paint-protection for plywood, to withstand water, snow, etc?
Discussion in 'Misc DIY' started by David Combs, Nov 27, 2008.
  1. David Combs
    David Combs Guest
    Our basement boiler-room (steam-heat, water-heater, other heater,
    all gas) has, up high, a window looking out into a grate-covered
    pit. (Grate at ground-level.)
    For safety from CO, we keep the window open a few inches,
    always, allowing boiler-updraft to drag in fresh air.
    Problem: leaves (southern Westchester county) and then
    snow, potentially 100% covering the grate, dangerously.
    What to put over the grate to keep leaves and snow
    away from it.
    Used to have ugly office-chair rug-protector draped over
    it. Recently the boss (of this house) tossed it out,
    calling it UGLY. (Well, yes, it was -- but it added
    safety.)
    Happens that six months ago I (surrepticiously) retrieved from our garbage
    some old half-inch pieces of plywood.
    My idea is to use one of them to lay one of them across near-grate concrete-blocks,
    to return the room to a "safe" condition.
    To avoid instant UGLY!-judgement, maybe painting it dark-green
    would help.
    QUESTION: how to weatherproof it?
    What kind of paint, primer, brands, number of coats,
    etc?
    THANKS!
    David
  2. David Combs
    Jim Elbrecht Guest
    Right here- if it were me. . . I'd close the window, install a CO
    detector. . . and if it indicates a problem I'd install a pvc
    dedicated vent that only opened when the furnace called for air.
    I've heard that there is some sort of energy thing going on where it
    cost more to heat the great outdoors. I don't know for sure as I've
    been trying to *seal* things up around here- not open them up.
    -snip-
    And invite wood eating insects to live on the warm side of that board.
    Do it right- do it once.
    This is probably the most expensive way out- but at $60, it will
    probably pay for itself in lost heat in a few years- not to mention
    the safety & esthetics 'payback'.
    http://www.myhvacparts.com/Catalogue/Accessories/Termination Kit.htm
    Jim
    Jim Elbrecht, Nov 27, 2008
  3. David Combs
    Ed Pawlowski Guest
    "David Combs" <> wrote in message
    > away from it.
    Sounds like you are making a nice haven for rodents. Very thoughtful of you
    as they like warm cozy places to live. .
    I'd run a proper vent up the side of the building with a screened air intake
    at least 48" above the ground. Not seeing your setup I can't give exact
    methods, but you can replace a window pane and use PVC in periscope fashion,
    or a through the wall vent that is commonly used for fresh air intakes.
    Ed Pawlowski, Nov 27, 2008
  4. David Combs
    Jim Elbrecht Guest
    After sleeping on it, I'd like to correct that. If I had a CO leak,
    I'd *fix* it before somebody died.
    Jim
    Jim Elbrecht, Nov 28, 2008
  5. David Combs
    Guest
    > > away from it.
    I agree, Ed's suggestion is the professional - safe solution. Go
    for it. Don't play around. I also suggest that you follow the
    suggestion to add a CO alarm. I have three in my home. Yea, as a
    teenager I once was caught by CO, I was OK but a few other people
    ended up in the hospital. Nasty Sneaky stuff.
    , Nov 28, 2008
  6. David Combs
    Phisherman Guest
    On Fri, 28 Nov 2008 07:47:11 -0500, Jim Elbrecht <>
    >Jim
    You don't want any detectable CO, it is highly poisonous. Very low
    levels are expected, nor is it practical to remove all CO, as carbon
    dioxide and carbon monoxide are in equilibrium.
    Phisherman, Nov 28, 2008
  7. David Combs
    Guest
    , Nov 28, 2008
  8. David Combs
    David Combs Guest
    In article <>,
    Norminn <> wrote:
    >By covering the grate with plywood, are you not defeating the purpose of
    >the grate? Size and
    >location would help ..... does it have to be at ground level for foot
    >traffic or in driveway?
    Stupid of me to not have said that I would make a half Tee-Pee (sp?)
    out of it, leaning it from the away-from-house-wall edge of the
    grate up against the wall, a foot or two off the ground.
    Sorry!
    David
    David Combs, Nov 29, 2008
  1. Who Cares
    Which plywood for hurricane protection?
    Who Cares, Jul 10, 2003, in forum: Home Repair
    244
    McQualude
    Jul 12, 2003
  2. Replies:
    1,019
  3. Jack
    279
    3,704
    Harry K
    Mar 8, 2010
  4. Replies:
    277
  5. REPJ
    420
