Newel post removal
Discussion in 'UK DIY' started by Cordless Crazy, Sep 13, 2005.
  1. Anyone know the best way to remove and replace either the upstairs o
    downstairs newel post without hacking and butchering the staircase
    which I want to retain
    Cordless Crazy
  2. Set Square
    Set Square Guest
    Cordless Crazy <> wrote:
    > Anyone know the best way to remove and replace either the upstairs or
    > downstairs newel post without hacking and butchering the staircase,
    > which I want to retain?
    If at all possible, keep the bottom foot of so of the old newel post which
    is firmly attached to the staircase. Cut it off at the appropriate level,
    bevel the top, and fit a new upper section. You'll find lots of good
    information and "How to" guides on the Richard Burbidge site at
    http://www.richardburbidge.co.uk/main.asp?page=270
    Burbidge also do a video which most sheds sell for about a fiver which shows
    you how to renew newels and bannisters etc. Well worth the money - and
    refundable if you buy your kit from them.
    Cheers,
    Set Square
    ______
    Please reply to newsgroup. Reply address is invalid.
    Set Square, Sep 13, 2005
  3. Stuart Noble
    Stuart Noble Guest
    Not easy to get a square cut at this angle. It's worth clamping a
    section of 4 x 2 to the base as a saw guide.
    Stuart Noble, Sep 14, 2005
  4. Set Square
    Set Square Guest
    Chris Bacon <> wrote:
    >> which shows you how to renew newels and bannisters etc. Well worth
    >> the money - and refundable if you buy your kit from them.
    > Refundable? I'm not surprised! That's about the cost of a single
    > spindle from them (they are, IMO, *very* expensive).
    It's expensive if you buy from the sheds. I got all my stuff from a
    Builder's Merchant at nearly 40% below the retail price.
    The video is worth a fiver - even if you don't get it refunded - or even if
    the do the job with non-Burbidge products. The principles are the same.
    Cheers,
    Set Square
    ______
    Set Square, Sep 14, 2005
  5. Set Square
    Set Square Guest
    Stuart Noble <> wrote:
    >> which is firmly attached to the staircase. Cut it off at the
    >> appropriate level, bevel the top, and fit a new upper section.
    I cut through 2 sides of mine with a circular saw, using a clamped-on piece
    of wood as a guide for each cut - and then finished off with a hand saw.
    This gave a nice square cut. Then I put a suitably sized polish tin against
    each vertical face and drew round it to get a nice rounded top shape - which
    I achieved with a hand plane. You can see the general effect in this rather
    grainy photo.
    http://www.hampton-magna.freeserve.co.uk/after.JPG
    If anyone is interested, I could take a close-up of the relevant bit of the
    newel post.
    Cheers,
    Set Square
    ______
  6. Grumble
    Grumble Guest
    > the
    > newel post.
    > Cheers,
    > Set Square
    Very flash, I haven't seen spindles like that before. Do they come pre-cut
    to size and you fit the handrail accordingly? I wouldn't like to have to cut
    each one. How about the spindles on the landing, would they be the same
    length as the stairs?
    Grumble
    Grumble, Sep 14, 2005
  7. Set Square
    Set Square Guest
    > pre-cut to size and you fit the handrail accordingly? I wouldn't like
    > to have to cut each one. How about the spindles on the landing, would
    > they be the same length as the stairs?
    > Grumble
    It's Burbidge's Fusion system, and comes in chrome or gold finish - with the
    wood in a choice of pine, beech or oak. You can get pine spindles, too -
    rather than metal if you prefer.
    The spindles are supplied at a fixed length - with the end fixings attached.
    The landing spindles are longer, and their fixings are perpendicular -
    whereas the stair fixings are angled - and slightly flexible to accommodate
    a range of stair gradients.
    To get the handrail at the right height for the spindles, you have to cut
    the old bottom newel off in the right place - although you could shorten the
    new top section of the bottom newel a bit if necessary. The bracket for the
    top end of the handrail fits round the top newel - so you slide it up and
    down to suit.
    This is what it looks like from the top:
    http://www.mills37.plus.com/stairs.jpg
    And, for good measure, this is what it used to look like:
    http://www.mills37.plus.com/before-up.jpg
    Cheers,
    Set Square
    ______
  8. Guest
    Guest Guest
    On 14 Sep,
    Is that how the house builders left it? I very much doubt if that complies
    with building regs.
    I must get round to doing mine when I get a spare round tuit.
    B Thumbs
    Change lycos to yahoo to reply
    Guest, Sep 14, 2005
  9. Set Square
    Set Square Guest
    <> wrote:
    > On 14 Sep,
    > complies with building regs.
    It's how it was built in the 60's. It presumably complied with the regs at
    that time - before anyone started worrying about not having any gaps which a
    100mm sphere could fall through.
    Cheers,
    Set Square
    ______
    Set Square, Sep 15, 2005
  10. Stuart Noble
    Stuart Noble Guest
    Stuart Noble, Sep 15, 2005
  11. Set Square
    Set Square Guest
    > Nice hat
    Thanks! <g>
    Cheers,
    Set Square
    ______
    #11
  1. Al Hart
    Newel Post
    Al Hart, Dec 14, 2003, in forum: UK DIY
    2,314
    Set Square
    Dec 14, 2003
  2. Cordless Crazy
    Newel post removal
    Cordless Crazy, Sep 15, 2005, in forum: UK DIY
    889
    Set Square
    Sep 16, 2005
  3. Jules
    1,263
    Jules
    Jan 3, 2009
  4. edee em
    newel post
    edee em, Jul 26, 2003, in forum: Home Repair
    387
    edee em
    Jul 26, 2003
  5. Al Hart
    Stair Newel Post renewal
    Al Hart, Dec 14, 2003, in forum: UK Home Improvement
    1,471
    BigWallop
    Dec 14, 2003
Share This Page
