Painting a steam radiator
Discussion in 'Misc DIY' started by Chuck Reti, Jul 23, 2003.
  1. Chuck Reti
    Chuck Reti Guest
    My house, mid-20s vintage, is steam heated (boiler was "modernized"
    mid-70s).
    We're redoing a room and I've wirebrushed the ancient flaky paint off the
    radiator. Wondering what's the best repainting solution. Want it to be
    same color as the baseboard and trim, which are painted with an
    off-white semigloss latex. I need to prime the bare metal (not rusty),
    but with oil or water based primer? And can the cover coat be the same
    latex as the trim paint? Any issues re wintertime hot radiator coils and
    paint adhesion or odors? I know there are hi-temp "barbecue grill"
    paints but they're gloss enamels and little color choice.
    Chuck Reti
    Detroit MI
  2. Chuck Reti
    Curly Sue Guest
    On Wed, 23 Jul 2003 12:31:03 -0400, Phil Munro <>
    wrote:
    > Our house is about the same vintage, also with steam radiators of two
    >different kinds. On several we have used a glossy enamel "rustoleum"
    >type of paint. On another we used a latex. In every case we first
    >stripped the old paint off before applying the new paint, and have had
    >NO trouble with the paint coming off -- except the one time we did NOT
    >strip the old paint off.
    How did you strip the paint off?
    Sue(tm)
    Lead me not into temptation... I can find it myself!
    sue at interport dot net
    Curly Sue, Jul 24, 2003
  3. Chuck Reti
    Chuck Reti Guest
    In article <>,
    wrote:
    > On Tue, 22 Jul 2003 22:24:19 -0400, Chuck Reti
    > >mid-70s).
    > >radiator.
    > snip
    > Was this radiator painted with lead paint?
    It may have been, given its age. Having considered that possibility,
    I wore gloves & mask, brushed on a plywood sheet outdoors (no edibles
    growing anywhere, no watershed issues). Swept up what I could and will
    dispose of properly at hazmat dropoff on recycling day. Just trying to be
    Mr. Environmentally correct :).
    Hazards aside, would a lead coat, mostly all removed, affect what should
    go on next?
    Chuck Reti
    Detroit MI
    Chuck Reti, Jul 24, 2003
  4. Chuck Reti
    ameijers Guest
    "Chuck Reti" <chuckr*@No*SPAMmac.com.invalid> wrote in message
    > In article <>,
    > > >mid-70s).
    the
    > > >radiator.
    > > snip
    > go on next?
    If you already have it loose and out of the house (and most of the crud
    off), I'd take it somewhere and have it shotblasted and electrostatic powder
    painted, and NEVER have to mess with it again. Shops that do that can
    probably also clean out the inside, which should make it work better.
    aem sends...
    ameijers, Jul 25, 2003
  5. Chuck Reti
    Curly Sue Guest
    On Fri, 25 Jul 2003 11:48:35 -0400, Phil Munro <>
    wrote:
    > We use a chemical stripper which is very similar to zip strip.
    >I apply it, then scrape with a putty knife, use steel wool, apply some
    >more and steel wool some more. The one I just finished yesterday had
    >some brown paint against the metal. It took a little more effort to
    >remove than places where there was also a top coat of white paint.
    > I have no idea whether any of it is lead paint. Unless sanding or
    >heat is used (and the heat gun does not work on metal surfaces), the
    >lead problem should be minimal.
    Thanks for the reply. Did you know that you can get inexpensive lead
    test kits in the paint department (of, for example, Home Depot)?
    Sue(tm)
    Curly Sue, Jul 25, 2003
  1. BKS
    painting steam radiator pipe
    BKS, May 17, 2004, in forum: Misc DIY
    437
    m Ransley
    May 17, 2004
  2. Michael Stoic
    Steam Radiator - ID and Specs.?
    Michael Stoic, Oct 14, 2004, in forum: Home Repair
    381
    HeatMan
    Oct 17, 2004
  3. Michael Stoic
    Steam Radiator Repair - Epoxy
    Michael Stoic, Oct 21, 2004, in forum: Home Repair
    686
    Edwin Pawlowski
    Oct 25, 2004
  4. fnord
    Steam Radiator thread sealant?
    fnord, Oct 15, 2005, in forum: Home Repair
    397
    Lawrence Wasserman
    Oct 17, 2005
  5. anonomous
    steam radiator valve ?
    anonomous, Oct 23, 2005, in forum: Home Repair
    635
    HeatMan
    Oct 26, 2005
