Mold on window
Discussion in 'Home Repair' started by Just me, Nov 7, 2011.
  1. Just me
    Just me Guest
    I just bought a ten year old house with air exchanger and just noticed
    some mold on most of the windows. It doesn't look like it is between
    the panes. It looks like it's between the outside of the exterior
    glass and the vinyl border. I can see it looking out from the inside
    (green against the white vinyl) but don't see the same thing when I'm
    outside looking in.
    So, I don't think the seals are gone. The black rubber between the
    panes looks clean. They are regular double pane casement windows. And
    yes, we get a lot of rain here. LOL
    Anything I can do to get rid of the mold?
  2. Just me
    harry Guest
    > outside looking in.
    > Thanks
    Remove glass, clean, replace. Simple.
    harry, Nov 7, 2011
  3. Just me
    Just me Guest
    > > outside looking in.
    > > Thanks
    The glass cannot be removed.
  4. "Just me" <> wrote in message
    > > outside looking in.
    What makes you think it is mould (rather than the way the
    interior rubber cushioning reacts to sunlight)? The
    windows were sealed at the factory and it is not likely
    mould spores both were present and could find nutritive
    materials within the seal.
    Don Phillipson
    Carlsbad Springs
    (Ottawa, Canada)
    Don Phillipson, Nov 7, 2011
  5. Just me
    ransley Guest
    > outside looking in.
    > Thanks
    Use laundry bleach in a spray bottle
    ransley, Nov 7, 2011
  6. Just me
    Just me Guest
    > news:...
    > > > outside looking in.
    > Don Phillipson
    > Carlsbad Springs
    > (Ottawa, Canada)
    If it were reacting to sunlight, I would expect the north facing
    windows to have none - but they do. And since the growth is on the
    exterior side, it's sheltered from the sun (there is none on the
    interior pane anywhere - which is exposed to sunlight). It's also only
    occurring on the bottom portion and at no other part of the window, so
    if it were sun, it would affect the entire window equally. The colour
    of the growth is green and being in a sheltered part of the window,
    with a wet climate, it's not hard to determine it's mold or some form
    of growth that shouldn't be there.
    The only suggestion I've gotten is to use clear caulk on the lip of
    the window on the outside since the water is obviously getting in
    behind the vinyl. Barring any other suggestions, I will try that. If I
    can cut off the supply of moisture, it should kill what is growing
    there.
  7. Just me
    Robert Macy Guest
    > >news:....
    > > > > outside looking in.
    > > Don Phillipson
    > > Carlsbad Springs
    > > (Ottawa, Canada)
    > there.
    Have the mold tested.
    Robert Macy, Nov 7, 2011
  8. Just me
    Just me Guest
    > > >news:....
    > > > > > (green against the white vinyl) but don't see the same thing whenI'm
    > > > > > outside looking in.
    > > > Don Phillipson
    > > > Carlsbad Springs
    > > > (Ottawa, Canada)
    > > there.
    It's not easily accessible. Even if I could, I see no reason to test
    it. It's on the exterior of the window so that it's not affecting the
    internal air quality.
    I just need to find a way to keep the moisture out so that it doesn't
    spread any farther. Soaking the area with the javex based solution
    then caulking it seems to be the only solution.
  9. Just me
    hr(bob) Guest
    > > > >news:...
    > > > > > > outside looking in.
    > > > > Don Phillipson
    > > > > Carlsbad Springs
    > > > > (Ottawa, Canada)
    > > > there.
    > then caulking it seems to be the only solution.- Hide quoted text -
    > - Show quoted text -
    To start with, are you talking about thermopane windows, double-hung
    windows, with storm windows, or what?? Can you take a picture to show
    us?
    hr(bob) , Nov 7, 2011
  10. Just me
    Just me Guest
    On Nov 7, 6:49 pm, "hr(bob) " <>
    > > > > >news:..com...
    > > > > > > > glass and the vinyl border. I can see it looking out from theinside
    > > > > > > > outside looking in.
    > > > > > Don Phillipson
    > > > > > Carlsbad Springs
    > > > > > (Ottawa, Canada)
    > > > > occurring on the bottom portion and at no other part of the window,so
    > > > > there.
    > us?
    As noted, they are double pane vinyl casement windows. Too dark right
    now for a picture.
  11. Just me
    harry Guest
    > > > outside looking in.
    > > > Thanks
    > The glass cannot be removed.- Hide quoted text -
    So what happens if the glass gets broken? Complete new window?
    harry, Nov 8, 2011
    #11
  12. Just me
    Just me Guest
    > > > > outside looking in.
    > > > > Thanks
    The pane physically being removed isn't the problem (for a
    professional). The problem is breaking the seal will release the
    insulating gas in between the panes. I believe the gas can be replaced
    but at a cost. If the glass is broken, the gas has escaped so you only
    have two options. Replace the window or replace the pane and get the
    gas injected (if it's possible). Replacing the window would probably
    not be cost prohibitive.
    I'm not going to break the seal trying to get at some mold that is on
    the exterior of the window.
    Just me, Nov 8, 2011
    #12
  13. Just me
    Ron Guest
    > outside looking in.
    > Thanks
    Squirt bottle with bleach and water.
    Ron, Nov 8, 2011
    #13
  14. Just me
    Just me Guest
    > > outside looking in.
    > > Thanks
    That seems to be the immediate answer. If the water can get in there
    to grow the stuff, the bleach can get in to kill it. Then a thin bead
    of caulk later to keep the water out.
    #14
  15. Just me
    harry Guest
    > > > > > outside looking in.
    > > > > > panes looks clean. They are regular double pane casement windows.And
    > > > > > Thanks
    > the exterior of the window.- Hide quoted text -
    No it wont, the two glass sheets are joined together with a spacer/
    sealing compound. I takes only a few minutes to remove the sealed
    unit.
    They are held in by beads/plastic moulding and neoprene seals.
    On most, you prise the beads out with (say) a woodworkers chisel,
    starting on the longer sides in the centre.
    There are a few around where you have to remove the neoprene seal
    first.
    It is a trivial task. There may be spacers and security rivets inside
    the frame if the beads are external.
    harry, Nov 8, 2011
    #15
  16. Just me
    Ron Guest
    > > > > > > outside looking in.
    > > > > > > Thanks
    > unit.
    > first.
    He doesn't need to remove the glass. He's already stated that the
    mildew/mold is between the outer piece of glass and the stop.
    Also, w/o knowing exactly what kind of window that he has, most likely
    the glass is also sealed to the inner frame...not just sitting there
    with only the stops to hold it in place.
    Spray bottle with a mixture of bleach and water or straight bleach
    will take care of the problem.
    Ron, Nov 8, 2011
    #16
  17. Just me
    Oren Guest
    On Tue, 8 Nov 2011 10:16:25 -0800 (PST), Ron <>
    Exactly
    Simple place to start :-/
    Oren, Nov 8, 2011
    #17
  18. Just me
    harry Guest
    > > > > > > > outside looking in.
    > > > > > > > Thanks
    > > unit.
    > > first.
    > will take care of the problem.- Hide quoted text -
    It might kill the mould but it will still be there.
    harry, Nov 9, 2011
    #18
  1. Phil L
    1,012
    Phil L
    Apr 26, 2008
  2. Chuckles
    586
    Chuckles
    Apr 23, 2004
  3. John
    Mold in window frames
    John, Nov 30, 2005, in forum: Misc DIY
    201
  4. Nancie
    397
  5. Mold in Window A/C
    , Oct 1, 2006, in forum: Misc DIY
    229
    tamara719
    Oct 2, 2006
