Minimum stair to ceiling height?
Discussion in 'UK DIY' started by daddyfreddy@gmail.com, Aug 25, 2005.
  1. Guest
    Can anyone confirm what the required minimum height is between the
    stair nose and ceiling?
    I'm replacing some stairs and where they turn you have the landing
    above you. I want to make sure the height clearance is adequate. One
    source tells me it's 6'6" but even they weren't 100% sure.
    , Aug 25, 2005
  2. Bobby Bewl
    Bobby Bewl Guest
    <> wrote in message
    2 metres
    See: www.stairplan.com/Partkpage7.pdf
    Bobby
    Bobby Bewl, Aug 25, 2005
    The Building Regs have changed, there is no minimum ceiling height.
    In my study (a loft conversion) there is 1.9 metres,, the Building
    Inspector confirmed that the requirement no longer exists.
    Nigel M
    Nigel Molesworth, Aug 25, 2005
  4. Bobby Bewl
    Bobby Bewl Guest
    "Bobby Bewl" <> wrote in message
    news:dekuni$ci3$-infra.bt.com...
    > <> wrote in message
    > news:...
    > 2 metres
    > Bobby
    and it is the same in Scotland:
    http://www.scotland.gov.uk/build_regs/standards/brs-03.asp#S3
    Bobby
  5. in2minds
    in2minds Guest
    not sure if it no longer exists but the toilet in our basement has only
    5'8" headroom and was passed by the BCO
    in2minds, Aug 25, 2005
  6. Ian White
    Ian White Guest
    AIUI there is still a 2.0m height requirement on the staircase and its
    top and bottom landings, but not anywhere else upstairs.
    Ian White
    Ian White, Aug 25, 2005
  7. Matt
    Matt Guest
    .....who, being 6ft tall then proceeded to take a leak round the back
    of the shed
    Matt, Aug 25, 2005
  8. John Rumm
    John Rumm Guest
    There is no minimum height for ceilings in rooms, but stairs are different.
    There standard headroom is 2m. For loft conversions, this is reduced to
    1.9m at the centre of the tread and can fall to as little as 1.8m at the
    edges of the tread.
    I would suggest that either you misunderstood, or he was wrong. See
    section 1.10 of part K of the building regs.
    Cheers,
    John.
    | Internode Ltd - http://www.internode.co.uk |
    | John Rumm - john(at)internode(dot)co(dot)uk |
    John Rumm, Aug 26, 2005
    But there is on *Staircases*.
    BTW the measurement is between a line along the centre of the noses of
    the treads to any point vertically above IIRC
    Thats celing heifht in rooms. Not in straicases. Banging your head on
    the ceiling is not the same as falling down staris in today's britain.
    The Natural Philosopher, Aug 29, 2005
    My understanding is similar.
  11. Roger
    Roger Guest
    The message <>
    from The Natural Philosopher <> contains these words:
    ISTR that there is some limited relaxation of this rule for loft
    conversions where it is difficult to comply with. It is some time since
    I looked it up and I can't remember the detail.
    Roger Chapman
    Roger, Aug 29, 2005
    #11
  12. John Rumm
    John Rumm Guest
    > conversions
    That is right. If you can't meet the 2m requirement then you can go for
    1.9m in the centre of the tread falling to 1.8m at the edges.
    Cheers,
    John.
    John Rumm, Aug 30, 2005
    #12
  13. Guest
    Okay, cheers all. 200cm is the correct figure it appears. The original
    stairs had a 195cm clearance. Not sure if the regulations applied in
    the 70s but looking at the poor way these original stairs were
    installed/supported they could have got away with installing a bamboo
    ladder.
    , Aug 30, 2005
    #13
  14. Roger
    Roger Guest
    The message <>
    from contains these words:
    > ladder.
    Before Building Regulations went metric the requirement was for a mere
    78 inches or 1981.2mm in new money. I don't know when the change
    occurred but it was certainly later than the early 70s.
    Roger Chapman
    Roger, Aug 30, 2005
    #14
  1. G&M
    Minimum door height
    G&M, Jun 3, 2004, in forum: Misc DIY
    8,642
  2. Replies:
    354
    Roger
    Sep 28, 2005
  3. iamwhatiam
    402
    Andy Wade
    Nov 17, 2005
  4. Yi Jin
    minimum door height
    Yi Jin, Mar 1, 2004, in forum: Misc DIY
    844
  5. Slumlord
    619
    Goedjn
    Mar 9, 2005
