Mold Resistant Paint
Discussion in 'Misc DIY' started by nomad8@webtv.net, Nov 15, 2003.
  1. Guest
    I have a inside shower and the walls are unpainted stone. I find the
    shower walls are getting moldy. I have been told to clean the stone
    with bleach and than seal with silicone.
    Where can I get spreadable silicone sealant to brush over the walls?
    Please suggest particular products: it would be helpful if I could
    purchase them at Home Depot or Lowes.
    Your help would be appreciated.
    Allan
    , Nov 15, 2003
  2. mark Ransley
    mark Ransley Guest
    geosel is a product, But i advise against it. When it molds behind it or
    when it discolors you can only remove it by sandblasting. In a few
    years it could look like an ugly mess. I have a stone wall this was done
    to, its black with mold and will be sandblasted off. Use bleach often
    stone looks good natural
    mark Ransley, Nov 16, 2003
  3. Mould is really hard to get rid of. Clorox tends to remove the paint and
    isn't a permanent solution. I installed a ceiling fan and let it run for a
    few minutes to exhaust the steam which would otherwise condense on the
    walls, etc. So far, so good with that.
    <> wrote in message
    > Allan
    William W. Plummer, Nov 16, 2003
  4. DLGlos
    DLGlos Guest
    >Allan
    If it is stone, do NOT talk to your local Home Depot or Lowes.
    Instead, head to your local professional stone/tile shop. You also
    might want to stop into John Bridge's online stone/tile forum and
    re-ask your question. A bunch of knowledgeable people hang out there
    and they are honestly helpful.
    If this is an ongoing problem, better ventilation will likely be part
    of the solution.
    David Glos
    DLGlos, Nov 17, 2003
  1. Dave Jennings
    Fire resistant paint "certificate"?
    Dave Jennings, Aug 30, 2005, in forum: Misc DIY
    570
    Bob Eager
    Sep 2, 2005
  2. NumboJumbo
    Moisture resistant paint and staining
    NumboJumbo, Oct 15, 2006, in forum: Misc DIY
    342
    NumboJumbo
    Oct 15, 2006
  3. traderfjp
    Zinsser Mold Resistant Paint
    traderfjp, Mar 24, 2005, in forum: Misc DIY
    9
    1,164
    trenfour6
    Apr 30, 2014
  4. Mikepier
    314
  5. Rick Samuel
    Mold resistant materials
    Rick Samuel, Jul 27, 2003, in forum: Building Construction
    307
    Rick Samuel
    Jul 27, 2003
