Neutralize Muriatic acid
Discussion in 'Home Repair' started by Oren, Apr 20, 2008.
  1. Oren
    Oren Guest
    > 2: Muriatic Acid: same questions, basically:
    > ? ?How much, for how long, etc.
    > ? ?Dangers?
    Drained Pool (pending)!
    How or what can I use to neutralize Muriatic acid/water pool ?
    I plan to acid wash the in ground pool walls. While I'm busy there
    (walls) the acid wash will pool at the deep end of the pool.
    I would like to toss/pour something into the puddle that would
    neutralize acid; until I can pump it out.
    Thanks!!
    Oren
    Oren, Apr 20, 2008
  2. Oren
    dadiOH Guest
    >> ? ?Dangers?
    > Thanks!!
    > Oren
    Any base. Bicarbonate of soda is cheap and easy. If the mix fizzes and
    doesn't stop you need more bicarb.
    dadiOH
    ____________________________
    dadiOH's dandies v3.06...
    ....a help file of info about MP3s, recording from
    LP/cassette and tips & tricks on this and that.
    Get it at http://mysite.verizon.net/xico
    dadiOH, Apr 21, 2008
  3. Oren
    Guest
    > >> ? ?Dangers?
    > > Drained Pool �(pending)!
    > > I would like to toss/pour �something into the puddle that would
    > > neutralize �acid; until I can pump it out.
    > > Thanks!!
    > > Oren
    > Any base. �Bicarbonate of soda is cheap and easy. �If the mix fizzes and
    > dadiOH
    > Get it athttp://mysite.verizon.net/xico- Hide quoted text -
    > - Show quoted text -
    add water and pump down sewer. sometimes the soultion is dilution.
    a chemical fizzing in your pool might damage it
    , Apr 21, 2008
  4. Oren
    Erma1ina Guest
    > > ? ?Dangers?
    > Thanks!!
    > Oren
    Check out
    "How To Acid-Wash a Swimming Pool"
    http://www.ehow.com/how_2005488_acid-wash-pool.html
    or
    "Pool Tip #20: Acid Washing"
    http://www.alisonosinski.com/pooltips/20.htm
    They recommend sodium carbonate (aka soda ash).
    Erma1ina, Apr 21, 2008
  5. Oren
    David B. Guest
    Don't think you have to be concerned . Some pool owners use muriatic aid to
    lower ph.
    "Oren" <Oren@127.0.0.1> wrote in message
    >> ? ?Dangers?
    > Thanks!!
    > Oren
    David B., Apr 21, 2008
  6. Oren
    Phisherman Guest
    >> ? ?Dangers?
    >Thanks!!
    >Oren
    Household ammonia
    Phisherman, Apr 21, 2008
  7. Oren
    ransley Guest
    > > ? ?Dangers?
    > Thanks!!
    > Oren
    Have you ever worked with Muriatic acid, if not beware the fumes will
    seriously damage your lungs, Muriatic is a fuming acid and there is no
    way to avoid it, if you are in the pool likely the fumes will
    concentrate and stay in the pool, A very good respirator is a must but
    even that wont protect you 100%. It might be a job to pay to get done
    and not subject your lungs to. Muriatic also eats galvanising off
    pipes quickly, then they rust fast. I would not let acid sit in a
    pool, but neutralise it or have it drain while being diluted with alot
    of water. If pipes are pvc there is no issue but the drain may not be.
    There is wrong and right way to do the job you need to research it.
    Ive washed with muriatic and it made me sick for days from the fumes.
    ransley, Apr 21, 2008
  8. Oren
    ransley Guest
    > > ? ?Dangers?
    > Thanks!!
    > Oren
    My neighbor had to fill in his pool , he said over years of cleaning
    with acid the drain leaked and the pool would not hold water anymore,
    bleach kills mold, soap might work, research before you clean it.
  9. Oren
    Oren Guest
    >>> ? ?Dangers?
    >> Thanks!!
    >> Oren
    Thanks. I'm reading two pounds of soda ash will neutralize one gallon
    of muriatic acid.
    My acid wash will already be diluted (1 part acid to 4-6 parts water).
