PAINT A FIBERGLASS TUB?
Discussion in 'Misc DIY' started by April Inyard, Apr 20, 2006.
  1. April Inyard
    April Inyard Guest
    I have a blue fiberglass tub that would be more expensive to replace than
    it's worth. Does anyone know if it's possible to refinish a fiberglass
    bathtub? Has anyone done this?
    Thanks!
    April
  2. On Thu, 20 Apr 2006 16:46:49 -0400, "April Inyard"
    >Thanks!
    >April
    No, but I've painted fiberglass boats. You want catalyzed
    polyurethane. Several trade names Awlgrip, Imron. There are others.
    It is expensive, relatively speaking.
    Should be sprayed. Job for a professional unless you are equiped and
    skilled. Cat poly shouldn't be used without the proper respiratory
    protection equipment.
    Frank
    Frank Boettcher, Apr 21, 2006
  3. April Inyard
    Guest
    One more alternative would be to sand the tub evenly dull with
    2000-grit wet paper, and then restore the shine with increasingly finer
    buffing compounds. This is something that is within the capabilities
    of the average DIYer with enough elbow grease. I've taken scratches
    out of my Jacuzzi this way.
    Oh, by the way, never ever scour your tub with the green side of a
    Scotch Bright kitchen sponge.
    , Apr 21, 2006
  1. Thomas Prinzie
    recommend safe cleanser for fiberglass tub?
    Thomas Prinzie, Oct 15, 2003, in forum: Home Repair
    667
    Tom Baker
    Oct 16, 2003
  2. Susan Thomas
    Remove stain from fiberglass tub?
    Susan Thomas, Dec 16, 2003, in forum: Home Repair
    277
    Lewis Campbell
    Dec 17, 2003
  3. Mitch Skool
    Removing built-in tub/shower (fiberglass)
    Mitch Skool, Jan 30, 2004, in forum: Misc DIY
    338
    Speedy Jim
    Jan 30, 2004
  4. Rick Shaw
    Modifying a fiberglass shower/tub
    Rick Shaw, Jul 14, 2004, in forum: Misc DIY
    675
  5. blueman3333
    904
    Jim Yanik
    Feb 6, 2007
