    Redo it when it starts to wear and try something else...
    might be future in it - it worked for Jackson Pollock...
    you'll want to find a very strong chemical stripping agent to remove
    any wax or other coatings...
    then use the bonding primer - then coat...
    It's a floor - don't worry about...
    philkryder, Jan 29, 2006
  5. Mikepier
    Mikepier Guest
    I had the same tile in my basement. I just went over it with new
    Armstromg Vinyl composition tile. Very easy to install. Painting the
    floor might lead to more problems.
    Mikepier, Jan 29, 2006
  6. Guest
    yeah just add another layer of tilke directly over the old, after
    cleaning the old tile real good.
    never sand old tile its a asbestos hazard.
    , Jan 29, 2006
  1. Bill
    old asphalt tile floor
    Bill, Nov 14, 2003, in forum: Misc DIY
    528
    Klaus Der Phauck
    Nov 16, 2003
  2. Pavel314
    Self-stick Asphalt Floor Tile
    Pavel314, Dec 30, 2003, in forum: Misc DIY
    363
    Casey Stamper
    Dec 31, 2003
  3. Bill Gill
    Asphalt tile removal
    Bill Gill, Jan 13, 2006, in forum: Misc DIY
    885
    Bill Gill
    Jan 14, 2006
  4. Mikepier
    432
    Manster
    Oct 27, 2007
  5. Edwin Pawlowski
    Painting over asphalt tile
    Edwin Pawlowski, Nov 3, 2007, in forum: Misc DIY
    431
    professorpaul
    Nov 3, 2007
Share This Page
