Noisy tap
Discussion in 'UK DIY' started by Paul Tomlinson, Feb 23, 2004.
  1. Hi
    I've just replaced my utility room basin and tap and find that the
    cold tap (fed with mains pressure) is very noisy, especially when half
    open. Its the sound of the water, but I don't remember the old tap
    making anywhere near as much noise. The new tap is a monobloc design
    with a lever, rather than rotary. The plumbing is standard 15mm
    soldered joints except for compression fittings mating to the tails
    screwed into the tap itself.
    The mains water pressure is good but I wouldn't say excessive. The
    room is on the ground floor. The kitchen tap, also on the ground
    floor, doesnt suffer from the same problem.
    Any ideas ?
  2. Paul Tomlinson
    Lee Guest
    Paul Tomlinson wrote:
    > Hi
    > Any ideas ?
    Exactly the same problem here. Also with a ceramic type basin tap.
    Strangely the bath tap is identical design and fed from the same pipe,
    but is not noisy.
    The mains water here is very aerated though, which is what think is
    causing the noise in our case. Restricting the flow by opening another
    tap stops the noise, so I'm thinking of fitting a flow restricter :)
    Lee
    To reply use lee.blaver and ntlworld.com
    Lee, Feb 23, 2004
  3. Paul Tomlinson
    Harry Ziman Guest
    I had this once and used a service valve that I had already fitted in the
    pipework to throttle back the flow slightly. Worked fine.
    "Lee" <> wrote in message
    news:c1dene$1h69j9$-berlin.de...
    > > Hi
    > > Any ideas ?
    > but is not noisy.
    > Lee
    Harry Ziman, Feb 23, 2004
  4. Paul Tomlinson
    rob Guest
    > > Hi
    > > Any ideas ?
    > but is not noisy.
    >current water regs mean you should have an isolation valve on the hot and
    cold. you can then close off the supply valve slightly to reduce the flow.
    rob
    rob, Feb 23, 2004
  5. Paul Tomlinson
    Glenn Guest
    rob
    Only on new plumbing surely ?
    Glenn
    Glenn, Feb 23, 2004
  1. Simon Avery
    Noisy new external tap.
    Simon Avery, Nov 4, 2003, in forum: UK DIY
    919
    Simon Avery
    Nov 6, 2003
  2. Yitzak
    828
    Yitzak
    Oct 11, 2004
  3. Replies:
    436
    Roger Mills \(aka Set Square\)
    Feb 6, 2006
  4. not available
    Noisy Tap
    not available, Feb 21, 2006, in forum: UK DIY
    456
  5. Replies:
    520
    Roger Mills
    Dec 11, 2006
