New house concrete slab crack
Discussion in 'Misc DIY' started by Dan C, Mar 13, 2005.
  1. Dan C
    Dan C Guest
    Hello all,
    I have a new construction house under way (in Florida). It's still in the
    rough stages (walls and roof up, plumbing and wiring mostly done, no
    sheetrock yet). Today I noticed a crack (narrow, almost a "hairline"
    crack) running for about 15 feet across the slab. Is it somewhat
    normal/expected to have a crack in the slab, or is this a very big warning
    sign that I should bring up with the builder? Thanks for information.
    If you're not on the edge, you're taking up too much space.
    Linux Registered User #327951
    Dan C, Mar 13, 2005
  2. m Ransley
    m Ransley Guest
    Small cracks are normal
    m Ransley, Mar 13, 2005
  3. Guest
    As Don Young says, some hairline cracks are not unusual and joints of
    several kinds are used to control cracking. Concrete changes volume as
    it cures and if the soil is not properly prepared, can settle.
    The size, shape, and location relative to other features can give
    useful information on causes and severity.
    TB
    , Mar 13, 2005
  4. G Henslee
    G Henslee Guest
    Dan,
    As the others have said small cracks are inevitable however you may want
    to fill them with rubberized caulking if they widen anymore, prior to
    putting down your finish floors such as carpet. Doing so may deter ants
    and such from appearing later.
    Dan C wrote:
    > Hello all,
    G Henslee, Mar 13, 2005
  5. Dan C
    Dan C Guest
    Thanks (and also to the others who replied)! I guess I'll not worry too
    much about it. Appreciate the help.
    Dan C, Mar 14, 2005
  1. Stellijer
    440
    Stellijer
    Aug 13, 2003
  2. Jerome
    Concrete slab crack ?
    Jerome, Dec 16, 2003, in forum: Building Construction
    679
    Js Walker Lazenby Jr
    Dec 16, 2003
  3. slab crack new house
    , Mar 16, 2006, in forum: Building Construction
    404
    Al Bundy
    Mar 17, 2006
  4. Dundonald
    485
    Dave Osborne
    Sep 14, 2010
  5. Mike
    447
    Tim Watts
    Oct 19, 2011