    Oren, Apr 21, 2008
  10. Oren
    Oren Guest
    On Sun, 20 Apr 2008 16:40:34 -0700 (PDT), ""
    If I neutralize the acid wash, can't I pump back into the yard? And
    not send it down the sewer.
    The reason I want to neutralize the mixture... as I work.
    Oren, Apr 21, 2008
  11. Oren
    Oren Guest
    Oren, Apr 21, 2008
    #11
  12. Oren
    Oren Guest
    On Mon, 21 Apr 2008 07:42:37 -0400, Phisherman <>
    >>> ? ?Dangers?
    >>Thanks!!
    >>Oren
    >Household ammonia
    I haven't read about using ammonia! Got a link?
    Oren, Apr 21, 2008
    #12
  13. Oren
    Oren Guest
    On Mon, 21 Apr 2008 06:12:22 -0700 (PDT), ransley
    >> > ? ?Dangers?
    >> Thanks!!
    >> Oren
    Tanks for the safety tips.
    This is a shallow, 10,000 gallon pool. PVC pipes and sewer lines.
    I'm being cautious and may hire the job out, but I now know more of
    what to ask a company that would do the wash.
    I'm leaning towards doing the job over a weekend....
    Oren, Apr 21, 2008
    #13
  14. Oren
    Oren Guest
    On Mon, 21 Apr 2008 07:13:29 -0700 (PDT), ransley
    My pool is tens years old. As far I know it has never been acid
    washed.
    Draining and cleaning will give me a chance to inspect and repair any
    damage.....
    Oren, Apr 21, 2008
    #14
  15. Oren
    Calab Guest
    > washed.
    > damage.....
    Also be aware that draining a pool puts a whole bunch of new stresses
    on it. Might want to Google it before draining.
    Fight Usenet Spam!!! - http://improve-usenet.org:80/
    Want a good newsgroup reader that will filter out GoogleGroups spam?
    Try MesNews - http://www.mesnews.net/gb/
    Calab, Apr 21, 2008
    #15
  16. Oren
    Oren Guest
    >> washed.
    >> damage.....
    Directed to my reply...
    Yes. I don't have a water table problem. My pool should not float out
    of the ground. Good point!
    Oren, Apr 21, 2008
    #16
    Especially if the ground is clay or has a high water table... Pop goes the
    weasel...
    Robert Neville, Apr 21, 2008
    #17
  18. Oren
    Phisherman Guest
    >>>> ? ?Dangers?
    >>>Thanks!!
    >>>Oren
    >>Household ammonia
    No link (chemistry class). But, if you should add too much ammonia
    there won't be a problem, plus it is cheap. The ammonia reacts with
    HCl and produces a salt. You will get a (harmless) white smoke if
    both liquids are close to each other. Properly dispose of any excess
    muriatic acid--you really don't want this stuff laying around.
    Phisherman, Apr 22, 2008
    #18
  19. Oren
    dadiOH Guest
    Be sure to add the acid TO the water, not water to acid. Wrong way =
    violent bubbling/splashing and is dangerous.
    dadiOH
    dadiOH, Apr 22, 2008
    #19
  20. Oren
    ransley Guest
    > Reminds me of highschool chemistry class.
    Muriatic does not react to water violently, so I would take the
    previous posters Bull Shit here to bull shit, Muriatic FUMES,
    Muriatic eats metal pipe. It wont react to added water as sulfuric
    will, I use Muriatic, maybe even tomorrow AM to clean stone.
    ransley, Apr 22, 2008
    #20
  1. John M.
    Muriatic acid question
    John M., Jun 30, 2003, in forum: Home Repair
    9
    656
    mark Ransley
    Jul 7, 2003
  2. Lesley See
    Muriatic Acid? Snake?
    Lesley See, Nov 9, 2004, in forum: Home Repair
    18
    694
    Lesley See
    Nov 11, 2004
  3. barry martin
    barry martin, Nov 11, 2004, in forum: Home Repair
    barry martin
    Nov 11, 2004
  4. workinprogress
    Will Muriatic Acid Damage Tiles?
    workinprogress, Feb 21, 2005, in forum: Misc DIY
    369
    Charlie Bress
    Feb 21, 2005
  5. ransley
    How do I neutralize acid
    ransley, May 10, 2008, in forum: Home Repair
    375
    David Nebenzahl
    May 10, 2008
